Question about HP OmniBook XE2 Notebook
I just got an HP XE2 with no HDD or RAM. I installed both, and hooked up to power supply, and nothing happens when I power it on aside from the battery and power-on lights coming on. I don't know if I have been ripped off, the seller said it should boot to bios, and it's not. Any suggestions?
    Problem Solver:
  • 10 Answers
Check the Hdd !
Could be a graphics card .
Posted on Sep 20, 2009
Where do i find manual for asus z92m ?
Remove the power supply, remove the battery, remove the RAM and remove the hdd.
Plug in the power supply and press the power button, it should complain as there is no RAM or hdd. Unplug the power supply, replace the hdd and RAM then power it up and press power on.
Jul 29, 2014 | ASUS Z92M Notebook
Dv9920us motherboard check
Remove the power supply, battery, hard drive and RAM. Connect the power supply on its own and press power on. If it now goes to the first screen, add the RAM and then the hard drive. If it did nothing, I would suspect the GPU has unsoldered itself from the motherboard due to overheating.
Dec 26, 2013 | HP Pavilion dv9000z Notebook
HP xw4400 workstation wont boot/start if RAM are inserted.
If you are increasing the RAM from 1Gb to 2Gb then the RAM maybe incompatible. Try using a RAM module as the original make and speed.
Try installing one RAM module at a time to see if one of the RAM modules is faulty.
Removing the RAM will give a POST error code of no RAM or faulty RAM.
Feb 25, 2013 | HP xw4400 Workstation - 1 x Intel Core 2...
I have a asus p4p800-vm motherboard I have everthing hooked up right the front panel wires power from the processor and power supply led lights hdd reset everthing but when I plug the computer up nothing...
Hi, maybe you should download a manual.
From here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800VM/#download
Just to check you have connected everything right.
First select your operating system.
Select manual and click on global for download.
The file has to be unziped before you can read it.
Have you installed the ram module and cpu correct ??
If you have installed a wrong type of ram it will not boot at all.
Does it makes any beep sound ??
Is the powersupply ok ??
If you are useing the onboard graphic check for loose connections.
Check with the manual that all connections are in order.
Aug 28, 2011 | ASUS P4P800-VM Motherboard
When I push the power button nothing happens, no lights, no fan, no anything.
Hello
Thank you for using FixYa. Try these solutions
  • remove ram, and restart. any beeps?
  • Remove HDD and restart, any beeps or messages?
  • Has the unit had a powersurge?
  • Can you check to see if there voltage coming out of the power supply unit?
  • Make sure the DC jack on the laptop is firm - if broken they tend to be loose.
Hope this of some help
Thanks
Richard
Nov 17, 2009 | HP Pavilion ze4547wm Notebook
21/10/09 Hallo. Re.: hp Omnibook XE2. Upgrade hard disk drive 20 GB or 30 Gb. I would like to know if some one has installed a 20 GB or 32GB hdd and if he has any problems with that. I would like also to...
the HDD best to use is an SSD.
the HDD was a standard, 2.5? PATA drive for laptops
why would you want such a small drive, they dont make them now. (40 smallest?) new.
this PC is not supported by HP now, its too old a Pentium III no less.
why would 20gb be and upgrade.?? 10 now? omg , it is 10GB...then... and worse its PATA (IDE) harddrive.
its 17 years old now, most are in the recycle bin,
it came with windows 95 or 98, (hopeless that OS)
the laptop has zero value now, so is putting a new
$50 to 100 dollar drive,is wise,?
what if there are more problems, (endless when that old)
you can not use modern, SATA drive (
just 2.5" PATA (IDE) (pata is wide parallel interface with wide ribbon cable)
here are some
http://www.pricewatch.com/price/hard_removable_drives/notebook_40gb
Jul 18, 2017 | HP 80GB NOTEBOOK HARD DRIVE KIT FOR HP...
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Nothing happens when I press the power button. No
What about the power supply? I bet it's supply's issue. Otherwise make sure that PWR button wires are connected properly and to the correct terminals of the motherboard
Jun 29, 2009 | Intel D915GAG Socket 775 Motherboard -...
HP Pavilion DV notebook wont boot up
First of all, if you are getting 1 short and 2 long beeps, the graphic card of the Notebook might have failed. Get the Notebook repaired by HP if under warranty.
However, if your Notebook is installed with AMD processor, it is having a known issue and can get it repaire for free if purchased in US and the related information is available from the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
I am sure that this information helps...
Aug 10, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Won't boot or start, fans and leds work
Are you hearing any beeps when you start it up?
Dec 17, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
HP OmniBook XE2 Notebook Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
