Question about Kenmore HE2 Plus Front Load Washer
Mold on rubber ring of front load washer
The rubber ring by the door of my front load washing is full of mold. How can I remove it safely?
  • 4,345 Answers
Use soap and water, and scrub it.
Posted on Sep 20, 2009
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    Neptune washer front door seal has black build up
    Try pouring a cup full of distilled white vinegar into the soap dispenser drawer while it is filling up on a hot wash. Don't put any washing in, just let the machine go through the full cycle. Repeat if necessary.
    You may be able to scrub lightly affected areas of the door seal with a scourer or old toothbrush etc. and something like Jiff. To be on the safe side you should wear goggles and a mask when dealing with black mold.
    It may be worth trying a black mold remover available from supermarkets but read the instructions to make sure it is safe to use on rubber if intending to use it on the door seal. If badly affected - the only way to get rid of it - is to replace the door seal.
    Nov 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Pink mold in outer rubber ring and mold extends to door.
    Here is a tip that I wrote about cleaning your washing machine...
    How to have a Clean Washer
    http://www.fixya.com/support/r4356970-clean_washer
    Make sure to leave the door open when the machine is not in use to let it dry out...
    heatman101
    Jul 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
    There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
    Hi.
    The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
    The only way to remove is by replacing the door seal.
    If you try bleach etc then it will cause the mold to get worse.
    Hope this helps
    Aardvark Repairs
    Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
    Water sitting and mold growing in the rubber gasket ring around the opening for the door
    Front loaders are known for building up mold and the smell.
    It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
    It’s caused by using fabric softener. Dilute it 50/50 with water.
    It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
    Pull the rubber door seal back and clean the mold off .
    affresh is recommended by some manufacturers. You run it through a wash cycle with it.
    Oct 09, 2009 | LG WM-2277HW Front Load Washer
    MOLD REMOVAL FROM WASHER RUBBER BOOT
    Try this:
    Run an empty load and as soon as water has filled and the washer begins to run, open the washer door (probably have to pause the washer via the control panel) and add 3 - 4 cap fulls of regular bleach. If you don't have regular bleach, you can try vinegar. After cycle completes, open washer and wipe the entire gasket with an old towel.
    When washer is not in use, prop the door open so the inside can fully dry.
    Please report back here with the results and if you are still having problems, we can take the next steps if needed.
    Aug 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Mold in rubber ring front loader Fridgidare washer
    Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
    Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Mold build up around ribber gasket . Heavy, black and hard
    Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
    May 28, 2009 | Washing Machines
    Black mold growing on gray rubber boot inside door.
    Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
    Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Kenmore HE2 Plus Front Load Washer Logo
    715 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
