Question about GE Refrigerators
Water is leaking under fridge. The pan keeps filling up and overflowing
  • 98 Answers
Hey ...Two things can cause that. That I know of. Depending on the age. There could be a fan under there where the pan is that is not running.
And the coils may be dirty. not letting the heat out like it should. There is one more thing. Is it cooling ok. if not . It's low on freon.
Hope this helps
Ken
Posted on Sep 23, 2009
  • 4,070 Answers
On some models, when the water dispenser is clogged the water will bypass to the drain pan. The water from the defrosted freezer also drips to the pan but it shouldn't fill it under normal conditions. Try to see where the water is coming from.
Posted on Sep 20, 2009
Drain pan in whirlpool side by side refrigerator fills and overflows
do you have water hooked up to the machine?if so check the plastic lines that go to the water valve,i couldn't figure out why there was so much water in pan,all it is is when the fridge defrosts the heater comes on in freezer and melts the ice off of the evaporator coil and the water goes through the drain tube down near compressor to evaporate,i kept looking and stuck my hand in and there was a fine spray of water coming from a pinhole in one of the water lines,the owner never vacuumed
out the coil,so the machine was running hotter than normal,you can try shutting off the water valve that feeds the fridge and see if it stops overfilling,if it does you could have a hole in one of the lines,if there isn't any water hooked up to the fridge check the condenser coil to see if it's clogged with dust,this is how the heat escapes from the machine and the heat is what evaporates the water in the pan,also check the door gaskets,if they're torn or not sealing good warm air will get into the freezer causing ice buildup from warm and cold air mixing and forming ice,like i said the water that goes into the pan is from when the fridge goes into defrost,there's either more ice that's forming from an air leak or water is leaking from the filter line or one of the water lines.good luck with the detective work
Oct 01, 2017 | Whirlpool Refrigerators
I have a frigidaire gallery series side by side and everytime the fridge says the water filter needs to be changed now it leaks a good bit of water from the bottom of the fridge.
There is an O ring that will leak water into the overflow pan under the fridge. I'd clean the pan too to eliminate bad odors. You must shut off the water supply before changing the filter element. There is no shut off valve built into the filter or its housing.
Aug 08, 2015 | Frigidaire Refrigerators
Why does kenmore side by side model 596.50004100 leak water from bottom?
1. there is a condensation pan under refrigerators, pull front bottom grill off & you should see pan. if pan is full it will overflow, pull forward to remove & empty. also check to see if something spilled in bottom of fridge & is running into drain hole into pan. most of the time condensation is so slow that it will evaporate before the pan fills up, but I've had them fill up on me in the past, not too often though.
2. if fridge is equipped with ice maker & clod water dispenser, connections on bottom back side could be leaking ( not likely, unless they have been disturbed).
there is not much else that it could be unless it is not the fridge & is coming from some where else & running under the fridge.
Oct 09, 2014 | Refrigerators
Water in the pan beneath
As long it is not coming out onto the floor then it isk working correct but if it overflows you are getting too much moist into the refrigerator you would need to find that air leak
Mar 24, 2014 | Refrigerators
Water collecting in the pan underneath the fridge.
it should do this but the water should evaporate from the heat from the condenser and compressor,when the machine goes into defrost a heater comes on and melts all the frost off of the coil,the water drains down into the pan where the water will evaporate,when was the last time you cleaned out the condenser coil?remove the front bottom kick panel and check the coil,if it's filled with dust it has to be cleaned out at least once a year especially if you have a cat or dog,then pull out the machine unplug it or shut off the control and remove the bottom back panel,the easiest way to do this is to vac up as much dust as you can with a shop vac,then set it for blow by putting the hose on the other end of the shop vac and blow the dust out of the coil,you can buy a condenser brush that will remove dust thats stuck inside the coil but the shop vac works great,through the condenser this is how the heat escapes out of the machine,also clean off the fan motor in the rear,also there are plastic water lines that come out of the water valve that could be cracked going to the ice maker and water dispenser or the valve itself could be cracked causing this problem or the pan could have a crack in it,very unusual for the pan to overflow,when you're done cleaning it plug it back in,make sure the fan is running fine and have someone fill a cup of water and check the plastic lines coming from the valve to see if it leaks,pull out the pan and check it for cracks,fill it up at the sink and check it,if everything looks good you can shut off the water valve that goes to the fridge for a few days and keep an eye on the pan,like i say it's unusual for the pan to overflow just from the defrost water,if the water is evaporating with the water shut off then you have a crack in one of the water lines going to the ice maker or dispenser
Aug 05, 2012 | Amana ASD2522WRS (251 cu ft) Side by Side...
A stream of water leaks out of the bottom of the fridge at night.
the condensate pan under your fridge has overflowed. this pan catches any condensation from the evaporator coils.
Nov 12, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Whirlpool Defrost pan overflow
check and see if the door to the ice chute is closing all the way, moisture can get in there and cause excessive frost build up also check the location of your defrost thermostat behind the back panel in the freezer, it should be attached to the top of the evap coil. also check your water system and be sure that there are no leaks under the refer dripping into the pan while the unit is cycling for ice fill or dispenser line.
Sep 19, 2009 | Frigidaire FSC23F7D Side by Side...
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
WHERE IS THE WATER COMING FROM UNDER MY FRIDGE?
very odd that there would be an influx of water to that pan, especcially enough to overflow it. a bit of a pain in the butt to remove that pan, try soaking some water out if it. and see if you can see where water coming from, id be willing to bet that the water filter housing right next to it is leaking and happens to be filling your drip pan, did you replace water filter recently?? perhaps its not seated properly.(regardless removing the water filter should stop the leak)
Mar 04, 2008 | Whirlpool GC5SHEXNS Side by Side...
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
