Question about Dryers
Dryer is very noisy- when starting, the dryer starts, but there is a lag until the drum actually starts to turn. How do I change the belt?
    Problem Solver:
  • 9 Answers
Need to take off the top of your dryer you will see the belt goes around the drum and then a pulley, very easy to change
Posted on Sep 20, 2009
Drum Noise and not drying proerly
a dryer drum usually rides on rollers. when center of roller wears out then they start to get noisy
Dec 21, 2013 | Zanussi Dryers
HI MY AMANA DRYER HAS A HARD TIME STARTING AND AFTER A FEW MINS. STOPS
I am a little puzzled! Normally the difficulty is with startup rather than stopping after starting. Are you sure that the drum actually turns or maybe it just sounds like it is turning? If it never actually turns then it is probably the belt or the motor. You can make sure by placing only a few items in the dryer (try a couple towels or different colors) place the towels inside, (pay attention to where they are) begin the cycle, open the door to see if the towels have changed position. If the drum has been rotating then try adding a few more items to see if things change.
If the drum does not turn at all it maybe the drum belt. If, as you increase the load, the drum has difficulty starting then it is probably the motor or a control circuit. Hope this helps...Good Luck. Douglas
Jan 28, 2011 | Amana Dryers
My dryer won't turn. The motor runs when you push start but the drum doesn't turn. I can turn it by hand and it will run.
- The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
- The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
- The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
- Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Dec 15, 2010 | Dryers
Dryer starts but drum does not turn. was fine until a sneaker got wedged between one of the fins and the chamber wall and drum stopped turning and we smelled a burning odor. after removing the sneaker we...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Oct 02, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer has started to be very loud.
Check ease of drum moving that it moved freely. Remove panels Is motor noisy? Check belt. Is movement of drum noisy? Make sure exhaust is not clogged. Can the air move freely to the outside. Make sure there are no kinks in exhaust line. Determine cause of noise then you have a few choices. Repair, lubricate replace parts or replace dryer. Sometime you just need to use it until it doesn't work anymore and then buy a new one depending on the cost of repairs vs. replacement.
Sep 30, 2010 | Fisher and Paykel Dryers
Motor is noisy (loud buzzing). Drum belt seized.
the problem, is with a component,called a capacitor.a capacitor gives a"jump start"to the motor.when this charge or jump start cannot be given,the motor will "hum" or"buzz".a new capacitor should not too expensive.
Oct 16, 2009 | Tricity Bendix TM310W Electric Dryer
Past few days, dryer got very noisy. Then drum
The noise is coming from a moving part. There are only a few that normally cause a problem. Also the dryer drum not turning freely is what broke your belt. Here is what I would replace. Drum rollers, Drum slides and idler pulley. You can check these parts before you replace them. If the drum rollers don't spin real easy, replace. If the idler pulley does not turn easy, replace. If the drum slides are worn, replace. Your model may be one with a front drum bearing. If it looks worn, replace.
You may be able to take dryer apart, try turning drum. Listen for the noise and notice if the drum is hard to turn. If so, you may be able to determine if the problem is in the front or back of drum. Keep on mind that the noise might have been the belt slipping due to the drum being hard to turn. Either way, when you have it repaired, it should run with the noise. Good luck.
Oct 16, 2009 | Kenmore 400 6943 Dryer
Drum does not turn
Here are a few things to check. If you don't feel comfortable performing these check, please have a repair person come in and check it.
* Broken belt. Open dryer and see if belt is still wrapped around the drum. Pull on the belt to make sure it's not just hanging there. Inspect belt condition. Do not apply spray adhesive in this case: replace the belt. If belt is broken, look for contributing causes for failure such as worn drum rollers, damaged felt kit, or stiff idler roller.
* Motor burned out. Remove belt from motor pulley and start dryer. If motor runs but is noisy and motor is unable to turn the drum when the drum belt is threaded back on the motor pulley, then replace the motor.
* Thermal fuse is open. Run continuity test.
Hope this helps.
Sep 10, 2009 | Kenmore 63942 Dryer
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Servis Tumble Dryer
Sounds like the wheel at the back of drum where belt goes has come loose should be allan key screw/nut to tighten up again.
Hopefully that is the end of your worries.
                Mick
Oct 14, 2007 | Dishwashers
Dryers Logo
49 people viewed this question
Top Dryers Experts
Marvin
Marvin
