Question about Maytag MSD2454G Side by Side Refrigerator
Our side by side side by model was purchased in 2002 and has been problem free. Starting about two weeks ago following a party, there has been a continual frost build-up in the freezer. I have removed the frost and wiped the freezer dry 3 times and removed a bag full of ice from the lower basket thinking that may have started the problem by setting the stemperature too low. What can we do now? Yvonne Winston
  • s_winston53 Sep 21, 2009
    We have searched and clean the freezer and refrigerator in between several appointments and time away from the house. We cannot find a defrost timer. There is no plastic plug covering. Our model # is MSD2456GEW.
    Thank you for your attempts to help us with this problem.
    Yvonne Winston
  • 41 Answers
You have a bad freezer door gasket!! it's letting moisture seep into the freezer and once the moisture hits the extream cold it turns to ice crystals.The freezer is designed to get as cold as 0 degrees and the ice cubes stay in cube form as long as the temp is below 32 degrees so the ice cubes didn't make a difference.You can try and CLEAN the contact surfaces of the gasket and freezer real good this usually works,if the gasket is damaged you will need to replace it.
Posted on Sep 21, 2009
Testimonial: "It worked to clean surfaces of the gasket very well. All this area in the refrigeration unit was iced over. Careful chipping the ice away did it!"
  • Maytag Master
  • 4,655 Answers
That problem should not be too hard to solve.There is a defrost timer located inside the fresh food compartment and just behind the temperature control panel. Most times the timer has a plastic plug covering a hole about the size of a pencil. Remove the plastic plug and use a flathead screwdriver to turn the timer slowly clockwise. When compressor stops running leave it there for up to 25 minutes. That should start the defrost manually. During that time open freezer door and listen to hear crackling or a sizzling sound. If yes that is defrost taking place. If the timer does not restart the refrigerator on its own slowly turn again clockwise until the compressor starts. The problem is most likely the defrost timer. If not there are only two other things to check and that is the defrost heater and defrost thermostat. Let me know what you find, Thanks, Sea Breeze
Posted on Sep 20, 2009
Le2412 power on problem
The power supply is failing.
Dec 20, 2013 | Apex Digital LD4088 LCD TV
2002 merc grand marquis wont start battery was replaced 1 week ago
Does it not start or not crank ?
If it does not start, you will need to figure out if it is a lack of fuel to the injectors or lack of spark to the plugs to proceed.
Jul 29, 2012 | 2002 Mercury Grand Marquis
I need my unlock code for lg u990 imei 358203- 01-2052260
Try to get free LG KU990 Viewty unlock code from promo event at third party sites. Here you can try on this store, a few months ago they have free unlock code event, but you must follow their instruction. If you so urgent looking lg unlock code, you can try buy from online store according to your models and network card. It will not takes so much time.
May 02, 2011 | LG KU990 Viewty
Hello, We just purchased the Electrolux side by side counter depth fridge (E23CS78HSS) a week ago. This past weekend the power failure light can on and the temperatures began to rise in the fridge and...
A week ago sounds like it is still under warranty. Check the manual for a troubleshooting chart and see if there is anything power failure. If you find nothing, return the fridge for another one.
Dec 20, 2010 | Electrolux E23CS78HSS Side by Side...
Purchased in 2002 and is starting to freeze in the
Check the back of the fruit and vegi drawers. If theres a slot for an intake port try closeing it (if adjustable) Check thermostat setting for fridge and adjust to a lower setting.
Finally make sure door closes and seals closed, clean gasket with mixture of white vinegar and water (1 cup vinegar to 1 gallon warm water). If this fails internal thermostat may need replacing.
Dec 17, 2009 | Amana ARS2464B Side by Side Refrigerator
I purchased a Kitchenaid Refridgerator 6 months ago. I changed the filter at the bottom about 3 weeks ago. Ever since then, my refridgerator has a bad odor. I have completely cleaned the refridgerator and...
If you purchased this machine NEW 6 months ago, everything on it is under warranty. You should contact the selling dealer to verify you are entitled to a free service call. Changing the filter is routine maintenance and in no way should affect the warranty.
Oct 25, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Problem with kenmore side by side leaking
2 things could be wrong first is you compressor running if is not running you have to check the overload to see if it tripp if it did it will sound like a babys rattle just repl and compressor should kick back on if is running then is you evaporator motor running if is not then check for volatge at the wires if you get 118 then repl your motor. is the unit defrosting is there a lot of ice on the back cover it might not be so 3 thing might be failing 1 timer 2 defrost thermostat 3 heater coil call a tech to have those check out thanks
Oct 09, 2008 | Kenmore 50522 / 50524 Side by Side...
Maytag MSD2454G Side by Side Refrigerator Logo
200 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
