Question about Whirlpool LSB6200KQ Top Load Washer
Machine drain problem
The machine washes, but will not drain or go the next cycle
  • 725 Answers
To check drain tilt it up on its back ... reach under the drain pump is in front... two clips on each side and two hoses to remove . check to see if it is plugged.
Posted on Sep 20, 2009
  • 66 Answers
Timer has gone bad,try wd-40 or replace timer.
When using Delicate cycle machine does not drain fully. How can I empty machine before next wash Zanussi Lindo 300
sometimes small items get over the edge of the tub & as you said can plug the pump, most get caught in the hose
Feb 12, 2015 | Zanussi Washing Machines
Machine will not spin or drain
good day?
fully automatic machine? washing cycle is normal?
if yes, do the same.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Whirlpool Washing Machines
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Will not drain and move to next cycle/Lt700xv
Machine washes but will not drain then moves to the next cycle, What do I do?
Feb 08, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LSB6200KQ Top Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
