Test it. Put a bowl of water in the microwave and place a small (1 or 2 sq inches) piece of aluminum fold next to it. Power the microwave on for 2 or 3 seconds. If the foil sparks, the oven is creating microwaves and should be functioning correctly. If nothing happens to the foil, then you have no microwaves being generated by the klystron tube.
You can spend 80 to 150 dollars to have the oven checked and repaired or you can find another on Craig's List in your community for less than 100 dollars. Alternately, you can replace with a new one for whatever you are able to spend (from 95 to 600 dollars).
I mistakenly used the "cook time" instead of timer, and cooked for 22 minutes with an...
(More)
I mistakenly used the "cook time" instead of timer, and cooked for 22 minutes with an empty oven. The display went totally blank and the mw will not work now.
If I use the High setting, it trips my fuse box. I seem to need a lower setting (5) for recipes that...
(More)
If I use the High setting, it trips my fuse box. I seem to need a lower setting (5) for recipes that call for High, since they otherwise cook in half the time on High, or overcook..
