Question about HP Pavilion dv1000 Notebook
Desktop freezes..no icons..nothing!!!
Sense about a month, each time I use my laptop (Toshiba) my desktop freezes. Windows XP opens normally until he reach the desktop and then I only have the background without nothing. No startup menu, No icons, nothing! I only can move the mouse and after tapping Ctrl, Alt, Del I couldnt move the mouse.
PLEASE SOMEBODY I NEED HELP!!
I HAVE IMPORTANT INFORMATIONS ON IT. HOW CAN I GET THEM OUT???
THNX
  • hamed93 Sep 24, 2009
    I actually tried the safe mode before but I had the same problem (only desktop and nothing)..I dont know what to do!!!
  • 93 Answers
Hi... login to safe mode by tapping F8 before u seee the Windows Xp Splash screen... select the option SAFE MODE and wait for a while u ll get the desktop.. then go to USER ACCOUNTS in Control Panel.. and create a new user account... and delete the previous account.. While deleting Make sure to select the option DELETE ONLY ACCOUNT dont select Delete files k... The files from the previous acconut will be saved to the desktop of the new account..
Posted on Sep 20, 2009
I have a Toshiba Satellite L505D-S5983
Try a different mouse, that would prove where the problem lies. Looks to me like the mouse is failing.
Jul 16, 2010 | Toshiba Computers & Internet
My Dell Inspiron laptop boot up freezes
RUN CHECK DISK AND IF IT STILL WONT BOOT RESTART AND BEFOR THE WINDOWS LOGO COMES ON PRESS F8 AND CHECK START IN SAFE MODE THEN RUN CHECK DISK
Nov 12, 2009 | Dell Inspiron 6400 Notebook
I get the message "Bad check sum (CMOS)" Model toshiba tecra 730XCDT
hi friend,
Probably a dead Motherboard battery. Need to enter the BIOS screens and reset values. Especially the time and date. Maybe the boot order and if using USB KBoard enable legusy USB devices. This will occur each time your friend shuts down and reboots until the battery is changed.
Issue
When you turn your Toshiba computer on, you see an error message like: **** Bad RTC battery ****
**** Bad Checksum (CMOS) ****
Check system, then press [F1] key The Real Time Clock (RTC) battery provides power for the internal clock/calendar and for maintaining system configuration settings.
This error can occur when a machine has been left turned-off for an extended period of time (around a month), and is the result of a depleted RTC battery. Other symptoms include not being able to execute Windows Update properly, errors/problems executing application software (like Norton Antivirus), and the appearance of the Windows XP "Desktop Clean Wizard".
Resolution This condition is easy to fix in 3 basic steps: Reset the BIOS defaults
Set the correct date and time in Windows.
Charge the RTC battery Please follow the detailed instructions in the next section.
Procedure Set BIOS defaults Press the [F1] key as instructed in the error message:
Check system, then press [F1] key In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system. Set the correct date and time in Windows As Windows starts-up, you may see an error message about an "Invalid System Time". Go ahead and click "OK" to clear the error dialog. Open the Windows Control Panel and open the "Date and Time" control by double-clicking its icon. Set the correct date and time, then click OK to save. Charge the Real Time Clock (RTC) battery To charge the RTC battery, connect the AC adapter and turn the computer on (both the DC IN and Power LEDs must be green). Leave the machine on for approximately 24 hours to ensure a full charge in the RTC battery. Please note that the RTC battery does not charge while the PC is turned off, regardless of whether the AC adapter is connected or not. Other Information: If, on subsequent reboots, the "Bad RTC Battery" error persists, it's quite likely that you actually do have a bad RTC battery. If that's the case, you should contact a Toshiba Authorized Service Provider to have the system serviced. Windows XP Desktop Cleanup Wizard The first time you reboot Windows XP after resetting the system clock, Windows XP may try to run the "Desktop Cleanup Wizard". Simply Cancel the "Desktop Cleanup Wizard" at the first dialog. If you do manage to clean your shortcuts from the desktop and want to recover them, you will find them in a folder called "Unused Desktop Shortcuts". You can recover them as follows: Double-click to open the "Unused Desktop Shortcuts" folder
Drag the selected items back to your desktop
Close the "Unused Desktop Shortcuts" folder. You can delete this folder if it is empty.
thank u for using fixya
regards,
sivaranjini
Aug 10, 2009 | Toshiba Tecra 730CDT Notebook
My Toshiba satalite freeze on the first screen labeled with windows xp
I can fix it for you. You have to have it repair by a PC technican. I am one . This is a problem with the operating system. A file has been currupted. Where abouts do you live?
Feb 13, 2008 | Computers & Internet
Windows freezing in normal mode model toshiba m45 os win xp
First I would try blowing the fans out with canned air while the system is powered off.
Does Windows freeze during any actions in particular, or just random times? Have you tried restoring Windows from the Recovery CD? If not, I would definitely recommend it, but make sure you backup your data first.
Dec 07, 2007 | Toshiba Satellite A45-S250 Notebook
Laptop 'freezes' after about half an hour of operation
Is the hard drive making a clacking noise, and/or does the mouse freeze only once or freeze and unfreeze a few times before dying completely?
Nov 21, 2007 | Computers & Internet
Computer Freezes During Startup (Urgent!)
Try firstly, on start up keep pressing F8 until a menu comes up. Look for the line that reads 'Start windows with last known good configuration', move cursor to it with the up or down keys as your mouse won't work; and press enter. Hopefully your pwill restart and run as normal. If not you may need your Windows cd.
Jan 03, 2007 | Toshiba Satellite A105 Notebook
HP Pavilion dv1000 Notebook Logo
262 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
