Question about Whirlpool Duet GHW9150P Front Load Washer
Door wont open on my washing machine hoover select 1500
Theres no water in the drum, the cycle has finished, and the light says its finished, but the door lock wont release the door.
is there anyway of overiding the door lock ???
your help would be much appreciated
Paul
I just had the same problem and came here looking for a solution...I went back one last time and tried to unplug. That didn't work. Then I put it on drain/spin and after a minute interrupted by hitting the pause/cancel button - and it released! I am so happy!
Posted on Sep 21, 2009
All the display lights are on and the door won't open but the cycle is not finished
inbuilt lid safety switch wont let the door open till wash cycle is complete and drum has stop all motion
if you cant open the door at all after cycle ends
turn off at the wall
if no better
could be a timer fault or faulty lid switch
May 31, 2016 | Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
My Hoover 750 washing machine does not spin any more. What would cause that and can I fix it with a new part?
Hello.
The answer to your question is YES.
And below is the instruction on how to solve the problem.
The Hoover750 is a washing machine that offers many standard features and a few additional options, including energy saving cycles, variable spin and water pressure options and pre-wash, extra rinse and timer features. Available online and in select appliance, department or home retail stores, the Hoover washing machine should function well with basic maintenance and care. However, if individuals experience problems with the machine, some troubleshooting steps may be beneficial in locating the source of the issue and a potential resolution.
1. Ensure the Hoover washing machine is firmly connected to a grounded power supply if the machine is not working. Reset the circuit breaker if necessary.
2 Turn the main power switch to "On" and open and close the washer door firmly if the electrical outlet has power but the washer is not functioning. The washer will not operate if not turned on or if the door is open.
3 Verify the water inlet hoses are connected firmly and are turned on if there is no water flowing to the washing machine. Straighten out any kinks in the hoses and remove possible obstructions from the inlet screen.
4 Straighten the drain hose if the water is not draining from the unit. Remove any possible blockages from the drain hose. Tighten the hose if necessary.
5 Avoid selecting a "No Spin" option if the washer is not spinning water out of the drum. Choose a new spin cycle and press "Start" to remove water from the drum.
6 Verify that all four feet are touching the ground evenly if the washing machine is rocking or vibrating during use. Adjust as needed.
Thanks.
Feb 19, 2011 | Hoover Washing Machines
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Washing machine wont fill with water-hoover performance 1100
check that the water inlet pipe is not blocked. it does have a filtewhich can get blocked with lime scale.
Dec 27, 2008 | Washing Machines
I have a hoover hsp15 select 1500 that wont spin or drain properly. Where is the filter so I can check that out?
The filter on most hoover machines is behind the kick plate at bottom front of machine.
Post back if further assistance required.
Thanks for using fixya.
Nov 29, 2008 | Hoover H130E Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
664 people viewed this question
Dan Webster
Dan Webster
Sal De
