Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Do it use mixed gas and what type of oil
Mixed fuel and what type of oil does it take
    President:
  • 2,220 Answers
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Today most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 20, 2009
ST175G, 2 cycle engine, I lost the manual and I cant remember the percentage of the mixing oil and gas. It has been a few years since I did it. Please help. Thank you, Roger
the type of oil to use is 2 stroke oil ( not ordinary engine oil as for cars )and the ratio is 40:1
the engine type is a homelite engine and the ratio can be 40:1 or 50: 1
I prefer to set the ratio as to the smoke produced so if 40:1 produces too much smoke at full rpms , drop it back to 50:1
The correct mix is when there is JUST visible smoke at rpms
definitely no e fuels.
Jun 25, 2016 | Garden
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
What type of gas to use in a craftsman edger 358.773110
FUELING ENGINE This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality 2-cycle air*cooled engine oil. We recommend Craftsman brand oil. Mix gasoline and oil at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline). DO NOT use automotive oil or boat oil. These oils will cause engine damage. When mixing fuel, follow instructions printed on container. Once oil is added to gasoline, shake container momentarily to assure that the fuel is thoroughly mixed. Always read and follow the safety rules relating to fuel before fueling your unit.
Sep 12, 2011 | Craftsman Garden
What petrol mix does it use, and what type of oil
Depends on what type of saw it is some very new ones use 50:1 oil fuel mixture older ones use 25:1 mix and the larger the bore or engine capicity you should probably use a little more oil to protect it, Mose saws will give the oil fuel ratio on the gas cap or in the owners manual
Brad
Aug 01, 2011 | Garden
Does it work with pure (car) petrol. Do I have to mix with oil. What type of oil? How do I mix.
most 2 cycle machines will work with a 50 to 1 ratio, you mix 2 stroke oil with gas, that would be 2.56 ounces of the oil to each gallon of gas, put a gallon of fuel in a gas can, and add the required amount of 2 stroke oil, and shake it up, and use it as necessary!! Good Luck If you find that the machine smokes a little, you can cut back just a hair on the oil added
Not a problem, just a question: What is fuel/oil mix ratio on this unit? What type of oil? Unleaded gas ok, I'm assuming. thnx!
everything i have seen says 40:1 mix. most saw are 50:1 or 40:1. use 2 cycle oil and mixing instructions are on the bottle. unleaded is ok
Nov 13, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
WHAT TYPE OF FUEL, STRAIGHT OR OIL/FUEL MIX & WHAT PROPORTIONS ?
Determine if your engine is a two-stroke or a four-stroke. Check the gas tank on your lawnmower or the owner's manual to determine what type of engine you have.
Read the label of your two-stroke oil. Follow the directions on the package to ensure the right mix.
Measure and pour the gasoline in to the empty gas can.
Add four ounces of two-stroke oil per each gallon of gas.
Replace the cap on the gas can and shake the oil and gas to mix. Add fuel to your engine.
Take care.
Jun 01, 2010 | Garden
I have a techumseh snow blower 5.5 engine. I need to know what type of fuel it needs. It says on the outside something about a 50:1 oil gas mix and lists some types of oils. Where can I get these oils,...
go to your hardware store and ask for some 2 cycle 50:1 oil, mix that with a gallon of gas and you're good to go. Before you mix, make sure that you read the oil container for it's recommendations! You can purchase a small container of oil that is all measured for 1 gallon of gas
Feb 10, 2010 | Garden
What is best oil weight and fuel mix to use
I use 2.3 ounces of 2 cycle oil mixed with 1 gallon of gas in mine and it runs great
Aug 18, 2009 | McCulloch Garden
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
156 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
