Question about Cycling
I have just bought a Giant Expression and need a 3 spd manual
Just need a Shimano Nexus technicla sheet
  • 484 Answers
This is the Shimano tech sheet page. You can select the part number in question. The Shimano reference material is well detailed and diagrammed.
Hope this helps out,
matt
Posted on Sep 20, 2009
Testimonial: "Prompt reply - many thanks"
Shimano Service Manual
What sort of hub is it? The one that runs in oil is the Alfine - the others are greased, in my experience, although there is an dealer-approved means of refreshing the grease in a Nexus hub by dunking the internals into oil.
The Alfine 11 speed needs 25cc of Shimano SG-5700 oil assuming all the old oil has been drained first. This is according to a Koga Miyata manual for a bike that uses this hub.
May 20, 2013 | Shimano Internal Gear Hub Maintenance Oil...
Giant terrago manual
how do I Remove a shimano crank from a giant terrago MTB? On a normal crank puller the small thread is 12 MM diameter, but on this bike the interior thread of the crank itself only fits on 10MM
Apr 02, 2012 | Giant Terrago Disc
I require an instruction manual on how to maintain and set the gears and brakes on the shimano alivio system which is on a giant strata 2010 mountain bike
Below is a link to the tech docs for the Shimano Alivio system look for the specfic componet you would like to adjust. The links with SI are the Service instructions. EV are the parts lists.
Shimano Alivio System info
Hope this helps.
Zeppelinx12
Mar 16, 2011 | Shimano Cycling
One shoe won't snap into spd pedal
SPD hold on to cleats with a spring loaded action. This is normally adjusted with an allen key. Check that this is not screwed in so tight that action is locked up. If you don't have adjustment instructions go to shimano.com and download. You should be able to check for movement by pushing against spring clip with screwdriver (saves the fingers but mind it doesn't slip). If no movement also check for foreign body in pivot of clip. If all OK check for position of cleat in shoe. Make sure mount position is same as other shoe.
Dec 06, 2009 | Shimano M520 Spd Pedals
How to assemble the shimano nexus three speed cable to the nexus hub? Looks like you just push on and tighten the screw , seems to simple. Need someone else to advise me. thanks
Although i have not worked on a Nexus hub, Shimano's tech sheet page has your info. The Nexus drivetrain is found on the fourth category on the left (Comfort), and the hubs are 2/3 of the way down the page under "SG Internally Geared Hubs". i was not sure which one was yours (there are quite a few!), so i figured it best to just pass on the site to you.
Hope this helps,
matt
Sep 17, 2009 | Shimano Cycling
I need a manual for a Shimano nexus 3-speed hub installation.
http://techdocs.shimano.com/techdocs/blevel.jsp?FOLDER%3C%3Efolder_id=2534374302052334&ASSORTMENT%3C%3East_id=1408474395181679&bmUID=1248577311531
scroll down to Nexus
Jul 25, 2009 | Cycling
I have Shimano Ultegra Flight Deck 20(?) Speed gears on my Giant Bicycle. Do you have a manual for them as I am new to riding and am trying to learn how they work? Thank you
Go to http://www.shimanoservicecentre.co.uk/ and click on Spares and Support tab at top of page. Download service sheets and assembly diagrams.
Apr 20, 2009 | Cycling
Cycling Logo
106 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
