Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Refrigerator with automatic The ice melts and leaks out the door?
  • 6 Answers
Same problem with my unit. The plastic tray seems to warp over time and the water drips out of the tray prior to freezing into the cubes. I was able to purchase a replacement tray online. I also discovered a hidden reset button under the right side where the ice tray motor assembly is located. This button had to be pressed in order to get it to cycle through again after replacing the plastic tray. We'll see if this solves the problem of water spillage all over the interior of the freezer!
Posted on Sep 22, 2009
The ice maker makes ice and fills the ice bin but every few days the ice melts and creates a frozen ice scicle path to the lower tray and all the ice has melted and frozen again below the ice maker.
The problem with the ice melting points toward a cooling problem in the freezer. This could be caused by several different problems. Dirty condenser coils below the refrigerator could be contributing to this problem. I recommend checking and cleaning these coils if necessary.
Check the door seal on your freezer. A leak through the freezer door seal may be allowing warm air to enter the freezer and melt the ice.
Make sure that your temperature control is set properly.
If these tips do not help resolve the problem, it is likely that you have a component failure or a sealed system problem. The thermostat could be bad. You could have a condenser or evaporator fan problem. You could also have a defrost system failure that is causing your cooling problem. A weak compressor would also cause this symptom.
Jan 17, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Ice melts in freezer
check your inner box liner for cracks also your door seal's you have a air leak
Jan 13, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE side by side refrigerator with automatic ice - ice clumping
Most likely happening during defrost. Replace defrost thermostat
Nov 17, 2017 | GE Refrigerators
I have a side by side refrigerator, automatic ice maker freezes.
What is happening is a partial melting and refreezing. Make sure the ice compartment door is kept closed.
Nov 19, 2009 | Refrigerators
The freezer door was ajar overnight and now the icemaker is leaking water
chances are alot of the ice melted overnight. remove all of the ice cubes, dry everything out and then wait a full 24 hours for the icemaker to produce ice cubes.
Aug 28, 2009 | Kenmore 21.7 cu. ft. Side-by-Side...
Small amount of water leaks from the front of my Samsung R2630SH.
I found out that there is a plastic panel that cools three draws inside the refrigerator. Behind the plastic panel there is an evaporator (coolant childer) that catches the condensation of repeatedly opening and closing the refrigerator door that turns into thick ice. Because of condensation, ice buildup in such a way that the ice pushes the middle draw out causing the door to open. In turn depending on how long the door stays open, melts the ice and the water leaks under the bottom draw out on either side of the front refrigerator door. Also, there is a drain plug that is also iced closed. To solve that problems, the unplug the refrig, put towel under the refrig, removed the panel (unplugging the wires and removing screws) and took a hair blow dryer to melt the ice. Oh, by the way, I used to blow dryer to melt the ice from the panel before I could remove the panel. That job took all day. I removed all the ice and reassembled the panel and replace the drawers. To my amazing, no more leaks and the water dispenser worked for two days and quit. I believed the water tank (plastic container in front of the panel has frooze again. By the way the ice maker did not work after removing the ice.
Aug 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
Why is my refrigerator leaking water inside
It sounds like the flap in the door for the ice despenser is missing or is sticking open. The room temperature will lower the temp in the ice bucket enough to partially melt that ice, OR cause a LOT of condensation that may freeze or re-freeze.
Aug 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Water under the crisper bins in the refrigerator -
Replace the door seal on the freezer. When they go bad, outside air leaks into the freezer and when it kicks into automatic defrost, the ice crystals melt and run down the back of the refrigerator. The oldar models had a drain under the crispers that drained into a pan near the condensor coils. It was a heat source that evaporated the water. Some brainstorm decided they weren't necessary.
Feb 13, 2009 | Whirlpool Refrigerators
Ice melts and leaks out of the front of through the door Ice dispenser
sounds like a bad fan motor.when you open the freezer,can you hear a motor running or not?
Jan 14, 2008 | Whirlpool GS6NBEXR Side by Side...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
113 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
