Question about JEEP Wrangler Unlimited Toy Vehicle
Jeep BA10-5 transmission clutch replacement
I replaced the clutch, throwout bearing/slave cylinder, and master cylinder in my '87 Wrangler, and now it won't go into gear. I was sure to bleed the system properly (several times, using several methods), and I have good pedal pressure, but still no release.
Is it possible that the retaining ******** the throwout bearing didn't break? The new master cylinder isn't the same brand as the old one (the old one is a Girling, this new one is from CarQuest), but all dimensions and capacities appear to be the same. I don't know what to do, and Jeepin' season is almost over! Please help!
SOURCE: Wrangler 2000 clutch
the slave cylinder needs to be level. get a small bubble level and jack up the front or rear appropriately till its level.
Posted on Aug 21, 2008
  • 33 Answers
SOURCE: 1994 Jeep Wrangler 4cyl - Bleeding slave cylinder
This is not a bleeder hole, this is a weep hole like in a water pump to see when there is seepage past the seals.
Bench bleed the system. With the master cyl. line and slave cyl assembled, place the master cylinder in a vise, fill the master cyllinder. actuate the slave cylinder back and forth lower than the master cyl. This will allow the air to escape upwards back into and out of the master cyl.
Once bled the system can be installed.
Good Luck
Posted on Oct 02, 2008
  • 6982 Answers
SOURCE: 1990 wrangler all new slave cylinder, pressure
If you have had the flywheel cut, have a clutch with a different release height (different finger or diaphram design & height) or a remanufactured pressure plate, or all of the above, you may run into this problem.
Small differences there translate to a large difference at the pedal. On linkage type designs, there were several options including longer/shorter throwout bearing or adjustable fork pivot ball. Hydraulic systems should compensate somewhat, but if you are beyond the travel of the slave cyl, I'm not sure there is anything you can do from the outside. I would check that there are no air leaks. If you have an external slave cylinder you may be able to make a slightly longer rod that connects the slave to the clutch fork. I really can't think of anything else to do at this point.
Hope this helps a bit.
Posted on Apr 19, 2009
  • 61 Answers
SOURCE: replaced master and slave cylinders for clutch and
Some companies stopped putting the bleeder screws into the slave cylinders. The boss is still there and is threaded but there is no hole in the bottom. You can put a hole in if you wish but they did away with that type because people were having problems bleeding the system. To bleed this style of slave cylinder: 1.Remove the plug from the end of the cylinder where the line goes in. 2. Remove the straps holding the cylinder in. 3. Hold at a 45 degree angle. 3. Pour fluid into the cylinder with the cylinder extended. 4.Slighltly work the cylinder in and out to work any exess air out. Still holding at a 45 angle. 5.Make sure master cylinder has fluid in it. 6. Insert rubber seal and line into slave cylinder while still holding at a 45. 7. Insert roll pin into slave just over half way. This way if you have to remove it you can still get it back out. It probably will not come out if you put it in all the way because they were designed not to come out. You can snip off the straps that hold the piston back. 8. Push the piston back into the slave. This will force any air out that is in the cylinder. 9. Bold slave back on. 10. Pump clutch until it feels right. Make sure there is enough fluid in the resevoir otherwise you will force air into the line. If it dont feel right repeat this process. When all feels right in the petal finish putting the roll pin into the slave cylinder. Good luck. You may need 10 hands!
Posted on Jan 30, 2010
SOURCE: 1991 Jeep Wrangler - Clutch pedal has lost pressure
yo it could just be out of fluid!
Posted on Apr 22, 2010
1995 Jeep Wrangler Manual Trans issue.
good job but....you forgot to say what the problem is???
Feb 15, 2018 | Cars & Trucks
I can't shift into any gear! I press the clutch Pedal and there is nothing, no response!
First place you need to look is at the clutch master cylinder on the firewall next to the brake MC. Ifg it's empty then re-fill it and s5tart to look for a leak. It is a sealed system exactly like your brake,therefore any fluid loss indicates a leak. Check on the firewall under the master, where the clutch pedal rod goes into the cylinder under the dashboard (inside the car). Check the line to the slave unit and the slave. It helps to have someone pump the clutch pedal to make any leak more obvious. If you find the leak, replace the part that is leaking. If it appears not to be leaking, replace the master as it can internally bypass and not build pressure.
Bleed valve is located on the slave. Bleed as you would a brake.
Some slave units are part of the throwout bearing...if so, to replace it, the transmission needs to be removed. but bleed valve should be on a line right near the pressure line going into the bellhousing.
Sep 23, 2010 | 1993 Jeep Wrangler
Clutch pedal is going to the floor. about 2 mos ago replaced the master cylinder bled the system worked good now its doing the same thing. if i bleed the system it works good again for a day or so. dont...
i dont think its bearing problem.Did you fit a [new] master cyclinder,if you did then its the [slave ]cyclinder .,its a pressure problem not a bearing problem.adrian,,,,
Aug 04, 2010 | 1992 Jeep Wrangler
Slave cylinder leaks
Remove the bolts holding the slave cylinder to the transmission. Disconnect the hydraulic hose. Reconnect hydraulic hose to new slave cylinder, and install the slave cylinder in it's original position.
Now proceed to bleed the line through the slave cylinder until a solid stream of fluid comes through, and the pedal pressure becomes firm.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 10, 2010 | 1991 Jeep Wrangler
Cant switch the gears clutch goes all the way to the floor line extreamly loose
since these are a hydraulic system, the level in the master cylinder needs to be checked. If it is empty, use dot 3 brake fluid to refill. Once it begins to work(you will need to pump it to regain the pedal)the 2 components need to be inspected for leaks and rebuilt or replaced as is necessary. If not, this will happen again. You have 2 components; the cltch master cylinder and the slave cylinder. The master is under the hood and the slave is at the side of the transmission. Pull the boot back on the slave cylinder and if fluid leaks out, rebuild or replace.
Mar 02, 2010 | 1992 BMW 3 Series
Cant put my 98 Hombre in gear.
There are 4 parts to this system. First is the clutch master cylinder, second is the slave cylinder, third is the clutch throwout bearing, and last is the clutch pressure plate. These are all the parts that can be the issue. The master cylinder is the part that pumps the fluid to the slave cylinder, which pushes on the linkage to the throwout bearing, which pushes on the fingers on the clutch pressure plate, releasing the clutch. If you drained the fluid out, first you need to make sure that all the AIR is out of the system. It's just like brakes, it will not pump if it has air in it. The hydraulic portion of the system rarely gives problems, so here's a question. How old is the clutch in your truck? If it's over 100,000 mi, then you should start suspecting the throwout bearing. Did the truck make any groaning noises when you pressed the clutch recently, and then perhaps it stopped on its own? These are signs of throwout bearings going out. Here's the bit of troubleshooting that you need. go under your truck, and find where the slave cylinder attaches and pushes on the linkage that goes into the bell housing on the transmission. Feel this linkage; it should have very limited to no movement. if it moves significantly, then your throwout bearing went out, and you will need to replace your clutch and throwout bearing. If not, then it's the hydraulic portion of the brakes, and you'll have to troubleshoot between air in the system, master cylinder failure, or slave cylinder failure.
Feb 15, 2010 | 1998 Isuzu Hombre
91jeep clutch quick pedal loss, barely shifts
Look inside the vehicle at the firewall where the clutch pedal rod goes into the master cylinder. See if there is fluid running down the inside firewall. Next look at the bottom of the bellhousing to see if fluid has been coming out of it. That will tell you if it's the master or slave cylinder. Most likely it is the slave leaking inside the transmission bellhousing.
Jun 07, 2009 | 1991 Jeep Wrangler
93 jeep wrangler stuck in second gear
If your clutch is operating properly, the problem is inside the transmission, either shift forks or lost adjustment on rails. You may have damaged the brass synchro gears by not taking care of this right away. First though, make sure the clutch is releasing, check for internal bypassing ,leaks and slave cylinder operating properly (some slaves are part of throwout bearing and cannot be serviced unless trans is removed)
Jun 05, 2009 | 1995 Jeep Wrangler
I have just replaced the clutch and throwout bearing and no the jeep won't move or even feel like it wants to move. When I push in the clutch it is very soft as well. please help. it is a 1983 cj7 with the...
Sounds like the clutch disc it sticking on the input shaft, or you don't have something correctly aligned in the clutch pressure plate. Or possibly the throwout bearing sticking.
Jun 04, 2009 | 1983 Jeep CJ7
JEEP Wrangler Unlimited Toy Vehicle Logo
342 people viewed this question
Top Jeep Toys Experts
Glenn Smart
Glenn Smart
Lawrence Oravetz
ray gallant
Are you a Jeep Toy Expert? Answer questions, earn points and help others
