Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Print unable 36 for DCP-165C
It started with a grating noise followed by an error message "Print unable 34". After making sure there's no paper jammed, I restarted and got "Paper Jam" error. I got irritated and actually jammed the feeder (figured it was the error anyway). The I got "Print unable 36".
I followed the disassembling process outlined, and I was able to fix the problem. Thanks a lot!
  • seijukh May 11, 2010
    Here is some great PRINTER solution by Some FIXYA EXPERT.
    Get any kinds of PRINTER solution from bellow.
    » Brother Printer Solution
    » Canon Printer Solution
    » Epson Printer Solution
    » HP Printer Solution
    » Lexmark Printer Solution
    » Xerox Printer Solution
    » Other Printer Solution
    5
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Unable to print 34 (what is it and how to correct)
This means there may be a paper or object like a paper clip inside the printer. Have you just had a paper jam?
Open the unit and inspect for paper or an object.
Follow the directions in the manual regarding saving any unprinted faxes, then disconnect power for ten seconds. Plug the unit back in. It should be working.
Oct 13, 2014 | Brother Office Equipment & Supplies
T632 printer error : 34 short paper. What does that mean? Don't see 34 as a valid error code.
This error message means that the printer has determined that the length of the paper in the source specified on the second line of the display is too short to print the formatted data. For auto-size sensing trays, this error occurs if the guides are not in the correct position.
Please try to do the following
? Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
? Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
? Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
For further assistance, please contact Lexmark Technical Support.
Aug 02, 2011 | Lexmark T632 Laser Printer
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
cenprop@bigpond.com
Apr 08, 2010 | Brother Office Equipment & Supplies
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Paper jam on hpc7280 printer noise from duplexer area NO PAPER JAM
Follow the instructions in this video. If you follow those instructions and still get the message, you may need to replace your printer or the rear door.
May 19, 2009 | HP Photosmart C7280 Printer
Unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
1.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2. If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine...
Thanks.
Dec 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print Unable 34
There might be some paper left in the machine. Check the very edges espacially the left side (seeing from the front).
Another reason could be that the encoder strip isn t in right position or is stained from ink.
Anyway try the first solution first.
If you stll have trouble try to open the printer:
http://www.fixya.com/support/t211210-brother_mfc845cw
and have a close look to the encoder strip + disc (and look out for some paper in the edges... ;-))
Mar 22, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
1,626 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
