Question about Dell Inspiron 1420 (dncwja1_1) Intel Core 2 Duo T7250 (2MB cache/2.0GHz/800Mhz FSB) 80GB/1000MB PC Notebook
Looks like my colour correction is messed up.....i tried all the posible soulutions...it is all pink and the start up scren is green in colour....what can i do
    Problem Solver:
  • 10 Answers
Right click on your desktop , properties and go from there , it sounds as if you have changed your computer theme.
Posted on Sep 20, 2009
Hi, the screen on my Dell Vostro 1400 started having some issues after I dropped it. The colours were all messed up and pink and green seemed to be the only colours working. When I plug it to a external...
The screen is bad.... They do not like being dripped. At this point, I would run an external monitor for color. A new screen will be roughly $300 or so.
Jun 02, 2011 | Computers & Internet
I have just recently purchased a BMW ci328i and do not yet have the manual. The coolant sign is starting to flash up on dash. What coolant can I use?
There are many different coolants and if you mix 2 different ones together they can react and turn into a gel which don't do the car much good! the best way is look what colour coolant is in the system already and as long as you use the same colour coolant it will be fine, main colour coolants are green,blue pink and orange, green and blue can be mixed together as can orange and pink but Pink cannot be mixed with blue or green, i would guess the coolant in your car will be the pink stuff but please check 1st, hope this has been usefull to you.
Ash
Jan 09, 2011 | 2000 BMW 3 Series
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
Jul 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Hp w2007 why does the computer go pink everything that is green is now black
All the colours on the screen are created by "mixing" the 3 "primary" colours (red, blue, green).
Once the production of "green" ceases, anything that should be "100% green" becomes "100% black",
and every colour that indicates some percentage of "green" becomes a mixture of just RED and BLUE, i.e., various shades of PINK.
First, try the monitor on another computer (desktop or laptop). If the problem persists, it's time to replace the monitor. If the problem vanishes, it's the video-card in your computer that is not generating GREEN, or it is the "data" cable between your monitor and your computer that is not transmitting the GREEN request. So, you can try replacing the data-cable, or try replacing the video-card.
Jul 11, 2010 | Computers & Internet
My monitor resolution colour is changed to pink.
Check the data-cable between the computer and the monitor, and try a different cable.
Or, try connecting the monitor to a different computer, to see if the video-card in your computer is not working correctly.
If necessary, replace the video-card.
Colours on your monitor are produced by "mixing" the 3 "primary" colours: red/green/blue in various proportions.
Or, if part of the monitor that produces one of those 3 primary colours has stopped working, then the resulting "mix" will have too much RED/PINK. Fix/replace the monitor.
May 29, 2010 | SAMTRON 55V 15" CRT Monitor
Picture colour is wrong. Too much green and pink.
first reset the settings to factory default. then swap out the cable. if you still have trouble, replace the colorwheel.
Mar 27, 2010 | InFocus ScreenPlay 4805 Multimedia...
Acer Orbicam Colour Problem!
The display is gone. Replace it.
Nov 29, 2009 | Acer Aspire 5100 Notebook
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Aug 21, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Optoma h27 colour issues
Check to be sure that the projector is in the correct mode. If it is expecting an RGB signal and you send it (Y,Pr,Pb), you will see the picture as you describe. The same works for the above reversed. In all likelyhood, you are sending RGB and the projector is expecting the other.
Dan
May 07, 2008 | Panasonic PT-LB10VU Multimedia Projector
Dell Inspiron 1420 (dncwja1_1) Intel Core 2 Duo T7250 (2MB cache/2.0GHz/800Mhz FSB) 80GB/1000MB PC Notebook Logo
65 people viewed this question
Alun Cox
