Question about Compaq Presario 5000 PC Desktop
I took screws out of cpu fan to clean fan , retainer peices fell out that you mount fan too. I do not know how to put retainer peices back in place so i can mount fan back on.
    Scholar:
  • 145 Answers
All you need to do is to turn locking screws anticlockwise.
This should solve your problem.Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Posted on Sep 20, 2009
Dryer light bulb holder fell out. Can I just put it back up? Wiring looks OK
As long as the wiring is intact retainer will mount back in place just be sure to c you start the machin you start the machine backup
Aug 09, 2012 | Dryers
The freezer is working but the frig. is hot, when is the freezer fan supposed to come on ? How do I test it - I have a multi meter but do not know when it is supposed to be getting power.
How To Test the Evaporator Fan The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer.
Caution: Before testing the fan, unplug the refrigerator to avoid an electrical shock hazard.
The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver.
evapfan.jpg Remove any screws that secure the fan or fan housing so that you can access the fan's wiring. Typically two screws secure the mounting bracket in place (labeled "A" below). It may be easier to remove the entire rear panel if the mounting brackets screws are inaccessible.
Spin the fan blade, it should move smoothly and freely. If the movement is not smooth, the motor should be replaced.
Test the fan for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of zero ohms. If the fan does not pass this test, it should be replaced
Jun 08, 2011 | Haier Refrigerators
Noise from condenser fan. I cleaned the blade and the surronding area. Put some w-d 40 but the noise is still there. It is cold. Should I replace the motor? how hard is it to do? kenmore coldspot...
Go to www.searspartsdirect.com enter your model number and select model number search.
Here you can see a diagram of the unit. The fan motor cost 95 dollars.
It depends on the type of noise it is making.
These motors when failing tend to hum when trying to start which is a sign of a dry bearing.
Rattling sounds or ting ting ting sounds are either a lose fan blade (check the cheap retaining clip on the front of the shaft .. it may have wiggled forward causing the blade to wobble) or a lose mounting screw.
Also I can't tell from the diagram how close the fan is to the drip tray(tray evaporator) These fans not only aid in removing heat from the condenser.. they help evaporate the water in the drip tray.
If you remove the motor.. have it tested before replacing it. At a hundred bucks it's worth a trip to a good electric motor shop.They generally will test it for free.
If you are able to determine the voltage and hook it up out of the cabinet you may save yourself a trip.
Chances are it's a lose mounting screw or that front blade retaining clip.
Best of luck!
Apr 30, 2011 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Is it possible to put the cpu back in the wrong way? i have just cleaned my comp & i removed the fan over the cpu & the video card? i put them back & now i cant get a signal to my monitor could...
If there is no activity when you power up then it could be the CPU.
Remove the CPU and check the CPU to see if you have not bent any pins. The CPU can only be installed in one position.
The CPU when removed usually sticks to the heatsink.
The CPU should be removed off the heatsink.
The CPU is locked onto the CPU chip holder, lift the locking level up to release the CPU or there may be a locking screw instead of a lever. Turn the screw anti-clockwise to release the CPU lock.
Insert the CPU in the chip holder and lock the CPU in place. If it a screw lock then turn the screw clockwise to lock the CPU in place.
Smear some fresh heat sink compound on the CPU and heatsink and place and then lock the heatsink in place.
Sep 25, 2010 | Medion (40010998)
Must heatsink have epoxy before clamping onto mount
DO NOT use anything on the heat sink but heat sink compound!!!!!!!
Jul 21, 2010 | Dell (N1240) Heatsink With Fan
Laptop won't boot turns on then off after about
Your Laptop seems to be full of dust - Maybe your CPU Heat sink FAN cannot turn because if this THUS causing your laptop to heat up and shut down again to prevent your CPU from receiving damage due to high temperature.
Close your laptop lid, then put the unit on its backlcd. Make sure you disconnect the Battery and the A/C Power chord. With the emty battery slot is facing you, take note of the screw that is facing you to the right on the bottom cover. There might be others like this in the same area. The cover that you need to remove is of rectangular shape, and the largest cover.
When you have removed it you should see the CPU Heat sink and a FAN. This is the part where you blow the unit out at that spot with compressed air so that the dirt will no longer block the heat from venting away from the laptop mainboard/cpu.Please check if the CPU FAN is still turning licenly. If it doesn't turn or very difficult - replace .
[ADVANCED]
Then, remove the 3 screws from the CPU heat sink and thereby remove the HEAT sink completely. Remove the CPU Heat sink FAN and clean it as nessesary. Use a small flat to switch the CPU from closed to open and remove it. Then clean it with a cloth and ethanol - make sure you remove all dirt and old heat sink paste on top if it. make sure you do not touch the bottom of the CPU and handle the pins carefully.
When you are done, place the CPU back and reaaply a eyedrop of fresh heatsink paste onto the CPU, lock the CPU switch again. Then clean the backside of the CPU heat sink where it rests on the CPU. When you are done with that, place the CPU heat sink back onto the CPU then screw the 3 screws back onto the CPU heat sink and onto the mainboard. Keep the sequence in mind. Reconnect the CPU Heat sink FAN to power on the mainboard with the cable then place the cover back onto it. Tighten all screws again and reconnect battery and A/C Power chord.
Jun 04, 2010 | Acer TravelMate 4230 Notebook
Makes a noise alomst constantly in the back of fridge. Stops when the door opens, starts back when you close it.
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.
Dec 17, 2009 | Samsung Refrigerators
Hollow, glass on glass knocking noise when compressor is shutting down, lasts almost 2 minutes.Tried tightening the metal case, cleaned coils, all areas under fridge. What next?
Dec 15, 2009 | Frigidaire Refrigerators
Just bought a insignia ns ltdvd26-09 will it mount to wall
I took 8 screws out from back of set just above stand, the bracket fell off.
Be sure to put the screws back in
Feb 08, 2009 | Insignia LCDTV26 26 in. Television
Bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Oct 20, 2007 | Bissell 8910 ProHeat Clear View Upright...
Compaq Presario 5000 PC Desktop Logo
67 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
