Question about Nokia N73 Cellular Phone
After finishing update my Nokia n73 its saying start-up failed how to fix this
    Problem Solver:
  • 16 Answers
Just format the phone using code *#7370# then after formatted change ur profile to general then remove ur mmc card then start the update.
Posted on Sep 21, 2009
    Problem Solver:
  • 8 Answers
Imei:351860018288243 model 3220 rh-37
provider: smart
philippines
can anyone help me with my restriction problem?
My nokia n73 keeps saying it is full but it isnt
Memory low will (possibly) be RAM running low.
I occasionally had it on my N73, but since updating to v4 haven't had the error once (had it regularly on v3, less said about v2 firmware the better).
Type in *#0000# to check the firmware - if its prior to v4, then run a firmware update via the Nokia Software Update.
Jul 12, 2010 | Nokia N73 Cellular Phone
I would like to update Nokia n73 music edition software. May i know the procedure. Thanks in advance.
Hi
For updating your firmaware of Nokia N73
You need to Download The following tools
  1. Nokia Pc Suite
  2. Nokia Software Updater
or else Nokia Ovi Suite
But i Will say the methods using Nokia software Updater
  • Download Nokia pc suite from
http://www.softpedia.com/progDownload/Nokia-PC-Suite-Download-11999.html
  • And Nokia software updater From
http://www.softpedia.com/progDownload/Nokia-Software-Updater-Download-141287.html
Install Nokia pc suite then Nokia software updater
It will ask for your PC to restart
Continue ,then Select Nokia software updater .
Connect your phone
It will Find out the connected phone
Before Proceeding further: A Word of CAUTION:
  • Your phone will be useless when updating failed in the Middle of updating due to System Restarts or Internet Connectin Failure or Cable Disconnection
  • So consider in mind that
U Need
  • An UN interrupted internet connection
  • Do not disconnect the Data cable after full installation of new firmware
  • Computer shall not restart or shutdown while updating
(If any of this failed the phone cannot be recovered )
So method continues.....
after Nokia software updater finds your phone, it will check for new firmware avail for your phone or not ,
\if avail select download and install
Keep in mind the Above words of caution
An advice is that If You feel not good ,then better give it yor nearest Nokia Service centre ,they will install a new firmware for your phone
Hope this will Help You........
May 13, 2010 | Nokia N73 Music Edition Smartphone
During firmware updation due to some reason n73 startup failed now displays white blank screen and not starting
Frim updation does not work Compeletly. Most of the time it stops at 90%. So never try to use firm updation. Give it a try by Fashing.
Mar 22, 2010 | Nokia N73 Cellular Phone
After connecting to nokia software updater&downloading update the program failed to install it
Hi there, first off all i like to say update your N73 from Nokia websites. click the Link your will get the page. But my friend remember it is very very risky. Just follow the important tips first.
A) I given a link which is for USA Nokia N73. Because i don't know your location. So you can go from the first steps. Type in address bar www.nokia.com then select your location. After that below the page you will find software update, just click there then select your handset. You must read the page information. That's very important.
B)Before start update take a backup of your phone.
C) When updating Don't touch or disconnect your data cable.
D) Way of updating your mobile going in dark or off mode. So don't think about restart. It will automatically start after updating.
E) By any reason during updating, if your phone disconnecting for internet or data cable then you lost your all data & the phone previous software also. Then you faced a big problem. That is your phone totally dead. That time only Nokia service center can rescue your phone.
F) I have that bad side experience with my Nokia N73. So i like to say that its really very risky. But if you give it to the Nokia service center then it will take max one day and charges maximum 15 U$ -20 U$.
Now you follow the steps how to updates.
  1. Connect your phone and wait for Windows to install the drivers.
  2. Open Nemesis Service Suite and click “Scan for new device” on the right-upper part of the window
  3. Click on the icon “Phone info”
  4. Click on “Scan”
  5. Change the product code to 0539343 and mark the case “Enable”.
  6. Press “Write”, and your phone’s product code will be changed (you might think that nothing happened, because the phone is still in normal mode, and the changing of the product code only takes a couple of seconds, but don’t worry, the product code changed !).
  7. Close Nemesis Service Suite and run the Nokia Software Update.
  8. Make sure not to touch the cable or the phone while your phone is updating or else you will break it! If you break it then your hand set will be dead & you have to submit in your local nokia service center.
  9. That’s it! When you restart your phone, it should now be the Nokia N73 Music Edition!
Thanks & waiting for your vote. Best of luck.
Feb 13, 2010 | Nokia N73 Cellular Phone
My N73 aint working at all i updated a software and it got hanged now its nt even starting
Dear Ashad , your phone software not done proper Updating. Result is phone software corrupted and dead. Only one solution Just Visit Nokia service center and tell then to install the updated software for your Nokia N73. Problem will solve then. If your handset not on at home you can't fix it by yourself.
Thanks & waiting for your feedback.
Feb 06, 2010 | Nokia N73 Cellular Phone
N73 sim card registration failed
hello sarah_fox,
Please Press [ *#0000# ]
and tell me whats appear
Thank you for using FixYa.
Apr 07, 2009 | Nokia N73 Cellular Phone
N 73 Stuck.
If you could not complete your firmware installation,Please re install your phone with the same firmware using Nokia Software updater.
Feb 13, 2009 | Nokia N73 Cellular Phone
N73 Software update 4.0839.42.2.1 failed
remove the cable and before update make a backup then download the nokia software updater from here
http://europe.nokia.com/get-support-and-software/download-software/device-software-update# then wait about 15 minutes thats what the softare tells after that your phone is updated if
Dec 21, 2008 | Nokia N73 Cellular Phone
Nokia n73 problem
untill unless it will get disconnect before finish its update..it ll affect ur parent board of ur mob...so better check ur main board whether workin or not..after tat ll go for further
Aug 26, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
