Question about Lands Phones
How do i block the phone no. - Lands Phones
    Guru:
  • 174 Answers
It depends on the type of phone you are using, if the phone has that services, you will be able to block but if it doesn't then you can call on your network service provider for help by asking their customer care.
Posted on Sep 20, 2009
Can you block a phone number on a Doro 6520 cellphone
Yes you can
How to block a phone number on Doro 6520 - Phone-Info
https://phones.brain-start.tech/block-phone-number/how-to-block-a-phone-number-o...
Aug 12, 2017 - Because you have an Doro 6520, you can also block text messages from a phone number. First, open the application "Messages" and then press the menu button located at the top left of your Doro 6520. Then you will see a list and you will need to press "Settings". Then click "More". You will have access to ... People also ask How do you block a number from your phone?
How do you block a number on a consumer cellular phone?
How do you block a phone number on an LG flip phone?
How do you block a number on a ZTE phone?
Feedback
How to put or remove a blacklist contact on yo ur Doro 6520 - Phone-Info
https://phones.brain-start.tech/.../how-to-put-or-remove-a-blacklist-contact-on-yo-ur-d... Jul 17, 2017 - To actually add the number to the blacklist on your Doro 6520, simply go to the contact containing the number in question, click on the 'menu' key of your Doro 6520, and select the 'block this contact' option or 'add it to the blacklist'. That's it, your contact is now added to the blacklist of your Doro 6520.
Doro 6520 - Turn call barring on or off
https://userguide.vodafone.co.nz/doro/6520...os/calls.../turn-call-barring-on-or-off/ Turn call barring on or off. You can block certain types of calls such as incoming calls when you're abroad. Key in your barring password and press the Navigation key. The default barring password is 0000.
Feb 20, 2018 | Cell Phones
How to block numbers
To block calls, open the Phone app, select Call History, tap the number, then select Block Contact or BlockCaller. To block calls, open the Phone app, select Menu > Settings > Call Reject > Reject Calls From and add numbers. To block calls for numbers that have called you, go to the Phone app and open the Log.26 Sep 2016
How to Block a Number on Any Phone ' PCMag.com..
or go to this link for other phones. How to block numbers Google Search
Oct 28, 2017 | Cell Phones
If we block calls from a number then do we receive text msgs from the blocked number?
It depends on the phone. SOme phones allows total blocking of contacts while others only block calls. You may have to test this with a friend to see what level of blocking your phone supports. If it is a smarphone, you may need an app that allows blocking if your phone does not do it the way you wish
Mar 29, 2014 | Cell Phones
Blocking nuisance mobile phone number
Can no be done. Iphone doesn't have a 'black list' for phone numbers
Nov 06, 2011 | Apple iPhone 3G
How do i block incoming phone call from a uniden cordless phone
  1. Block an Incoming Call
    • 1 Wait until your phone rings and displays the caller ID information 2 Press the "Block" button on your handset.3 Press "Menu/Select" or "Block" to confirm your decision.Block in Standby Mode
    • Press the "MENU" button on your phone's handset.
    • 2 Press the down arrow button to select "Call Blocking." Choose "Create New," "Private Number" (block private calls) or "Unknown Number" (block unknown numbers) from the list.
    • 3 Enter the 10-digit phone number, if creating a new entry. Otherwise, press the "Menu/Select" button to confirm your choice
Oct 14, 2011 | Uniden Cordless Phone
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
Pin blocked
You need to get a PUK, PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it. Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account. It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). More information on unlocking phones will be available here in the very near future. NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone. If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, use the links above to navigate your way to the specific PUK details for your mobile phone network operator.
Feb 03, 2010 | Nokia 5130 Cellular Phone
How do you UNblock a blocked number
Go to menu then initial setting then call block. Scroll to find the blocked number and choose erase. That erases it from the call block menu on your phone.
Sep 17, 2009 | Panasonic KX-TG1033S Cordless Phone
Blocking a phone number
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
hope this helps...please rate...thanks
Jan 13, 2009 | Uniden Cordless Phone
Blocking numbers on cell phone
Unfortunately, Sprint does not have the ability to block single numbers from calling you. We can either block all incoming calls, all outgoing calls, or both, but not particular numbers.
Jun 30, 2008 | Sprint PCS Phone SCP-2400 by Sanyo(r)...
Lands Phones Logo
14 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
