What kind of antenna do we need to recieve free to air t.v.
    Scholar:
  • 64 Answers
If this is a TV for the house you will need a rooftop aerial, may I suggest a high gain aerial which is taller and gives you a better signal.
You can obtain these from an aerial installer. He will come and put one up for £100
Posted on Sep 20, 2009
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
I have a Sony KDL-V32XBR1. The turner seems to be having issues. If I scan for channels I only find a few but my other flat panel receives a full range of channel.
U are using a antenna to do a recieving for a Free AIR DTV incomming braoadcasting tv signal channels siganal?Yes.U are using two different tv antennas signals wright?The Sony one just require a stronger and a better antenna signal,not all flat LCD or Plama tvs recieve the same strenghth signals.Some tvs design require a strong or a very strong signals strenght to get all the tv Free AIR DTV braoadcasting tv channels.Buy a better tv antenna design like a Digital amtenna will solved this problems for the Sony tv.
Sep 11, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have the converter box i have a plasma samsoung do i nstill need a antenna
Yes,u need a good antena,like a digital antena or a roof antena to recieve good free air DTV signal.U don't need a converter box,because ur tv is a digital tv.
May 04, 2010 | Samsung LN32A330 32 in. LCD TV
My phone is almost dead as it is not receiving singal. kindly advice what to do
Analyse why it is not recieving signals.Assumimg that the reason for not recieving the signal is either the problem with the software of your phone or the antenna of your phone is damaged. So i suggest you to go to your nearest Nokia Care Center & either upgrade the software or replace the antenna if damaged.If your phone is within the warranty period then you can replace the antenna free of cost only if it is damaged naturally.
Feb 25, 2010 | Nokia 6270 Cellular Phone
How to recieve over the air channels on my vizio V032E. I tried to set the source to Antenna and tried to tune it but it wont find any channels. Do I need external antenna to recieve these?
No.You might not have a reliable service provider or you might just be in a area in which t.v. signals are hard and or impossilbe to recive.You might also have the cable box,or just cables,mixed up.Hope it helped.
Oct 08, 2009 | Vizio L32 32 in. LCD HDTV
HDTV
Only a HDTV.
HDTV = An ATSC HD television (2004 or later) + a HDTV Signal ( Any out door antenna, Cable or DSS)
Please give is a good rating.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Televison & Video
Yamaha htr 5240 receiver, need fm antenna adapter
this is your manual http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5230.pdf
this is the 300 ohm adapter you need from radio shack and just install some small gauge speaker wire to it. or just splice the one that came with your receiver.
http://www.radioshack.com/product/index.jsp?productId=2062054
Feb 26, 2009 | Yamaha HTR-5230 Receiver
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Getting out, but not recieving well...
Initially pls check the grounding of both the antennas and/or their mounts. Thereafter, an SWR check/reading would also be good as it will not only tell you how efficient your antenna is in transmit but likewise in receive.
Additionally, a two (2) antenna set-up (twin tracker) is directional and therefore would have blind spots on either sides and being on a truck (especially with load/trailer) probably even at the back.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 29, 2008 | Radio Communications
Televison & Video Logo
Top Televison & Video Experts
