Question about Craftsman 25cc Gas Line Trimmer
Weedeater gas edger won't start!!!!!!!!!
I bought a sears 2 cycle gas edger in 1987 and it worked great for about 20 years. The gas line split. And at wall mart the had the weedeater 2 cycle gas edger for 149.00. I had so much good luck with the craftsman that this sould last me another 20 years. They look like they were made at the same place.I bought the craftsmen for my wife as she could start it very easy. I bought a second weedeater for my son and his wife last year. Now neather one will start. I can't get a spark to eather one of them. I have since worked on the 22 year old craftsman so i can edge my yard. But it is getting really hard to start.
Is there a spark control moudul on these weedeater edgers????
    Scholar:
  • 138 Answers
Yes, there is a spark module, but it's highly unlikely that two would have a bad module - more than likely, it is your gas mix. it must be fresh for the engine to run. the gas we have today will go bad in about a month and a half. if you happen to live in an area that has E85, forget it. small engines will not run very long, if at all on this junk. in some areas, you can get gas without alcohol, but it can only be used for lawn & garden equipment. it's expensive, but your engines will run
Posted on Sep 24, 2009
I am unable to get the line out of the troybilt weedeater,One side is out but the other is stuck and will not pull out nor can I force it through.p
I had the same issue and was not able to solve it. I went to lowes and purchased the plug-in start module and it works great. The string is still busted
Jun 20, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a sears 2 cycle mini tiller that worked great for the first hour but now won't start.
Do not use pre-mix fuel. Clean carburetor. Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil) .Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
check age of gas. Cannot be more than 30 days old.
Oct 10, 2012 | Craftsman Gas Mini - Tiller/Edger
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I am trying to repair the fuel intake on a featherlite weed eater
replaced fuel lines on sear weedeater and primer button still acts like it is suching against a vacume. push it in and it won`t release. this unit in same as my featherlite carb and tank. What do I look for line are not restricted, but car not drawing fuel?????
Jul 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
My stihl weedeater starts and idles fine but does not get power.
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crack or split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jul 07, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Brand new sears 2 cycle gas trimmer is very very hard to start . When you finally get it started and it runs for a while, it will restart easier.
Do you mean hard to start as in you have to pull and pull to get it started or do you mean hard to start as in tough to pull? If you have to pull and pull then the carb screws (gas and air) need to be adjusted. Start by turning them all the way in and the a turn and a fourth turn out and adjust from there. If you mean just tough to pull, the some newer weedeaters have lots of compression and since they come from the factory this way it can't be changed. It will always be tough to start.
Jun 18, 2009 | Craftsman 25cc Gas Line Trimmer
Weed wacker wont start
You do know my neighbor took her sears craftsman edger in and got a new one after a year. TAKE IT BACK!!!!!!!!
Jun 09, 2009 | Craftsman 25cc Gas Line Trimmer
My weedeater edger over heats and freezes up. it gets very hot, smokes around the spark plug, the spark plug is coverd with soot and it won't start again
Are you using mixed gas? The gas needs to be mixed 50:1
You will have to use 2 cycle oil. If you are using mixed gas, than you can buy a cooler spark plug.
Sounds like the spark plug is not properly gapped.
May 23, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Weedeater fuel line oopsy
I fed the fuel line up through the bottom, attached the filter and pulled it backk towards the hole in the bottom of the tank. I then used a brake adjustment tool to first push the filter back in place (with the line attached) then hold by pressing down on the top of the filter while I hooked up the little plastic clamp.
All that seems to work fine but the weed eater won't idle AT ALL.
May 02, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Craftsman 25cc Gas Line Trimmer Logo
742 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
