Thanks but visually I see no puffed capacitors and I'll check the fuse on its peak as shown as a diode standards
  • Yairo Ramos
    Yairo Ramos Sep 20, 2009
    ilo 27 inch tv and the model is DTV2798
    President:
  • 1,462 Answers
CAn you elaborate your problem , by giving the make, modeln number etc..
leave us comment and will solve your issue
Posted on Sep 20, 2009
Samsung SPL-4225 with Chassis AA98-00188A it comes on then shuts off in 3 seconds. I replaced C405, C406, C407, C408 since they were puffed up, but the problem remains. What other part needs be replaced?
Hi, if you have the service manual, check the power components related with these capacitors (power transistors, diodes, etc), commonly a capacitor is puffed up when receives more voltage than which can handle.
Oct 20, 2013 | Samsung 50 in. Plasma TV
Sansui mdl hdllcd3210 will not turn on.
Did power signal lights appear?If there's no power signal lights,check the fuse,located at the power supply.If the fuse is good,maybe the power supply is dead.There's a leak capacitor in the power supply.Try to replace all the leak capacitor..The leak capacitor can identify through visual checking when you didn't know how to use tester.The leak capacitor is rounded top shape and have moise at the top,compare to flated shape of good capacitor.Thanks,hope will it help you..
Aug 26, 2011 | Sansui 32" TV
BLOWING FUSE , THE IX1791CE IS SHORTED
mostly this problem cause opto coupler is short. change the opto coupler and related parts like transistors,zener diode.and check all diodes&capacitors is power supply. you find any leaky or damaged part change it.
thank you
Sep 03, 2010 | Sharp 21B-S10 21" TV
No power
No fuse, but it may be repairable,take cover off, there should be a protection diode at the end of red wire. To check this you need a ohm meter,check to see if open or burned, check resistors and capacitors around this for burned,puffed-up,etc.Also check the circuit board for burn trace. hope this helps..
Mar 21, 2010 | Radio Communications
MAIN INPUT FUSE KEEPS BLOWING
theres a shortage in the circuit try check the rectifier diodes at primary power supply section, not dangerous to little knowledge,refer to a qualified service technician
Jan 03, 2010 | Samsung TXP3275H 32" TV
Dead Set after power surge
Check the power supply transformer primary driver transistor and the associated components (some diodes and capacitors, resistors, an optocoupler maybe) and the rectifier diodes (or a bridge) and capacitors at the transformer secondary, what you are looking for is a short circuit, however, the short may as well be in another section of the circuit board (a shorted component may sometimes have signs of damage caused by heat, but this is not a rule).
Hope you can find out what it is...
regards
Triarcuate
Oct 01, 2009 | Televison & Video
I replaced all 3 convergence chips, check every
If it had line stright acoss screen thats Vertical IC and Capacitors 100uf 35v ,1uf 50v, 2.2uf 50v Check by hori output Blue capacitor c556 561pf 2kv
Sep 30, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Yuraku LCD TFT Monitor MA7BBA Wont power up
I've had the diods problem on such a monitor recently. To fix it I had to change the fuse and two 1N4007 diods as you can see on the following page:
http://tux12.free.fr/MA7BBA-recovery.html
You will notice I mounted the replacement diods on the solder side ( second hand components with too short leads) and that only 3 diod locations are seen on the component side; the fourth is hidden under the transformer on the top side.
Hope this can still be of any help.
Apr 28, 2009 | Computers & Internet
Blowing fuse
Check for bad caps or diodes. Look for anything discolored or burned.
Dec 11, 2008 | Memorex MT1131 13" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
