Question about Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range
Hi, I am getting an error reading on my whirpool gold stove it reads EO -F2- do you have any clues to what my be my problem. Thank you in advance for your suggestion
    President:
  • 1,723 Answers
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Posted on Sep 20, 2009
Testimonial: "Thank you so much! I will check around for reasonable prices to get a new keypad installed. I really appreciate your expertise. "
Kenmore electric stove model 95012102 displays EO-F2 the cooktop works.
that code is a bad touchpad.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1cHA0Nn50
Oct 30, 2011 | Kitchen Ranges
Hi I am getting an EO-F2 display on my stove Could you please tell me what this code signifies is the problem? Thank you Kurt
Hi
Error F2-E0 error means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Jun 11, 2011 | Kitchen Ranges
My Kenmore electric stove keeps beeping EO F-2-. What does this mean? Is it safe to use?
Hello & Welcome to FixYa
F2-E0 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 09, 2011 | Kenmore 72002 / 72004 Kitchen Range
My whirlpool gold accubake system display has eo f 2 ,my book is packed away for remodeling, so what do I do? Thanks
F2-E0 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Whirlpool Ovens
Display reads EO -F2- stove top works, oven will not
Sep 14, 2010 | KitchenAid KERA205P Electric Kitchen Range
Please be my hero
E0-F2 means a shorted keypad and will need to be replaced. Not sure how much the repair would cost w/o knowing the model # of the oven. This repair can range from $250 - $500 depending on the price of the part. Sorry for the bad news.
Dec 11, 2008 | Kitchen Ranges
Whirlpool Gold Range Error code EO F2
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted keypad"
"Replace Electronic Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
Dec 11, 2008 | Whirlpool GR773LXSS - Stainless Steel...
EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
Jun 01, 2008 | Kitchen Ranges
Error Message: EO -F2-, but I don't have a manual
Actual Solution: I justed fixed EO F2
1. Disconnect the power for 30 minutes!
2. Once reconnect the power, press the "cancel" button for 3-4 sec, this two steps serve as reset.
I have a Whirlpoor gas range and it has error message EO F2 for few weeks now. After searching on internet for possible solutions and didnt find anything working, I called Whirlpool thinking as a last attempt before calling expensive tech. people.
They told me exactly the above two steps, I came home and tried, it worked like a charm....
Note: Disconnect for 30 min, I tired 1 minute as some suggested on internet and didnt work.
Mar 04, 2007 | Kenmore 95002 / 95004 Electric Kitchen...
Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range Logo
378 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
