Question about Sony SA-WX700 Subwoofer
I have two of these units chained together and the second unit only puts out a wisper.
I have checked the cable, followed the troubleshooting guide in the manual without any change. unit powers on and I can hear/feel only a slight output.
  • 1,512 Answers
All of the sound from a sub is below 120 hz. sometimes there is not much to hear from a sub unless the program material requires it.
However, if you have 2 chained together... if they are facing opposite directions to each other they may be cancelling out. you may need to check for a phase switch on the sub and change ONE(that is out of phase with the front speakers) . otherwise, just face them the same direction as your front speakers. try to put them in corners also will boost bass performance.
Posted on Dec 16, 2007
Hi. i have a 36000 BTU Pridiom unit # POM365HX that is showing a P4 error code i was wondering if a service manual , troubleshooting guide was available for this unit.
P4 looks like a conpressor error on the outdoor unit. Possibly a voltage spike, pull the disconnect at the out door unit for 10 seconds and reinsert hopefully error clears. If not you will need to open outdoor unit and get error off of outdoor pcb
Jul 05, 2017 | Heating & Cooling
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times... Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
The red LED will flash as described below under the following
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
Sep 09, 2013 | Kidde 9000102 Night Hawk Combination...
I get set 3 when i press the remote and nothing else no matter what i press play etc any suggestions
Try reprogramming the remote so it matches the unit. If you get SET 3 or DVD 3 on the display, chances are the remote's command code is different to the unit, in which case the following may help a bit:
Ensuring new batteries are in the remote, correctly polarised ( + and - ) and with the remote pointed at the unit (while unit is on), press and hold both the [3] and [ENTER/OK] buttons TOGETHER for 5 - 10 seconds, then release. The remote should now fully control the unit.
If it doesn't, check the batteries and repeat the above. The above procedure is a suggestion based on Panasonic DVD recorders and their operation troubleshooting manuals. Give it a try at least.
Aug 14, 2011 | Panasonic DMPBD45 BluRay Player
Just changed blade and it wobbles itself loose. can't find any user manual or guide online and plasplug website has no email- just phone, fax or snail mail. i'm looking for a diagram to make sure...
You need to set the tension on the chain to where the chain is tight to the bar.
Loosent the bar nuts, and then screw the tensioner until the chain has no slack. Then retighten nuts.
Jun 06, 2011 | Garden
How do you install a thermo scientific multiskan ex reader
1. Buy The Unit from Thermo, Thermo Distributor or @ Indonesia you can buy from Elokarsa, PT
2. Unpack the good
3. Unpack the unit from the plastic/aluminium warp
4. Unpack the other part from each plastic pocket
5. Check all items by referencing of items check list letter
A. Open the units by unscrew the bold on left and right side using L key (including in item list with 2 fuses)
B. Open the filter wheel and place inside the reel housing
C. Put halogen lamp inside the housing and connect power cable (do not touch the internal lamp directly by hand / finger)
D. Close the unit by screwing these bold
E. Plug power cable, in unit (rear right unit, side of power switch)
F. Power on the unit, leave 15 second for the initialing and autocalibrating
G. The mini dot matrix screen should be showing the unit software version and word "Ready"
H. Push the param button on board, set the periperal by your self, like the manual
I. If the unit does not have a trouble, you ready to connect the unit using data cable (include inside the box) and direct connect to PC using RS-232 rear of PC or you must using USB-RS232 adapter for help an connection, install the Ascent Software on PC using Ascent Software CD including the box, choose "multiskan" and follow the instruction.
J. Finish, you can learn by doing, guiding with manual book (white one)
Good Luck
ST - Elokarsa Techinical Support
Nov 19, 2010 | Health & Beauty
Hi!! i have a whirlpool duet front and she stop in the middle of the cycle and mark error f11 cant someone help me please and thank you
Hello there:
I am very sorry for the problem that you are having
Please follow the information that i have put together for you and hopefully it will help you troubleshoot this a little bit better ok?
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
May 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to turn it on? wisper cool
Try this :
Jul 08, 2009 | AdobeAir WisperCool MMB8 Portable Air...
Press button to open garage door, doesnt work
may have stripped gears. take off light panel and look inside. white powder. bad gears. repair if yu are handy, if not, buy new unit.
Jan 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
You might be having problem in following area 1. Check the cable first. You can use the cabe tester. If cale tester is not available then chek the cable with multimeter. 2. Check the port wher you have inserted the patch cord. It should be in uplink port of first hub and normal port of second hub. Try this and revert back with results.
Feb 08, 2007 | Cnet CSH-2400 24-Port Ethernet Switch
Jamo DVR 50 Frozen?... Solutions?
I have the same frozen problem vith Jamo DRV-50.
But I found this:
Its a swedish site for electronic repearments, Jamo DVR-50 have problems with heat also and capacitors in the power suply unit goes burned. So the instructions are:
1.Simptoms:Various strange error
2.Solution: Replace the capacitors in the power supply, especially C30 470μF/ 10V, C31 2200μF/ 10V and C16 1000μF/ 10V.
My service guy already told me that some electrical parts in the power supply unit are burned, he replace them and succeded to powerOn the unit but still jamo have problems staying powered on and now im going to tell him to replace those capacitors C30, C31 and C16, and i hope this will work.
Oct 02, 2006 | Jamo DVR-50 System
Sony SA-WX700 Subwoofer Logo
77 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
