Question about GE Spacemaker Washer and Dryer Electric Laundry Center
My ge stackable smells like it is burning. How do I fix this?
  • 4,345 Answers
Well, you do not mention which machine causes the smell. My concern is fire hazzard, be sure to check the dryer hose system, and DO NOT USE plactic vent hose, major fire hazzard, they make the same thing in metal and it works better....
Posted on Sep 20, 2009
Kenmore stackable washer will not drain burning smell
THE DRIVE BELT HAS BURNT UP AND NEEDS REPLACED
Aug 14, 2014 | Kenmore Washing Machines
G.E Microwave model JVM1860 Burning Smell
you must open inside see the diagram, and see 1) burn cable 2) fuse 3) diode 4) capacitor 5) magnetron 6) bulb etc.
God bless you
Nov 22, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE 25GT270 TV had a jumpy picture for a short time, then TV shut down. Afterward, smelled a burning smell. What happened and can I fix it?
Check its vertical output section circuit for damaged component/s. Check the vertical output IC.
Feb 19, 2013 | GE 25GT270 TV
Burning smell microwave
The burning smell is most likely the rectifier burning. Look for a rectanguler black thing connecting from one lead of the capacitor to ground.
Jul 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire gallery stackable heavy duty washer stopped spinning and there was a electrical burning smell. what is this?
the problem will be in the motor. most of the time if burning smell comes due to coil burn only please change the motor
Dec 23, 2009 | Washing Machines
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Mar 07, 2009 | GE Dryers
Burning odor, no heat
A burning smell along with a different sound (growl) USUALLY indicates a breakdown in the High Voltage Side. This is not a direct short (short circuit) or the line fuse would have blown shutting everything down. The High Voltage Side is made up of-- The Secondary ,or High Voltage Side of The High Voltage Transformer, A High Voltage Diode, A High Voltage Capacitor, and The Magnetron. If The High Voltage Transformer is the problem it will smell like a florescent light ballast burning, and will smell each time you turn on the MW. A HV Diode burns and opens, thus no more smell. A HV Capacitor usually does not burn nor does the Magnetron. There is no Cheap-Fix unless you can see that the HV Diode is burned into and you can get to it to replace. CAUTION: Always unplug from power before attempting to repair. NOTE: If you replace a Diode make sure it goes back in the same direction it came out. Yes there is a front and back.
Jan 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Stackable Washer/Dryer
THIS COULD BE THE MOTOR IF IT IS UNDER WARRANTY LET THEM PAY FOR THE REPAIRS
Dec 27, 2007 | Kenmore 98702 Stacked Washer/Dryer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
252 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
