Question about Canon PIXMA MP210 Photo All-In-One Printer
Cannot change cartidges - refuse to click into place help
Why is my printer not responding after changing printer cartidges
check that printer cartidges are on the correct places, then turn printer and computer off and try again remember to total power down the printer
Mar 09, 2013 | Office Equipment & Supplies
My hp 4355 printer, error code cartridge error, n
No problem ... just try to follow these steps please and it will give all the answer for your question
remove the cartidge from the printer and clean up the bronze dotted spots on the cartidge as well as the place where the cartidge is placed inside the printer... then turn on your printer it will ask you to insert the cartidges .....
hope it will owrk for you if does not you may try another cartidge if does not work either its time to call the Manufacturer and get the printer replaced....
May 06, 2010 | HP Officejet 4355 All-In-One InkJet...
Keep getting remove and check cartridge, I did this and also checked for paper jam but still won't work.
Apr 14, 2010 | HP PSC 2175 All-In-One InkJet Printer
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
My epson d88 printer has 2 flashing lights, the ink charge and paper feed lights. this is preventing me printing out. this happened after i tried to change my inks. can anybody help?
I just had the same problem. Try opening the top flap on the printer and see if you can click the lid down on the ink cartridge box more firmly (until it clicks) - i had to force the cartridges to the left slightly to do this, although I'm not sure if thats neccessary. Then i pushed the cartidge box back to the right where it was before. The 2 red lights still flashed for me, but when i turned the printer off and on again it worked just fine. I hope this helps.
Jan 23, 2009 | Epson Stylus D88 InkJet Photo Printer
Printer doesn't reset after refil
I don't know what this "refill starter pack" contains but you HAVE TO change the chip of the cartridge otherwise the printer does not know that you changed/refilled the cartridge.
Dec 09, 2008 | HP LaserJet 1600 Printer
How do I change the ink cartridge in my Lexmark x2470
How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
  1. Make sure that plain paper is loaded in the paper tray.
  2. Ensure that the power light is on.
  3. Open the cartridge door.
    The cartridge carrier may move slightly, and then return to the loading position.
  4. Push up on the cartridge lever.The cartridge holder springs open.
  5. Remove the old print cartridge and dispose of it.
  6. Remove the sticker and transparent tape from the new print cartridge.
    Warning! Do not touch the gold contact area on the print cartridge.
  7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
    Insert the color cartridge in the front carrier slot.
    Insert the black cartridge in the back carrier slot.
  8. Close the cartridge door.
  9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
  10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
Please Rate the solution.
All the Best
Sammy
Sep 26, 2008 | Lexmark Office Equipment & Supplies
Canon MP170 printer
I HAD THE SAME PROBLEM WITH THIS SAME PRINTER THE ANSWER IS THE INK OVER FLOW SPONGE IN SIDE THE PRINTER IS MOST LIKELY FULL NEED TO BE CLEANED OUT
Jul 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Clicking noise from toner drum
get the toner cartidge out click in the top many times and then check it many times in horizontal leve (move it quickly from right to left many times)this will mix the toner.- reinstall it again.l
Mar 05, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Printhead ink cartidge replacement
Ok, you may have blocked printheads. Remove cartridges, using a cleaning solution and cotton buds (q-tips) thoroughly clean all residue. Now replace cartridges and try again.
Aug 15, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
29 people viewed this question
old marine
old marine
