Question about Audiovox MVDVD4 Car Video Player
THe video output is rolling like on an old tv that the horizontal hold was out of adjustment. I ran it through the other video input on the audivox VOH682 and the same thing. The old vhs player works fine in the VOH682. Also is there a digital tuner converter for the VOH682 to pick up digital tv signals.
  • skiphartline Sep 20, 2009
    THe main thing i'm interseted in is a fix for the horizontal hold on the dvd player is there possibly a pot inside which could be trimmed out
  • skiphartline Sep 21, 2009
    THank you, someone had push the system button on the remote
  • 5,807 Answers
i have found a web site which i think would work with your VOH682
here is the link:
http://www.parkmyauto.co.uk/ck0-1080-in-car-3rd-gen-dvb-t-12v-twin-digital-freeview-hideaway-tv-tuner--glassmount-antennas-737-p.asp
a) your VOH682 have a video display system of NTSC which
means other color system might not possibly work.
b) it needs signals which have NTSC system to work. either on RF
(antenna) or in video input.
hope i have helped you, thanks for using Fixya!
Posted on Sep 20, 2009
  • Rommel Cana
    Rommel Cana Sep 20, 2009
    the DVD player is factory set to accept NTSC programmed media, if the media is recorded in PAL
    then it will show rolling pictures, the sync frequency differs from every system used.
    try having known good media ( DVD movie in NTSC) if problem still persist then maybe the
    region setting of your unit have changed.( might have switched to PAL system)
    you need to go to video set up, under TV type
    select NTSC
Picture is rolling
In the old days there was a control at the back of every tv labelled "vertical hold" that needed adjustment when the picture rolled. As tv sets became better that control was at first moved inside the cabinet and then finally deleted.
The vertical hold controlled the amount of synchronising signal (that is extracted from the signal received from the antenna) reached the frame oscillator. Today's electronics are so stable the vertical and horizontal synchronisation is automatic so while sometimes a rolling picture can be caused by a bad signal it almost invariably caused by an internal electronic fault needing the attention of an engineer.
Oct 19, 2017 | Televison & Video
Repair visio e322 TV
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Apr 24, 2016 | Televison & Video
Where is the vertical hold control located on Vizio 32" 720 TV? Trying to give directions to handicapped brother remotely
there are no vertical/horizontal adjustments on this vizio lcd tv.
these functions are controlled by a microprocessor circuit and are not adjustable.
Jan 21, 2015 | Vizio L32 32 in. LCD HDTV
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
My philips 240b powervision tv, about 10 years old, while watching, all of a sudden the screen video turned into slanting horizontal whilte lines. the input is from setup box. I guess it happened when i...
Slanting horizontal lines indicate that the horizontal hold is out of adjustment. As the components age they change values and don't have the same effect on the circuit. some units have a horizontal hold adjustment pot on the back that can be adjusted to bring the horizontal back to the middle. If the adjustment pot is not on the back the only way to bring the horizontal hold back is on the inside of the unit and this is not a safe proceedure. If the picture was really good before it went bad then it might be worth the cost of repair. If the picture was getting weak (light colors, washed out look) then the repairs are not cost effective (not worth the money to have the unit repaired) There are some tv repair people that work quite a bit cheaper than others. It would be worth a few phone calls to get an estimate and make an informed purchasing decision.
May 01, 2011 | Televison & Video
Horizontal hold needs an ajustment
Hello
Horizontal rolling is your problem I thinks. In modern TVs there is no horizontal hold control like they wer in old one. All the adjustments are digital, that is related to a very accurate crystal oscillator frequency, and its cound downs. Therefore if your TV is not so old, its main Ic may be faulty, or horizontal synchronisation pulse does not reach the appropriate pin of that Ic. First check it, and if it is ok, replace the Ic.
Oct 18, 2010 | Durabrand DU1301 TV
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Dell pc to tv hook up
Most video cards on computers output progressive scan, and your flat screen tv may be interlaced. This would cause the horizontal hold to keep rolling.
Jul 06, 2009 | Dell Dimension 3000® Pentium® 4...
HORIZONTAL HOLD
Hello INDIII,
The answer is yes, if all you have to do is to adjust the horizontal hold control (usually located on the back of the TV)
The answer is no (with caveat) if you have to open up the set. This problem occurs when the horizontal oscillator is drifting off its set frequency of 15,750 Hz This can be caused by a component or components changing in value, or the problem could be caused by the loss of or decrease in the amplitude of the horizontal sync pluses within the video signal. Such a loss of amplitude can take place from the output of the Video detector to the Horizontal mixer stage (uses the Video pluses and the Horizontal oscillator to sync the picture). This means that you will be working around a hazardous section of your TV.
The caveat is if you have a background in electronics and you have the proper equipment.
1) schematic diagram of the TV to see where TV test-points are
2) multimeter to measure DC voltages at test points
3) oscilloscope to view waveform patterns in the horzontal section of the TV
4) Signal generator to produce a know good signal into the TV set.
5) Isolation Transformer to connect the TV power plug to to isolate the Tv ground from earth ground and allow proper connectivity for test equipment (plug the unit under test into the isolation transformer and the test equipment into the wall outlet.)
I hope this answers your question,
Thank you,
Shuttle83
Nov 26, 2007 | Televison & Video
Akai DHT300 screen rolling
The picture is rolling because there is no sync signal in the composite output. Are you using the RCA jack or the S-video output? Is there another small TV you could hook up for a test to see if the problem appears there? If it does, then the Akai has the issue and needs to be examined further. If not, the TV input may have an issue. You didn't say what the TV is but there is the possibility the video input is looking for external sync from the DVD but that's a bit of a stretch. Can you feed a different source into the video input of the TV to see if you get the same result? Hope this helps.
Nov 01, 2006 | Akai DHT300 System
Audiovox MVDVD4 Car Video Player Logo
64 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
