Question about Sony DAV-IS10 System
I do not hear sound until I am over level 50 - Sony DAV-IS10 System
    Novelist:
  • 169 Answers
If this is happening on all inputs then your system has a problem in pre amp or power amp section.
Try all inputs, with the same source at low volume first, as some may be more sensitive than others.
make anote of what happens and only change one thing at a time.
Posted on Sep 20, 2009
Why do you need to turn the volume up to over 50 to get a level of sound to hear
The number is an arbitrary number assigned by the tv manugacturer. They could have just as easily made that 50 a 7 or a 212 or any other number. Few volume controls are linear either.
Aug 04, 2016 | Luxor Televison & Video
Peavey 16 fx
are you going from the board to a 'mic' input, or a 'line input' on the Mac? you will need to attenuate the signal to a mic input. try reducing output from the board by 50% and reduce the input level on the Mac by 50%, and see if the distortion is lessened or eliminated. From there balance board output to Mac Input until you find what sounds good outta the Mac.
Oct 16, 2013 | Music
My sunfire overheats and leaks out overflow everytime i drivee it.i changed water pump,thermostat the fan is working fine and had a water pressure test done last mth
DID YOU BLEED AIR OUT THE COOLANT SYSTEM.TO BLEED COOLANT SYSTEM, FILL THE COOLANT SYSTEM THROUGH THE RESERVOIR TANK OR THE RADIATOR UNTIL THE FULL COLD MARK IS REACHED.BESURE TO USE 50/50 HALF WATER AND ANTIFREEZE.YOU CAN BUY ANTIFREEZE THAT IS ALREADY PREMIX 50/50.AFTER ADDING ANTIFREEZE TO RESERVOIR OR RADIATOR FILL RADIATOR TO FULL MARK OR IF YOU DONT HAVE RADIATOR CAP ON RADIATOR POUR ANTIFREEZE IN THE OVERFLOW JUG UNTIL COOLANT LEVEL STAY THE FULL COLD MARK.WAIT AWHILE UNTIL COOLANT LEVEL STOP DROPPING.NOW INSTALL THE RADIATOR OR OVER FLOW JUG CAP.START THE ENGINE AND ALLOW IT TO RUN UNTIL NORMAL OPERATING TEMPERATURE IS REACHED AND THE UPPER RADIATOR HOSE BECOME HOT.STOP THE ENGINE AND OBSERVE THE COOLANT LEVEL IN THE OVERFLOW JUG. THE COOLANT LEVEL SHOULD BE AT THE FULL HOT LINE.ALLOW THE ENGINE TO COOL UNTIL THE AMBIENT TEMPERATURE IS REACHED THEN CHECK THE COOLANT LEVEL IT SHOULD BE AT OR ABOVE THE FULL COLD LINE.ADD MORE COOLANT IF NECESSARY. WARNING BECAREFUL WHEN OPEN THE RADIATOR CAP OR JUG OVER FLOW CAP.USE A LARGE RAG OVER THE RADIATOR CAP TO KEEP FROM GETTING SCALDED.OPEN RADIATOR CAP A LITTLE AT A TIME TO KEEP FROM GETTING SCALDED.WAIT UNTIL ENGINE COOL DOWN BEFORE OPENING RADIATOR CAP OR OVERFLOW JUG CAP.WEAR SAFETY GLASSES.
Jul 12, 2011 | Pontiac Sunfire Cars & Trucks
Vizio 37" tv. sound loud enough on satellite and antenna. when hooked to dvd or blue ray, can hardly hear it even at maximum sound
I have a similar problem with my new 37 inch vizio. Watching on cable and the sounds gets lower and lower until i can hardly hear it. Must switch channels back and forth to restore the sound level of a particular channel. Does anybody have a solution ?
Feb 13, 2010 | Vizio VW37L 37 in. LCD HDTV
The heater stops working and then the car gets hot
Sounds like you have air bubbles in the cooling system. Most likely, if you haven't done any recent work to the cooling system, like changing out the coolant, you have a leak. The other, but less likely, cause would be the water pump is going, or the belt that drives it is slipping.
Unless you are adept at working on cars, I'd suggest taking it in and having the cooling system inspected for leaks.
For the time being, if you know how to check your coolant level, check it, as I am betting that it is low. Add a 50/50 mixture of coolant and water (mix it yourself, or buy the pre-diluted 50/50 blend) to bring the level up to where it should be. Until you can get it to be looked at, keep a constant eye on the level and top-off as needed.
Dec 13, 2009 | 1997 Cadillac DeVille
Gurgling water sound in dash
U HAVE A BLOCKED AC CONDENSATION DRAIN TUBE, IT EXITS AT THE BASE OF THE ENGINE FIREWALL UNDER THE CAR ON THE PASSENGER SIDE.
Nov 05, 2009 | 2004 Pontiac Grand Prix
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Audio volume level
Hi, I'm guessing your turning up the volume on the TV box to control the volume of your speakers. By doing this your only controling the audio strength coming out from the TV box.
What you should be doing is turning up the volume on your TV or amp feeding your speakers rather than the direrct TV box. The level of the speakers may have been reduced form last week (other people messing about with your equipment?) which is the reason why you have to turn it up to 30 rather than 10.
Another problem could be a loose audio connection from you direct TV box to your amp or TV. Have you tried a different source such as a DVD player, and does the sound on that seem alot quiter than before? If the volume of this is alot quiter also it could be a problem with your speakers.
Hope this helps.
Nov 01, 2008 | Televison & Video
Audio Levels are a mess??
connect a pair of headphones to your telly and see if the sounds is correct at all volume levels.
This will at least tell if you if it is the audio processing or simply the speaker/amplifier section
Aug 05, 2008 | Sharp 25N-M100 25" TV
Sound problem
- make sure sound is not muted - make all volumes are up to at least 50% fader level - try known working speakers or headphone on the headphone jack
Aug 29, 2007 | Acer TravelMate 2300 Notebook
Sony DAV-IS10 System Logo
420 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
