Question about Nextar MA933A MP3 Player
Mp3 player will not conect to computer
My nextar will not connect to my computer
    President:
  • 803 Answers
1. Go to the Windows Desktop, click on the "Start" button, and then click "Run" or "Start Search" if you are using the Windows Vista operating system.
2. Type the following text into the text box:
3. "devmgmt.msc" Click OK.
4. Select your computer when the Device Manager window opens, and then select "Action" from the options at the top of the window.
5. Choose the "Scan for hardware changes" option from the drop down menu that appears.
6. Insert any USB device such as a mouse or flash drive into the USB port in question. Now simply check the USB device to see whether it is working in order to test the port.
Posted on Nov 03, 2009
ChadL777
  • 69 Answers
SOURCE: nextar Mp3 player problem
Hmmm...my only thought is to check the extension on the music files you are sending and make sure they are .mp3 format. If the files are a different format that might explain why your player is not seeing them but your computer is.
Posted on Dec 29, 2007
  • 9 Answers
SOURCE: MA166 MP3 Player not recognizing..Windows XP
See the last posted solution, and the model number is not what you quoted, but MA566.
Posted on Oct 04, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Formated nextar ma933 mp3 player
That player is officially toast. There is no recovery software or firmware upgrades for that device - once the key system file is delted, it cannot be recovered.
Posted on Feb 05, 2009
truekleen1
  • 46 Answers
SOURCE: Nextar MA933A MP3 Player ?
you can download the driver @ nextar.com for Nextar MA933A. However it seems you only need the driver for it if you are using windows 98 or windows 200 prior to SP3. At the link above you can also download the manual, and read the FAQ section.
hope this helps.
Posted on May 08, 2009
  • 9 Answers
SOURCE: the USB doesn't work
there must be hardware problem you need some technician help.
Posted on Apr 04, 2010
My nextar digital mp3 player shows a computer and mp3 sleeping when i plug it into the computer. How do i fix it? Please help
When mp3 connected with the computer it goes off because that will be acted as usb only and the other funcion will be disabled. Therefore don't worry.
Mar 06, 2013 | Nextar MA933A MP3 Player
Nextar mp3 player won't work and computer can't find it to download music
This is common for most cheaply made media players and Win 7 pc's. Boot Windows in safe mode (press F8 after bios post but just be for Windows boots) then conect your media play. Windows sound and auto run features are not running in safe mode. So just open my computer to access your usb mp3 player.
Sep 26, 2010 | Nextar MA933A MP3 Player
How do I reprogram my Nextar mp3? Its frozen at the starting menu.
Here's a few ideas (with so little info on your problem):
1-scroll up and down the menu with the left/right arrows, hit the M button to play whatever selection (music, video, ebook...) is showing.
2-REGULAR MAINTENANCE: when your Nextar is connected to the computer via USB, open My Computer, right click "Nextar", select 'properties'. Under 'tools', check for disk errors and defrag the Nextar - and Backup if you want.
THIS should help!
Aug 03, 2010 | Nextar MA7151B MP3 Player
The USB doesn't work
Apr 04, 2010 | Nextar MA933A MP3 Player
My nextar mp3 doesn't conncect
Talked to a nextar rep, if windows doesn't load the drivers, then their is something corrupt in the firmware. When I hook mine up it keeps connecting and disconnecting. So it's most likely a firmware issue that has to be fixed by nextar.
Nov 11, 2009 | Nextar MA933A MP3 Player
Music not found
The songs you are trying to load to the Mp3 player are not compatible with the Nextar - a good test for this would be to connect your Nextar to the PC, open Windows Media Player, and click the Library tab, then the Sync tab - if a little blue "i" appears next to the song, it will not work with your Nextar. In fact, any song that is not in mp3 format or unprotected WMA (very few WMA's are unprotected unless you Ripped them directly from CD) will not play in the Nextar.
-Tha Mp3 Doctor
Jan 27, 2009 | Nextar MA933A MP3 Player
I have a nextar mp3 player and when i load songs to it from my computer afterit is disconnected from my computer it can not be found on the player
The songs you are trying to load to the Mp3 player are not compatible with the Nextar - a good test for this would be to connect your Nextar to the PC, open Windows Media Player, and click the Library tab, then the Sync tab - if a little blue "i" appears next to the song, it will not work with your Nextar. In fact, any song that is not in mp3 format or unprotected WMA (very few WMA's are unprotected unless you Ripped them directly from CD) will not play in the Nextar.xxx
Problem with MP3 player
I bought a few mp3 players that had same problem. Couldn't figure it out. They were nextar too. I don't buy them anymore. Nextar are really cheaply made. I would suggest taking it back, buying higher quality name brands. Creative is a higher quality, cheap and lasts a long time. Use mine everyday, has lasted 3 years so far.
Dec 11, 2008 | Nextar MA933A MP3 Player
Nextar Mp3 player problem
Try to sync it with windows media player.
It works every time for me.
Jun 29, 2008 | Nextar MA933A MP3 Player
Nextar MA933A MP3 Player Logo
Top Nextar Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
