Question about Toshiba Satellite A105-S4074 Notebook
Using s video output
I plugged the s video into my television to use as monitor but my tv says no signal. I tried restarting the laptop with the svideo plugged in and that did not work. I can find any specific instructions on how to do this (I thought the laptop would automatically send the signal like it does with the standard monitor plug.
  • rlyle Dec 14, 2007
    Thanks for your help. I did see and try the FN+F5 display function, but I did not push it simultaneously four times. That did. Thanks for the help.
  • Anonymous Feb 25, 2009
    Need assistance setting up my tv to my laptop.
    Brigadier General:
  • 6,966 Answers
Two things you can try:
1. You need to Activate your TV OUT feature in the Monitor setting of your display properties and select Clone so as to mirror what you see in your laptop's display in your TV. As you posted, the S cable must already be inserted before powering up your laptop; and/or
2. You may need to lower your laptops screen resolution. Most but not all TV units have lower resolution capacity than monitors. Perhaps try with the lowest possible setting (800X600) and when it shows on your TV, slowly increase till it blanks out again. pressing escape would revert you back to last setting that worked. Additionally you may need to lower likewise your laptop's Color Quality setting and/or the Screen Refresh rate.
Hope that this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 14, 2007
  • Louie  Role
    Louie Role Dec 14, 2007
    Hi again,
    Additionally -
    On Toshiba laptops you need to press the FN+F5 simultaneously four times to get the TV-Out setting. In some versions of Toshiba, it is Fn+F7.
How solve in my POLYCOM VSX 6000 showing error "unsupported signal adjust your PC output"
Try using the S-Video output and then try using the VGA output from the VSX 6000 unit. The unit can be fixed to output from either as the first monitor output (you may have the dual monitor option enabled). If this does not work the resolution of the TV might be HD, the output of your VSX 6000 is Standard Definition. You will need a monitor that accepts standard definition. If this does not work, I would reboot your VSX 6000 and try again. David
May 17, 2014 | Polycom VSX 6000 (220022222001) Video...
Trying to connect computer to LCD TV and get no signal?
If you are trying to connect computer to LCD TV and get no signal, as a first thing do the following:
Double check cable and connection. If possible test different connections. Try using VGA, DVI or AV, depending on availability on computer and TV.
Ensure that Video drivers on computer are properly installed, and that the video adapter is working properly.
If you are using a laptop, ensure that you do not need to use a function button to enable the external display, this is pretty common on laptops.
If you are using a desktop, go to display properties, find the windows where you get the picture of two monitors, and ensure that both monitors are enabled.
On Vista try also using the 'Identify Monitor' button on Top. It is located on same properties panel as the two monitor, the main Display Property windows. From the same window you can also modify display resolution, as explained later.
If still no luck, then it may be a problem of synchronization between TV and computer, in that case try the following.
  1. Turn off TV.
  2. Disconnect TV power cord.
  3. Restart computer.
  4. With Computer already on, plug back and restart TV.
....If that does not work.
On computer, go to display properties.
First try changing computer resolution. The TV max resolution may not be available on computer. In that case try lowering down to the smallest 16:9 resolution available on computer graphic settings (usually LCD TVs are 16:9), and if that does not work, set resolution to 800x600, just to test (picture proportion will be distorted, or you get squared box on a 16:9 TV).
If that does not work, open Display Properties. In Display Properties access Advanced, and then Monitor settings (XP). On Vista choose Personalize in control panel, then Display Settings, and go straight to Monitor Settings, in there again go to Advanced.
Under the advanced monitor settings you will find a tab called monitor, in there you find the monitor frequency. Try setting this to 50Hz, if that does not work try 100 HZ, that is the output frequency of your TV. If you get unsupported frequency, revert value to normal.
on Jan 17, 2010 | Televison & Video
How do I connect a laptop to this tv?
It will depend on the laptop's available external video ports. You can connect a VGA cable from some laptops to the VGA port on the TV. Then plug in a 3.5 mm audio cable from the headphone jack to the PC audio in port. (The audio connection is optional. You could continue using the laptop's speakers.)
Make the connections with the TV and the laptop off. You may need to enter the BIOS to enable the external video port. (It can be turned off to save power. The BIOS is accessed on boot by pressing a key (Esc, F1, Del) noted on the splash screen. For Win8 machines, you'll need to do a special restart.) Then turn on the TV before turning on the computer. The TV monitor should be automatically recognized for resolution and refresh rate. Next, if you have a Windows system, right click on the desktop (pick a spot with no icons or running programs). Click on Screen Resolution (or perhaps Graphics Properties, depending on the OS). Set the monitor to duplicate the screens or send data only to the TV screen.
I'm not sure if the HDMI ports will understand a computer signal. (Not all TVs can interpret the computer's HDMI signal; it is different than that of other set top boxes.) You can try the following connections.
If your laptop has a DVI output, use a DVI to HDMI cable (or adapter) to connect to the TV. Then connect the HDMI cable to HDMI 1 and use the PC audio connection as above.
For an HDMI output, use an HDMI cable. (You will still need the audio cable unless you can reset the audio signal to output on the HDMI port. Go to the Control Panel and then the Hardware and Sounds section. Under Sound, select Manage audio devices. Then in the Playback tab, make the HDMI audio the default.) For Display Port or Thunderbolt outputs on the laptop, you will need a DP to HDMI adapter.
If the HDMI port doesn't understand the computer signal, you'll need to use a converter to go from the computer's output to component video or to VGA. Then connect the converter's output to the appropriate port on the TV.
I hope this helps.
(To access the Control Panel in Windows 7 and earlier versions, click Start and then find the Control Panel in the right hand column. For Windows 8, press the Windows key + X (or access the Charms menu on the right-hand side (Win+C) and choose Settings). Then select the Control Panel.)
Oct 13, 2013 | Haier L42B1180 - 42 1080p LCD HDTV
We have a bang and olufsen beovision 7 40 inch tv. when we try to connect our laptop through vga port the tv appears blank without any display, tried connecting the laptop through dvi port also. The...
First, try setting your monitor refresh rate at 60Hz using a known-working monitor. (The VGA input of the Beovision 7 is recommended for 60Hz refresh rate). If this fails to produce output from the Beovision 7, it is very likely, your video driver's resolution is set too high for the Beovision 7 to display signal. If you are using the Beovision 7 as your primary monitor, first connect a known-working monitor to the computer and reduce the resolution to 1024x768. Once you have changed the resolution, try connecting the Beovision 7. If you get video signal, increase the resolution incrementally until you find the maximum resolution the Beovision 7 will handle.
IF YOU ARE USING THE BEOVISION 7 AS A SECONDARY MONITOR USING EXTENDED DESKTOP, reduce the resolution on Monitor 2 output to 1024x768. If video appears on the Beovision 7 at that resolution, incrementally increase the Monitor 2 resolution until you find the maximum resolution the Beovision 7 will accept as a secondary monitor.
Jul 14, 2011 | Televison & Video
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Connecting and recording camera with s video output on 1221 tx
The cam setup you're trying in your surgery is similar to the type I often setup in Dental operatories for there intra-oral cameras.
You need an tuner, if your external has S-Video port, you can simply plug into it and use windows media center or the cards software(if it came seperate) to record from the s-video feed.
Then you can hook the S-Video output from the laptop to the TV monitor in question and run the laptop in mirrored mode to show the same image on both screens.
Hope this helps,
May 26, 2009 | HP Pavilion dv6000z Notebook
How to connect acer laptop to philips tv to use tv as monitor
If your TV has a VGA input you can connect the laptop using a standard monitor cable. If the TV has component video inputs, you can get an adapter cable with a VGA plug on one end and the appropriate RCA plugs on the other.
Without these inputs, you can't connect the laptop directly. You will need a converter to switch from the computer's VGA output to a standard video signal to feed to the TV. Here is a website with a sample converter. (I don't know this site. It's just one I picked from a Google search as an example.)
Mar 23, 2009 | Philips Televison & Video
I want to use plasma tv as external monitor
Your laptop is not set to enable the external video output.
Most likely, your laptop has a key that says "RGB/LCD" or something similar on it. This key cycles through the various video output options, enabling the laptop's LCD, the external RGB output, or both simultaneously. Most laptops require you to hold down the function key ("FN") when pressing the "RGB/LCD" key to cycle through the options.
Mar 04, 2008 | ASUS A6U Notebook
No component video output
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Jan 23, 2008 | Yamaha HTR-6030 Receiver
No Display
for the HD15 connection you need to set your TV to PC mode
the only thing I can think that you may be doing wrong is that you need to "ACTIVATE" the external outputs on the laptop,as they are not on by default.
To switch video output mode  LCD / CRT (monitor/PC mode) /TV mode plus some dual modes LCD + CRT / LCD + TV
I have found that the overlays used for video playback do not work in the dual modes,  (and I have found that CRT monitor mode is best for connecting to a large TV)
so switch your TV to PC input,  connect your HD15 cable and SWITCH output mode on your laptop (usually Fn F5) press until you get an output,
you will also need to connect audio, so get a phono -> 3.5mm jack plug and plug that in also, and you are ready to rock and roll
Oct 11, 2007 | Hitachi CMP205SXU 25 in. Plasma Television
Toshiba Satellite A105-S4074 Notebook Logo
271 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
