Question about Huffy Alpine 24 Youth All-Terrain Bicycle
How do you adjust bicycle hand brakes - Huffy Alpine 24 Youth All-Terrain Bicycle
  • 484 Answers
There are two techniques:
The first involves the adjusting barrels and lock nuts on the brake levers, but i prefer to loosen the cable in the brake arm and pull it tighter and reclamp it there.
Hope this helps, feel free to email for further help,
matt
Allrotor13b@gmail.com
Posted on Sep 20, 2009
5 Suggested Answers
  • 384 Answers
SOURCE: How do you adjust the hand brake? I can get them
the bolt that runs through the frame might needto be tigthen more that the part that holds the brake in place
Posted on Feb 22, 2010
  • 1138 Answers
SOURCE: adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
Posted on Aug 28, 2009
  • 71 Answers
SOURCE: rear bicycle wheel won't turn. Brakes are siezed.
Find the arm that hold the cable. Loosen it to the desired tension.please comment if it does not work for you! I can help! Good Luck!
Posted on Jun 11, 2009
ftw1952
  • 10319 Answers
SOURCE: locating a manual with APSE drum type bicycle
freemanuals.com
or
http://www.bikepartsusa.com/?source=google&gclid=CI-YzIGcqKACFQ0eDQodY2_FZw
Posted on Mar 08, 2010
How do I adjust the brakes on my bicycle?
Re position the braking assembly so the stationary pad is just about to touch the rim and tighten. Then with the adjustment adjust the pad that moves so that it applies appropriate braking force when you squeeze the hand brake.
Oct 06, 2015 | Specialized Cycling
Adjusting bicycle hand brakes
http://youtu.be/hg6s596PPRY
Apr 17, 2014 | Schwinn Cycling
Hand brakes
hi, it all depends on what make and type of vehicle as there are many varieties of hand brake cable set-ups. what is it you wish to adjust brake on?
Paul.
May 06, 2012 | Schwinn Cycling
How do I adjust my hand brakes?
There is an adjusting screw on the handle and one at the bottom of the brake cable. Squeeze the brakes by hand tight on the tire and adjust the scews.
Feb 12, 2012 | Gary Fisher Presidio
Back hand brake rubs on pads cannot adjust basic hand brakes
If you can't adjust your brake position by using the adjustment screws you can loosen the wheel bolts and physically change the tires position to make it fit within the brakes. If that doesn't work take you bicycle into your local bike shop and have them check your rim alignment.
May 06, 2011 | Cycling
Front brake pads are not resting on the rim
Getting hand-brakes adjusted correctly is often a challenge, but they are adjustable with the right size wrenches. On the other hand, a front hand-brake on a child's one-speed bike is not necessary and is only on the bike to give it sales-appeal. If this is a one-speed bike, then it has a coaster brake (operated by pushing the pedals backwards). Actually the coaster brake is much safer than a front hand brake anyway. If the child applies the coaster brake too heavily, they will just skid. If they apply the front brake too heavily, they will go over the handlebars. If the hand brake is not interfering with the front wheel and is just not very effective, I would just leave it as-is. If the brakes rub on the tire, you should adjust them so they don't rub the tire.
Jul 23, 2010 | Dynacraft 16" Boy's Wheels Bike
The bolt that attaches the brake to the bike needs to be tightened/adjusted
Nov 23, 2009 | Dynacraft Girls 16" Barbie Bike
How do i adjust the brakes on a schwinn stingray low rider bicycle? the front brakes dont grip the wheel enough to stop and the rear is rubbing on one side. thanks
Let us start with the rear. The brake arms will have a small screw located on them near the pivot. You can screw these in to adjust the relation of the pad to the rim. You can also (if that didn't take care of it) remove the brake arm and move the spring's pin to the next hole to make sure it properly clears itself.
The front can be tightened on the brake levers with the adjustment barrel, or, if that is already fully turned out, turn it all the way back in and release the cable at the brake itself and retighten it when you have adequately adjusted the brake there.
Check out Parktool.com's repair help page (located at the top right hand of their homepage) for excellent detailed and illustrated help in bike maintenance.
Hope this helps a little,
matt
Sep 19, 2009 | Schwinn Stingray Chopper Youth Bicycle...
Adjust rear hand brake on Mongoose 20 inch bicycle
Aug 27, 2009 | Mongoose 20-Inch Gravity Games BMX...
Hand brake adjustment for schwinn point beach crusier
The brake that you are adjusting go to that wheel. On that wheel you will see a brake pad on each side of the wheel. To adjust tighter you squeese these two brake pads together, you will see a wire, there will be a nut that they wire goes through, loosen the nut and squeese brake pads together, then tighten nut back up. your hand brake will now be adjusted.
Feb 24, 2009 | Cycling
Huffy Alpine 24 Youth All-Terrain Bicycle Logo
664 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
