Question about Dell Dimension™ B110 PC Desktop
CD-Rom I'm having an issue with reading a cd-r. I can access the files from another computer but when I insert the cd into my drive, it shows a blank drive. There are pics that I am trying to access that are obviously on the disk but my system doesn't show any information at all on the disk. Any help would be greatly appreciated.
  • 178 Answers
This happens when you make too many sessions on your disk.
Your computer might not be able to read all the sessions of your disk.
Try to copy your data from a computer which reads it and then burn the thing in your disk after fully erasing it if its rewritable.
Posted on Dec 14, 2007
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
1305.Error reading from file....MoviesG.big How can i fix it?, should i delete it?... thnks
This issue may occur if one of the following conditions are true:
  • There is a configuration issue with the CD-ROM drive.
  • The MDAC (Microsoft Data Access Components) is damaged or is not installed properly.
  • There is an issue with the CD-ROM media. For example, the program CD-ROM is damaged or dirty.
  • Examine the CD-ROM or DVD Disc
  • Clean the Program CD-ROM or DVD
  • Test the CD-ROM or DVD in another Drive
  • Clean the Drive
  • Quit Unnecessary Software
  • Look for Known Issues with the Drive or Recording Software
  • Check for Drive Firmware Updates
  • Make Sure That You Are Using Protected Mode CD-ROM Drivers
  • Enable and Disable UDF Support
  • Reduce Drive Caching
  • Disable Auto-Insert Notification
  • Remove Duplicate Drives]
  • Restart Windows in Safe Mode
  • Clean Boot Your Computer
  • Install the MDAC Update
  • Check for Alternate Installation Locations
if problem persist contact game manufacturer.
Jul 02, 2011 | EA - Electronic Arts Command & Conquer 3:...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Plz help me out with serious problem of cd/dvd drive
it looks like you need an update for your DVD driver (Optiarc drives )
use the lenovo support site to get the latest driver for your notebook,
this should solve your issue.
Sep 06, 2009 | Lenovo 3000 Y410 Notebook
"NTLDR" is missing"
Change your computer's boot sequence. Make sure that your computer's first boot sequence is the CD-ROM Drive.
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.Enter in the following commands
[where X=CD ROM Drive]
Take out the CD ROM and type exit
Jun 13, 2009 | Asrock 775i65GV Motherboard
Can my cd /dvd player write too?
You can also verify the users manual. Mostly you can see some code in the CD-ROM like: DVD-RW= Can write CD and DVD DVD-R= Can only read DVD's CD-R= Can only read cd's. CD-RW- Can write CD's only.
Jun 10, 2009 | Computers & Internet
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Please insert a disk into drive
You can only copy files to a blank disk by using programs like NERO or by using a re-writeable disk like DVD-RW which you can format and use it like a hard drive. You need also burner not an ordinary DVD or CD player.
Aug 07, 2008 | Computers & Internet
Mp3 cds
Insert blank CD into cd-rom, open my computer, open folder containing mp3 files, Drag the mp3 files to the drive letter of the cd-rom drive, double-click drive letter - write files to disc
Mar 11, 2008 | iLO (2 GB) MP3 Player
Dell Dimension™ B110 PC Desktop Logo
64 people viewed this question
Alun Cox
