Question about Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum
Works then doesn't
The vacuum runs for a while, then stops. i let it sit a while then it works again.
  • 66 Answers
Motor is overheating,make sure the vents are clear of debree around the motor.
Posted on Sep 20, 2009
Dirt devil easylite 7.2 v does not hold charge. Can you suggest any fix? Thanks
Sorry to say that the batteries seem to be worn out. Usually this is caused by using it for to short a time each time you use it. Batteries develop a 'memory' after several short time uses, and can only be charged the time it 'Thinks' is a full charge. You can try running it until it almost stops. Then let it sit for about an hour turned off, then turn it on again, and run it till it almost stops. After doing that put it on the charger for 8 hours. Then run it until it almost stops again. then charge it again. That process sometimes breaks the memory problem. If not, you need new batteries- or a new dirt devil.
Jul 02, 2017 | Dirt Devil Vacuums
I have a light weight shark navigator vacuum it just stopped working help
Unfortunately these where designed to fail. I owned one, I could take it apart and clean everything and make it work again, eventually it stopped working completely tho
Feb 21, 2015 | Shark Vacuums
Neato robot turns on, fires up vacuum/brushes, but won't move - no error messages. What gives?
I have a Neahis to Botvac 85, had also problem, it started up then stopped. It is 2 or 3 years old, don't remember. but it started to ack very strange with the battery. then this start/stop problem came. I ordered a new originial battery and thought it should solve the problem but no it didn't After some time I decided to try again. Started Neato and it stopped after some time, then I wanted to see if the lidar was rotating so I removed the blue cover over the lidar and could see that it was rotating, then I touched it little bit and the neato started and started to clean my floor. so try this.
Sep 12, 2014 | Neato XV-21 Pet & Allergy Automatic Vacuum...
Why the vacuum shut off after 3 minutes and the plug is hot
sounds like the motor maybe clogged and over heating. if you can take apart the vacuum and find the motor. if you have a shop vac use that to clean out the dust and debris. put it back together and try it again. if this doesn't work i would replace the vacuum or get it repaired. i would NOT continue to run the vacuum if the plug gets hot after 3 minutes.
Nov 08, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Craftsman 179220 Canister Wet/Dry Vacuum
Maybe open the motor casing and look for an overheat reset button. If it doesn't have one, check for voltage at the wires coming directly out of the motor. If it has power there and no reset switch, then the motor needs replaced or rebuilt.
Jul 18, 2012 | Vacuums
I have a Bissell proheat steam cleaner, the 9500 series, and it stopped spraying water. I cleaned out the "gunk" in the heater part, put it back together, and it worked for about 3 min. Then it...
There is probably more gunk in there, the gunk can dry and break off in little shards which can get clogged up.
You can try putting straight vinegar in it, try running it through and let it sit in there for a while to see if it can help loosen up and flush out the gunk.
Oct 17, 2017 | Bissell 9500 ProHeat 2X CleanShot Upright...
After using the vacuum for a while it would stop running. After sitting several hours it would run again. Now it won't run at all. It was just a couple of months old and I haven't been able to use it...
If you would take the machine all apart in little pieces, you should find it is clogged with dirt or hair or whatever you have been vacuuming up.
Different brands of machines will last longer or shorter periods of time because of plugging up.
Most all of them can be cleaned, but some will just clog again quickly.
I personally use "Consumer's Report" to find good machines.
God bless your efforts.
Dec 07, 2017 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Vacuum stopped working and wont run
Check the cord to be sure its not broken anywhere.
Check the roller, it may be clogged
Oct 30, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The vacuum stopped running and won't turn back on?
While there's no reset button it's not uncommon for the internal thermal switch to trip to an "open" position. This internal, no-access-switch opens when the motor gets hot, it protects the motor from overheating to the point of failure. Bissell's website states that if the thermal switch is tripped let the vacuumm sit for a half hour and then it try it again.
If it doesn't work you might then try Tech610's suggestions.
Dec 08, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum Logo
212 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
