Question about Golden Technologies Health & Beauty
My used 4-wheel BUZZ Scooter did not have a battery charger when I bought it When broken down, I find the battery is in a pak with a haqndle on it for removal, and I see no visible means to plug anything in to it for recharging. How do I recharge this battery paK? if a charger is required, where do I het one and what is it called?
    President:
  • 1,865 Answers
You can write to the manufacturer and give them the model number and request an operator manual and a charger.
If you can find information regarding the voltage of the battery pack, and the type of battery it uses, you may be able to find a generic charging unit.
If you can find information regarding the voltage of the motor on the scooter, and current draw. YOu can buy a battery pack and charging unit to fit the scooter
Posted on Sep 20, 2009
What is maximum wheel size that can be used on merits challenger scooter
Only the stock size.
Merits Challenger Three and Four Wheeled Scooters - Independent ...
ilcaustralia.org.au/products/5611
Nov 30, 2016 - A rear wheel drive scooter with rear suspension, suitable for outdoor use. It is available with three or four wheels. Closed loop handles allow ...
Merits Parts - All Mobility Brands - Mobility Scooter and Power Chair ...
www.monsterscooterparts.com/mobility/mobility-brands/mehepr Merits Atlantis (P710/P7101/P7102) Power Chair Parts. ... Monster Scooter Parts carries Merits parts for all models, including scooter and power chair replacement battery chargers and battery packs. ... As an authorized Merits parts dealer, Monster Scooter Parts can help you find just the ...
Merits Health Products - scooter, power wheelchair, manual ...
www.merits.com.tw/ Merits is the professional manufacturer of health products. We specialize in scooter, wheelchair, home care bed, accessibility, patient aids and other home ...
Merits Challenger 4 Wheeled Scooter - Assistive Technology Australia
https://at-aust.org/items/6176 Nov 9, 2016 - Merits Challenger 4 Wheeled Scooter - UNAVAIL (Deleted). Learn More. Approximate Price: $4350. No supplier. (0 suppliers). For information ...
[PDF]Merits Pioneer 3 and 4 Owner's Manual.pdf - Scootaround
https://www.scootaround.com/.../merits/Merits%20Pioneer%203%20and%204%20Ow... Congratulations on the purchase of your new Pioneer 3 or 4 power scooter. We at ... tiller assembly, battery charger, and owner's manual. Contact ... Wheel Size.
maximum wheel size that can be used on merits challenger scooter Google...
Apr 05, 2017 | Health & Beauty
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
I need to find a stackable battery box for my scooter, as well as what batteries are needed. Also, what charger should be used with it? I bought used from a private party-no charger and the small battery...
James your scooter use 2 12-12ah batteries located inside the battery case. Just remove the screws holding the case together and remove the old batteries then replace with the new ones making sure that you repace the wiring just as you removed them from the old batteries you might also have a heat sensor attached to one of the batteries make sure you reattach that to the new batteries. Any off board charger made for power chairs or scooters will work but try to find a 4 amp charger with an on/off switch. Always turn the charger off when plugging or unplugging from the scooter Check on e-bay or with a provider for a charger Hope this helps
Nov 18, 2010 | Drive Medical Phoenix 3 Wheel Compact...
Scooter dash lights flash up and down .were normaly they come on and stay at top .they just constantly run up and down ..batteries show on charger in boot .that its fully charged
Hi. Some scooters will show a pattern like this while the charger is operating, but when the charger is turned off it should stop. Some internal chargers have a relay that is activated while the charger is on to disable the scooter. Does the scooter operate properly after the charger is turned off? If not, then unplug the charger where it connects to the batteries inside the scooter and see if this helps. If this helps, you might need a new charger.
Good luck. Neil.
May 14, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Batteries pull way down even completely charged
Hi...
Try tightening connections on the batteries
and dont use it with the charger plugged in
If this helps please rate my help
Apr 17, 2010 | Drive Medical Daytona 4-Wheel Power...
Wont charge
the batteries have failed or the fuse in the charger
ted
Apr 15, 2010 | Pride Mobility Products Hurricane PMV...
Charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
New 55ah batteries but charge won't last.
Battery life is affected by many things. But inside a tiled space like Walmart is probably the best possible running conditions. Make sure your tires are fully inflated, and you may need to have the motors check for worn brushes or maybe the wheel bearings are dry. Does the scooter push hard when in free-wheel mode? You may also need to have your charger checked, to be sure your batteries are really being fully charged.
Nov 22, 2008 | Pride Maxima 4-Wheel 4-Wheel Scooter
Health & Beauty Logo
19 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
