Question about Kenwood VR-6060 6.1 Channels Receiver
Kenwood 606 receiver
After a tv repairman worked on my tv, I discovered the receiver would not change from tv mode to cd/dvd.mode.
I can choose cd/dvd, can hear the cd, but cannot view it. Any ideas about how I can fix this problem? thanks, kay
  • 1,512 Answers
Disconnecting the tv from the audio connections on your amp may have created a powersurge in the audio input selector IC. Try powering down the amp at the wall completely for 5 mins and turn it on again. Check to see if operation has returned. If not then it may need an audio selector chip replaced.
This problem can be caused when connecting or disconnecting rca connectors from non earthed equipment like TV and VCRs, By the nature of this type of connector, it will spike the input line by connecting with voltages floating often over 100volts.
to avert this problem occurring, wire all the equipment up and with aerial disconnected and tv / vcr turned off at the wall socket. Turn the equipment power on at the wall last thing.
Posted on Dec 15, 2007
How to hookup kenwood system w/receiver,cd/dvd etc HELP?
basic setup is simple
connect the kenwood an test it out with speakers
then get some cables to connect it to your tv
you need a cable or 2 , rca phono connectors likely
from the receiver video an audio out to the tv audio video in
you might have 2 sets on each
2 outs an 2 ins
it wont matta which you choose
turn the tv to aux or video input 1 or 2
May 03, 2015 | Televison & Video
Connected DVD player to unit via s-video and optical audio, but still no sound when i choose 6-channel input, why?
you need to select the digital optical input or even easier would be to select the auto sensing efature ok good luck i would walk you through it but im sure you will figure it out ok :)
Dec 21, 2010 | Kenwood VR-606 Receiver
I have a new Samsung 47 in LCD and Kenwood DVD purchased in 2005. I am trying to hook both up to get surround sound from my Kenwood VR-606. My signal is coming from a HD cable box. I'm using HDMI from the...
Without additional equipment it can't be done. As i see your VR-606 pure analog device, and you trying to somehow use 5.1 sound from HD STB that is on HDMI put on RCA connectors of your VR-606. It is impossible without converter from HDMI to Analog audio or something likethis, best way to buy new receiver with HDMI input and TV neither Receiver with HDMI out oportunity. Then you will have your home cinema. In your current setup probably you can play only with stereo from your stb.
Apr 19, 2010 | Kenwood VR-606 Receiver
TV not receiving video signal from DVD. Component video setup from DVD player to SR-606; DVD input assigned to IN1; TV receiving TV signal routed through same HDMI working OK. Was working OK once. Didn't...
This model has a defective hdmi pcb assy. this is a well know defect with this model.If under warrenty have hdmi bd replaced if not the hdmi pcb assy retails around $350.00
Mar 28, 2010 | Onkyo TX-SR606 Receiver
How to connect my kenwood vr-606 digital audio to my tv... i tried to connect digital audio cable from my tv digital audio output to kenwood vr-606 receiver digital audio in and it's not working.. what did...
Your TV is NOT an audio source by itself. It's job is to make pretty visual stimulus for your eyes, not your ears. Everything IT hears comes from somewhere else like a DVD, BluRay, Cable Box, right?
Get the absolute best TV-related audio directly from the digital audio outputs of each source you're watching, not the TV.
Feb 19, 2010 | Kenwood VR-606 Receiver
Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Mar 23, 2009 | Kenwood VR-405 Receiver
Kenwood kdc-w4031 problems
How do I play dvd or vhs on my tv?
Mar 30, 2008 | Audio Players & Recorders
No sound from Receiver
well u nee dto plug the tv in it from tv outs rca to the kenwoods video 1 input ok or tv in and make sure tv settings output is on if it has any
Jan 09, 2008 | Kenwood VR-505 Receiver
What about 6 channels
on the tv there should be Audio An video out Yello,Red,white witch would go on to your reciever, either on AUX, Tv Video so hope that helps
Nov 03, 2007 | Kenwood VR-606 Receiver
VR-606 DTS won't work
All I can tell you is that "CD/DVD" must be selected as the source when using the optical digital input on the VR-606/616. I don't believe it needs more than one input (optical or coaxial) to output DTS sound, assuming the source is outputting DTS in the first place.
Feb 05, 2007 | Kenwood VR-606 Receiver
Kenwood VR-6060 6.1 Channels Receiver Logo
104 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
