Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Dr code what does this mean? what do i need to do kenmore gas stove
    President:
  • 1,723 Answers
That's a door code, check the door and door switch for alignment and activating switch.
Posted on Sep 20, 2009
Kenmore stove the oven wont come on it says dr
The DR error can mean that the door lock is enabled (or the oven believes it is). If the oven door was open and the Clean button was pressed, this can happen. Try pressing Cancel with the door closed. If the door is open, press the oven light button in and press Cancel. Try unplugging the oven (or flipping the circuit breaker to off) for a few minutes to reset the error.
If these don't help and the oven is not locked, then the control unit probably needs to be replaced. If you add a comment with the model of the oven, I may be able to direct you to the parts.
If your oven is still under warranty, contact Kenmore. I hope this helps.
Jul 03, 2014 | Kenmore Ovens
My Kenmore Elite Gas Range is reading F1 on the display....the gas burners work on stove but the oven wont work....any ideas??
The F1 error code is a failure of the electronic oven control. This could be caused by a stuck keypad or an internal malfunction of the control. You will need to disconnect power and wait at least 30 seconds, reapply power and if condition still exist you will need to replace the electronic oven control.
You will also need to check if the oven is overheating. If the control has sensed a runaway oven temperature it will display an F1 error code. This could indicate a failure of the oven temperature sensor.
Hope helps.
Jul 18, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
I have a self cleaning kenmore stove and I cleaned it today. It cleaned beautifully, but when it finished cleaning the clock did not come on; a code DR came on. I looked in my manual and could not...
My mother cleaned her oven this weekend and she got the same message on her display. I could not answer what 'dr' stands for, but I was able to clear the message simply by unplugging and replugging the range.
Still if anyone know what it means, it would be a big help.
Sep 09, 2010 | Kenmore Kitchen Ranges
I can't find my model number on my Sears Kenmore Gas stove. Several times now the stove has beeped then kicked out with EO and F2 showing in the clock area. The stove was bought in 2000 or 1999. Can you...
The tag with the model number is usually located on the rail that is visible with the lower drawer open.
The code you are getting is an indication that the oven got too hot or the control thinks the oven got too hot. It is usually do to one of two parts that have failed.
If the oven did not get too hot and you got the failure code, then the sensor would be bad.
If the oven did get too hot then the ERC (electronic range control) is bad.
May 17, 2010 | Kenmore 75012 / 75014 Gas Kitchen Range
What does it mean when the oven beep and F10 is on the screen
Go online and type in your model number and ask what the F10 code means. Every stove is slightly different. Mine did the same thing and the F2 code came on. Meant the sensor was gone and I replaced it in 10 minutes for under $80. Even a novice can do it. Perhaps same with yours, perhaps not.
Jan 08, 2010 | Kenmore 33169 Gas Single Oven
Kenmore gas stove Gas leak
I had this problem with my stove and had the regulator changed coming off the PROPANE tank.
Apr 04, 2017 | Kenmore Kitchen Ranges
Error code F93 Kenmore range model 970-686030
My stove just did the same thing but I have the maintenance agreement and they just told me to unplug the stove completely for 30 minutes. This will rest the internal working of the stove. Hope this helps I am trying it now
Rita
Jul 16, 2008 | Kitchen Ranges
Kenmore elite gas stove
f-1 means the ERC is bad. sometimes turning the breaker off for a couple of min will help but if not the the clock/oven control needs to be replaced
Nov 22, 2007 | Ovens
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
113 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
