Transformer specs for the i950 printer . I lost the cords for my canaon i950 printer. Need to know what the transformer specs were to get a replacement.
I lost the power cord to my "vintage fiber optic light" and would really like to use it. I don't know the voltage, so I can't even try to use another cord. Any ideas I what I can do?
If it is the type that has a cord, a power transformer and then the unit, look on the area where the power cord plugs into the unit. It ought to have the voltage, milliamps needed and the polarity.
If you have only lost the power cord, it just need to same type of plug.
Dec 11, 2016 | Office Equipment & Supplies
Where can I get a replacement power cord for my Lexmark printer.
Hi
Looking at the setup and spec sheets, the power supply is built in therefore no separate power block (transformer) to worry about. The power cord on the set up sheet looks to be a "Figure 8". Check on the printer itself and if the socket looks like this:
then it almost certainly a standard lead that is used for many electrical appliances as well as computer peripherals, and should be obtainable at most electrical or computer shops. If you ask for a Figure 8 mains cable they should know what you mean but if have a way to take this picture with you - even better !
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 17, 2014 | Lexmark S815 Genesis AllInOne InkJet...
Identifying specs of blown transformer on PCB
I have the same problem, with the same transformer. Did you ever find the specs?
I was thinking of buying the Frigidaire board, connecting to line voltage and measure output voltage.
Jul 09, 2010 | Frigidaire FAC126P1 wall/window Air...
Need power cord tranformer for my computer speaker system. plug on one end other end 3 pin system on othe Transforms 110v down to I guess 12v. not sure
you'll need electrical specs of the transformer (current and polarity) for the speaker system and mechanical connector spec. At the very least a model and number.
Mar 21, 2010 | Audio Players & Recorders
I moved and lost my power cord for my lexmark x7170. Just need another one! Any ideas
Is is just a power cord - they have tons of them at Goodwill, Savers.....I even pick up USB printer cables for $2 (instead pay $25 at Best Buy)
If the cord contains a transformer (black box) - then you will probably have to order one online (for the best deal).
Feb 24, 2010 | Lexmark X7170 All-In-One InkJet Printer
Plug it in and there is no power
Power supply will need to be changed
Jul 09, 2009 | Office Equipment & Supplies
Need transformer for Hobart Cybertig CT300
Hi Steve
my name is Rob
The cyber tig brand covers a lot of ground some of it older than me!
critical questions
do you have a parts list?
can you get from the machine
Model number
Spec number
do you have any drawings?
if these are all no all is not lost.
I can get a transformer custom made. i would need some details from the old unit.
Please let me know.
Regards
Rob Lee
Jan 29, 2009 | Hobart Welders Champion 500433A Factory...
Crown XLS 802 D Amplifier Transformer!
You will need AC to AC converter that will accomodate US to UK mains. Look for power requirements of your amp on name plate and match with available converters online. Make sure power line frequencies match in/out requiremnts
Apr 17, 2008 | Crown XLS 802 D Amplifier
k24674
jasbo
jasbo
Marvin
Marvin
