Question about Tools & Hardware - Others
Chamberlain CG40 CDM 1/2 hp motor does not rotate
Chamberlain CG40 CDM 1/2 hp does not close or open garage door. Basically the motor does not rotate, upon pressing switch it makes sound and the led indicator flashes 5 times.
    President:
  • 1,723 Answers
Here is the manual:
The fault it's reading is 'Motor overload'
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A3215.pdf
The motor could be stuck, check for free travel on chain drive and make sure nothing is stuck on door...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 20, 2009
Craftsman Door Opener Model #139 53975SRT1 1/2 HP will not open the garage door. It will close it. And if it's on the way down and I hit enter, it will open mid stream. But, if it's closed, an
Two things. Check for a broken door spring. If okay, remove the cover from the motor housing and check for a bad drive gear. This is a white nylon gear just in front of the motor. If it is going bad it should be obvious.
Jul 05, 2012 | Sears Craftsman LiftMaster Chamberlain...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Chamberlain 1/2 HP garage opener main part 41A5389-1 will not close door. Motor stops about 1 ft into travel on screw. Nothing blocking door - can easily open and close door manually. What to do?
If the main light flashes 10 times you have a door sensor problem. Make sure the small light on each sensor is on and not flashing. Tweak them if necessary. If the main light does not flash then you can try increasing the down force just a bit. This is a control on the side of the motor unit where the small gray antenna hangs. If this doesn't work you probably have a bad IR sensor which is a small printed circuit board just in front of the motor.
May 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
We just installed a CG40Chamberlain 1/2 hp garage
Your logic board is bad. If this is a used opener I would pull the logic board and look for loose or missing traces on the printed circuit board.
Apr 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
IChmberlain Garage door does not pen or close
The light flashing 5 times is the code for "RPM sensor or motor overload" and the 10 clicks sounds like the relay for the main light bulb that flashes when the door sensors are blocked or misaligned.
If you want an owners manual and have Adobe Reader you can go here and get one.
http://www.chamgerlain-diy.com/pdfdocs/A2490M.PDF
Oct 15, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opener closes when closed
Try this: Loosen the chain enough that you can remove it from the sprocket above the motor. Now run the opener until the sprocket turns in the clockwise direction and stops. Reconnect the chain. This will get everything in sync and you will have to tweak the 'up and down limits' a bit to get it just right.
Oct 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain garage door opener, Series CG40, 1/2 HP, #41A5021-1F. It opens just fine using the opener located on the wall. However, when I try to use the remote it does not work. I have installed...
Try programming this way. Hold the button down on your remote and then press and immediately release the smart/learn button. If this doesn't do it your remote may be bad. The wall control is hard wired and doesn't use the receiver that your remote does.
Oct 06, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Liftmaster 1265LM 1/2 HP does not open or close with remotes
is chain moving. if not, gears are shot. if moving, is trolley connected.
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener doesnt close all the way.
The motor is probably either stalling because the door is too stiff, or you have a beam break detector that is being triggered when the door is halfway down.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Tools & Hardware - Others Logo
264 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
Bill Boyd
ray gallant
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
