Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Ignitor maytag MGR6772BDS gas stove
With the stove and cooktop off on the gas stove, all four igniters started on their own and would not turn off until I unplugged the 110v cord from the wall.
All four continue to ignite when it is plugged back in.
  • 6 more comments
  • send Dec 31, 2007
    We don't seem to have any connectors at each burner.
    Where else would we look.?
  • DLJxn May 30, 2008
    All 5 ignitors began simultaneous sparking, independent of the switch position and whether or not the burner is lit. The synopsis about one of the switches being faulty makes sense, especially if significant moisture invaded the switch and caused a short. The manual says under no circumstances should the top be attempted to be removed. If this is the case, how am I to gain access to the switches and the wiring? DLJ
  • christjesus5 Oct 01, 2008
    Only one of my ignitors keeps clicking. The front left one. How do I fix that.
  • cds5150 Dec 26, 2008
    cds5150@gmail.com
  • claire7 Apr 26, 2009
    All four of my ignitors began to click without my gas stove being turn on or in use. We had to unplug the electric to make it stop.
  • bvaldes2 Apr 26, 2009
    I cleaned the stove top and the ignitors keep clicking, I had to unplug the range
  • mel104208 May 22, 2009
    Same problem - funny no answers!!
  • Anonymous May 25, 2009
    My stove is clicking as we speak! I'm grateful for the postings. We're starting to check the connectors, hopefully we can the bad connector. Did I mention, it's the holidays and guests are expected in a few hours.
  • 833 Answers
One of your switches on the gas controls is bad. You'll have to remove the lines from the switches to the ignitor one at a time to figure out which. With the power off, lift the top of the range to expose the controls. There are connectors for the power at each control. After removing one line, turn the power back on and see the result. You'll know when you've hit the right switch. Then, replace it.
Posted on Dec 14, 2007
Owners manual says in bold print "Do not attempt to lift the cooktop for any reason". So how do I get into the controls to attempt to fit the ignitor problem?
Posted on Sep 20, 2011
What wood cause a burner to ignite and will not turn off.
Is there an orange glow in the burner area when this happens? If so then the thermostat is not shutting the ignitor off and needs replacing. If there is no glow then the gas valve is not shutting off the gas and needs repalcing
Oct 10, 2014 | Whirlpool Kitchen Ranges
Ignitor keeps clicking and i unplugged the stove and it still is clicking to ignite
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 16, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Our gemini stove's bottom oven will not ignite
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Electronic ignitors won't stop clicking
Pull the burner caps, etc off the stove and completely dry the area ..Be sure to inspect each ignitor contact for cleanliness as well. If the ignitors have soapy buildup or water, around them, they can act like this.
You should be able to pull the burner caps and flame diffusers off and clean with a paper towel, and if needed, a light scouring sponge. Be careful not to scratch the surfaces, but scour the top of the ignitors carefully if you need to clean them.
Jul 31, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Has anyone else had a serious problem with the electrical wiring in their Maytag Gemini Gas Range? Without using the stove, the ignitors started firing and then stopped when I turned all the burners on....
Same problem here - and I have read about others with this problem. Usually blamed on moisture getting into the control unit ( which is under the backmost burner knob). I did not have a spill on the cooktop, nor was I "over zealous" cleaning. Looks like a bad design. Waiting to hear from the technician how much THIS is going to cost me...
Jan 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Jul 01, 2009 | Maytag MGC5430 Gas Cooktop
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
653 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
