Question about Kenmore Dishwashers
I have a roll away model 17449. i have it hooked up to the faucet, plugged in to a working outlet and it won't do anything.
How to turn on water outlets in delta bathtub?
I've seen plugs they insert to outlets by the screens for some reason. But during a remodel I did I noticed those plugs and removed them. Or on a tub faucet the plug might be where you screw it onto waterline
May 02, 2015 | Delta T13120-LTS Single Handle Monitor 13...
My Fontaine Monaco kitchen faucet just sprays water, never a seadystream or way to switch it. Have tried Lowes different areators but to no avail. What do I need?
The faucet has the wrong aerator or an aerator that has been installed incorrectly or is missing parts or is cross-threaded.
Jun 11, 2017 | Plumbing
My Kohler Fairfax faucet pressure /flow has dropped (cold)
Verify the cold water outlet has equal pressure as the hot side outlet at the wall. Check the inlet screen on the cold side water line where it attatches to cold water pipe. The screen could be plugged. Then check the cold side hose for any restrictions. Also check if there is a screen on the outlet side of the cold water hose and see if it is plugged. Otherwise the faucet valve is mis-aligned and will need to be rotated and re-tightened to align the valve to the center so both sides have equal water flow.
Nov 08, 2009 | Kohler K-12176-PB Fairfax Single Handle...
Hi, I recently had problems with my gfci outlets. I have 4 outlets connected to a gfci circuit and I cant get the other outlets to work if nothing is plugged to that one outlet at the end. The gfci outlet...
that is truly a strange problem, has there been any rewiring going on? almost seems that it wired in a series instead of a paralell circuit and the end one completes the circuit when something is plugged in. i am not sure how to tell to fix this other than to go thru the whole circuit.
at the gfci the line side, or the hot wires supplying it should be hooked up to the line side of the gfci. the wires feeding the rest of ur outlets should be connected to the load side of the gfci.
then at each outlet the hot wires both line and load should be hooked up to the brass or gold looking screws and the neutrals should be hooked up to the silver screws. this way u should have power on all the outlets.
Aug 11, 2009 | Leviton 8299 Combination Switch / Smart...
No water comes through after installation and turned on supply valves
these facets are shipped with plastic plugs in them to keep stuff from getting inside them during shipping. Did you remove the plastic plugs where the supply lines hook up?
Jan 04, 2009 | Delta Model 300: Classic Single Handle...
Red & Green lines rolling from the bottom to the top
You could have a ground loop problem. To test plug DVR and TV into same outlet.
Dec 27, 2008 | Televison & Video
American Standard Cadet 2-handle tub & shower set-Model#3275 - low pressure output
When you installed the new tub faucet you probably turned off the water to that faucet of even the whole house. IF IT IS AN OLDER HOUSE, TURNING THE WATER OFF AND BACK ON CAN LOOSEN SOME DEBRIS IN THE WATER LINES THAT CAN FIND THEIR WAY TO YOUR NEW FAUCET. If there is a screen at the end of the water outlet it can be clogged with gunk. Uncrew the screen on the water outlet and clean. You may also want to flush out the hot and cold outlets by turning the water off, removing the cartigages and slowly let water flush them out. Then reassemble. Also when you have the tub handles out you can turn the hot and cold supply valves off and on a few times to loosen more debris if it exsists........Joe
Oct 24, 2008 | American Standard Colony 3275.505 099...
How to hook up portable dishwasher.. we have the dishwasher from a friend and the adapter, but i don't know anything else. do we turn the faucet on or just press start on the washer???
Hi. Thanks For The Question. The Adapter Goes On THe Faucet .It Screws On. Then The HoSE From The DishWasher Hooks On To The Adapter Turn On The Water. Plug DishWasher In To The Wall Socket Put Dishes In Lock The Door Push Cycle Good To GOo. Thanks The Appliance Doc
Oct 03, 2008 | Dishwashers
Appliance installation
on the fridge.. sometimes the teflon tape is not nessesary. i just like to use it for the extra measure. teflon tape is in a blur roll with a white pop off cover and the tape it's self is a thin white tape.
on the dishwasher.
alot of the time you will be hooking up wire to wire. On the model you will be getting it may be as simple as even a black wire and a white wire. You may also need to purchase a plug that will plug into an outlet. but i am not sure what model you are getting so i do not know the exact specs on it. it also should come with an installation guide to help you through the process.
Aug 20, 2008 | Refrigerators
Dishwashers Logo
63 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
