Question about Whirlpool Duet GHW9150P Front Load Washer
F35 code? appears and then the washer just sits there with the f35 code blinking.....
The wather level switch needs to be replaced part number W10249845 which is not available. My duet is less than 1 yr old and I have been dealing with Advantage for 30 days to get this fixed. I am now waiting on a full refund for the washer since they cant get this part from 2 manufactuers. We now have to buy a new washer for 500 more and by the way the stack shelving that I purchased with this washer does not work with any new WP FL Washer there is another 400 plus the new warranty. Whirlpool should bite the bullet and do a recall.
Posted on Sep 20, 2009
Testimonial: "Thank you for your help."
What does F35 code mean and what to do?
  • Run an empty cycle without using any detergent. Often the fault code displays when too much detergent is used and the detergent sits in the drainage system. A cycle without any detergent is often enough to clear out the buildup.
  • 2 Pull the drain hose out of the standpipe mounted to the wall behind the washing machine. Complete a visual inspection of the hose for any clogs. If you see any, remove the screw that holds the hose clamp onto the discharge pump and then force water through the drain hose with pressurized water from a garden hose. Reattach the hose and then run an empty cycle to see if the code goes away.
  • Read more : http://www.ehow.com/how_11368049_fix-whirlpool-washer-f35-code-alert.html
    Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    Washer stops and blinks F35
    This is a faulty analog pressure switch. Remove top by removing screws in back of top. The switch hangs from right side of cabinet top. d8aedaad-1c15-4a3f-abda-867f2b851658.jpg
    Remove hose and plug from switch. Rotate switch quarter turn to remove.
    Dec 19, 2013 | Washing Machines
    Kenmore elite he 3t model# 110 46747801 blinking sud and then f35
    Hello, welcome to FixYa.
    The F35 error code (can also be associated to the "Sd" or suds error) on most not all ...Whirlpool built front load washers indicates the control has detected an analog pressure sensor (also commonly known as a wter pressure switch) error.
    Whether the sensor is faulty or not remains to be seen, here's what to check first.
    **Unplug the washer from the wall before servicing...safety first**
    This error "F35", can be caused by the air pressure tube being blocked or kinked between the bottom of the washer tub and the analog pressure sensor, examine by removing the top and back panels and inspect the hose and dome, i.e.
    If you find a blockage, kink, cut/torn hose or loose connection in tube, then this is the likely cause the error. If it however appears okay, then you will likely need to replace the analog pressure sensor, i.e.
    As I alluded to though, make sure the hose is clear and not cut and the air-dome at the tub isn't plugged and if not you'll have to replace the switch.
    Let me know how you make out and I'll help further in any manner I can. Good luck.
    Regards,
    Macmarkus :)
    Jul 27, 2011 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 46742 washer will not wash. It starts to fill and then SUDS or F35 appears on screen. It will not move through the cycle.
    The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. The analog pressure sensor is Key 38 in the first image below. With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced.
    Jan 23, 2011 | Kenmore Front Load Washer
    F35 appears. What is the problem and how to fix?
    F35 is a water level error.
    The water level switch (pressure switch) has malfunctioned.
    If you remove the top panel, three screws in the back, you will have access to the pressure switch.
    With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
    If the fault codes return after doing this, you will likely need to replace the pressure switch.
    Also - please be sure to use He soap.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%^
    May 08, 2010 | Kenmore HE2 Plus Front Load Washer
    Kenmore Elite front load washer stops and blinks F35 and locks up
    f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
    Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
    Just bought Kenmore elite washer and upon initial wash I got F35 blinking code and the washer stop working. What does this mean?
    Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
    F35 code appears, even after changing the steam chamber.
    IT IS THE ANALOG PRESSURE SENSOR NOT THE STEAM CHAMBER.
    May 27, 2009 | Kenmore Washing Machines
    Kenmore Elite HE5t Error Code F35
    we have a kenmore HE2 Plus washer, front loader. been getting F28 code for last several months. usually we can push cancel button, and it clears, unlocks the door, we restart and complete the wash. But now it is locked and we can;t clear it. have even unplugged the machine over night, it still will not reset. any ideas?
    May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Whirlpool front loader
    I've had this same problem and had a service man come in. The reason for the colde is an over-gunked up machine due to the directions for amount of soap to use on he bottles being incorrect.
    Run the washer empty several timres with just vinegar in place of the soap and then repeat with bleach. I've been told this will take care of the problem, but it may take many cycles before the codes will stop appearing.
    Also, from then on, only use 3 tablespoons, yes 3 tablespoons or 1 ounce of detergent per wash. The 1/4 cup that most he detergent bottles tell us to use is way too much.
    Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    239 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
