Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher Hello my dishwasher doesnt even turn on
  • bridgit Dec 31, 2007
    I have a brand new dishwasher and i tried a test run and the water never completely drained from the bottom. then it made this pop sound and now it won't even turn on. I just installed yesterday and have never wshed anything in it and it won't turn on.
  • Anonymous Aug 22, 2008
    replaced on off switch assembly
  • 75 Answers
Hi there first i would confirm you don't have power supply issue, replace the fuse and try different power outlet failing that it is quite common for bosch on/off switchs to burn out.
hope this is of some help
Posted on Dec 14, 2007
Bosh wishwasherhow do you unlock the child safety lock?
Hello there and welcome to fixya The child lock function of your Bosch dishwasher prevents accidental program changes and stops children playing with the controls while the appliance is running. You might want to turn the lock off if it has been accidentally turned on. The controls of the dishwasher are disabled, preventing you from starting a new wash, while the child lock is running. The lock is simple to turn on and off, as necessary, in just a few seconds
Read more: How to Get the Child Lock off a Bosch Dishwasher ' eHow.com http://www.ehow.com/how_12069321_child-lock-off-bosch-dishwasher.html#ixzz2E7bFXnhs
please feel free to give me a rating if this works for you it helps me give you the best help i possiabley can ok
Best regards Mike
Dec 04, 2012 | Bosch SHU9915UC Dishwasher
Hello. My Bosch dishwasher just isn't turning on again. It was working fine and now I cant get anything to turn on. Thank you
Make sure you have power to the machine. Plug in something you know works into the same power point as the dishwasher. If it works, then you will know the dishwasher has failed. If it doesnt, then check your meter box, switch, RCD etc.
Jul 26, 2011 | Bosch Dishwashers
Just installed a bosch dishwasher and when I turned it on the active light flashes but nothing else happens.
Hello, we'd like to see what we can do to assist you with this challenge. If you have a moment, please email us at Bosch.support@gmail.com so we can learn more about your situation. -The Bosch team
Jun 29, 2011 | Bosch Dishwashers
I have a Bosch dishwasher SGV43A03 and the bottom spray arm doesnt spin. It is free to move by hand, is clean inside and has clean nozzles. The water pump is operating the top jet and top spray arm...
Hello this means the circulation pump would need to be replaced. You can purchase the part from the link below. Also there are several articles that explain how to work on Bosch dishwashers.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
Dishwasher stays in cleaning mode and does not cycle to rinse.
Hello their sounds as though water heater has failed if it doesnt heat it defaults to a 3 hour cold wash and never finishes cycle eg doesnt go through rinse stages.will need a new heater service tech to change as fairly complicated.
Nov 02, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwasher fills and empties water but doesnt run any programm
Hello, welcome to FixYa. Can you elaborate on the actions which take place ? Does it fill and just sit idle until eventually drain or do you cancel the cycle manually to initiate the draining ? I should be able to help you with some more details. I will watch for your reply. macmarkus :)
Jun 24, 2010 | Bosch 24 in. SGS43C12 Classixx...
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
Bosch dishwasher not working
Try turning the breaker off for a minute or two. That may reset the computer to the default settings.
Dec 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
670 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
