Question about Dryers
We have a hotpoint aquarius CTD00 the water has stopped going into the tank.
    Problem Solver:
  • 9 Answers
It is your water pump, or sometimes your have to clean your screens where your hoses connect, dirt, lime buildup will block the water coming in.
Posted on Sep 20, 2009
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Just replaced jockey wheel on hotpoint aquarius ctd00 but drum still not going round??
Check belt not slipping, Most likly cause is motor brush assembly.About £18.00 to fix yourself
Feb 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Dryer revolves but no heat on any settings . hotpoint aquarius tumble dryer CTD00 7Kg.
fixed using posted advice on resetting thermostat.
Many thanks
Dec 10, 2009 | Hotpoint Dryers
Hotpoint aquarius condenser dryer ctd00 - empty water light will not extinguish after water has been emptied resulting in no heat
The float switch within the plastic unit at base of machine has failed,shorted out Carefully prise the unit open Disconnect and identify the three tags Replace switch and attached lever Examine the insulation on the rear tags as they are very close Reinstate Red light will now extinguish pump will run when float operates hearers will come on
Oct 15, 2009 | Hotpoint Dryers
Safety Trip
On the heater there will be a cut-off switch with a small hole where you can stick a needle in until you hear a 'click'.
Jul 14, 2009 | Hotpoint Dryers
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Dryers Logo
167 people viewed this question
Top Dryers Experts
