Question about Sony Playstation 3 (PS3) Console
My mates PS3 is stuck, he tried to install Linux (Ubuntu) and trashed his harddrive when he attempted to put the firmware back on from a Memory stick! I've ordered a new disk, how can I be sure that it won't trash the new (320Gb) disk?
  • 2 more comments
  • jon5888 Sep 22, 2009
    Magicbyrdman pointed out the ways of installing Ubuntu. I only knew about using the Install Other OS option and unfortunately wasn't around when my friend decided to take his chances and wade in:-)
    Does anyone know if Ubuntu installs anything in the hardware, because I want to be able to return it to it's original state - I feel bad for suggesting Ubuntu and giving him a disk with it on and I can't just leave him with £300 worth of bookshelf art. :-(
  • jon5888 Sep 23, 2009
    Thank you for your comments, they are almost exactly what I was needing to know. I would like to try and install Linux, but it helps to know that I can restore the system completely. Well done Sony for keeping everything so well compartmentalised. :-) I'll let you know how I get on when the Disk arrives on Friday.
    thanks aswell for the screen codes as my mate doesn't have HD yet they will be just what I need to set up a readable screen.
  • jon5888 Sep 25, 2009
    Disk arrived today in a Jiffy...bag!
    But thanks to your advice, Everything worked.
    New Drive straight in, couldn't rebuild the system automatically so I downloaded the latest update from SEC and put it on a memory stick. The repairs then ran from the memory stick and formatted the system partition for me.
    So, don't try and format the drive before you install it you'll only waste your time.
    Novelist:
  • 149 Answers
Did you install ubuntu from ps3 boot loader or was it an install of ubuntu then stick the hard drive in the ps3. cause the only way to install another os is from the install other os option even if the drive is partitioned ps3 has to lock the hard drive to the ps3 witch requires reformatt
Posted on Sep 22, 2009
Testimonial: "Thanks, I believe that is the way to do it. My main concern is that I won't be able to restore the PS3 software now that I've got a new drive!"
  • Kevin Byrd Sep 23, 2009
    the ps3 software isnt on the HDD itself you can always re-install the firmware. the other drive may not even be bad a way to test it is.
    Put the ps3 in standby mode(red light) press and hold the power button till you here a "double beep"
    on mine i have to hold the power button and it will give a "beep"......then another "beep" then go into standby mode again just release the power button and press and hold it again real fast now it should "beep" ........then "double beep" and release the power button this brings up the recovery consol where you can install the firmware again. i would download the newest firmware first just to make sure it wast a corrupt file. and see if it boots and formats the HDD if not from that same recovery console you can rebuild the file system and rebuild the data base and restore the ps3 to original state. after everything is formatted right download the ubuntu for ps3 and the ubuntu os bootloader for ps3. the bootloader is usually on the same disk image as the OS for ps3 so just put the Ubuntu for ps3 disk in the drive and choose the setup other os option and it should find it then choose boot other os with the cd still inside it. once ubuntu gets installed though you will want to adjust the display because its a pain.
    just edit the kboot.conf file where it says
    ubuntu="/boot/vmlinux initrd=/boot/initrd.img video=ps3fb:mode:X"
    where "X" is the number of display you would like to have
    example of YUV at 1080i would be
    ubuntu="/boot/vmlinux initrd=/boot/initrd.img video=ps3fb:mode:4"
    here are the dispay numbers
    0:automode
    YUV 60Hz 1:480i 2:480p 3:720p 4:1080i 5:1080p
    YUV 50Hz 6:576i 7:576p 8:720p 9:1080i 10:1080p
    RGB 60Hz 33:480i 34:480p 35:720p 36:1080i 37:1080p
    RGB 50Hz 38:576i 39:576p 40:720p 41:1080i 42:1080p
    VESA 11:WXGA 12:SXGA 13:WUXGA
Once removing my old harddrive and putting into a Amicroe USB 3.0 SATA External HD Aluminium Enclosure it asks to format before use losing all my harddrive i was trying to save. Is there a way to repa
What OS are you using? If this is a Windows system (or non-Apple, at any rate), what does the BIOS say about the HD size?
Something has become corrupt. You might not make it out "alive".
Sep 27, 2014 | Computers & Internet
How was the msi on the 90's?
Go online to find experts that may guide you step by step.These menonline may show you how to fix your console just as an experienced repairmanwould fix it. Allthese errors can be fixed completely by you without the involvement of anyexternal agency. Disassembly 1.PS3 Disassembly 2. PS3 Controller Disassembly Fix Common Problems Fix to all update related problems 1. The Mystery of the Blinking PlayStation 3 2. The dirt on Blu-ray lens (and how to clean it) 3. PS3 Owners Report Blu-ray Problems After 1.5 Upgrade 4. PS3 Bluetooth Controller Issues 5. Playstation 3 HDMI Problem and Fix! 6. Display/Video Fixes 7. PS3 Error Codes (With related fix) 8. How to Change From HDMI > Composite Easier 9. PS3 3 Beep & Blinking Red Light Fix PS3 Modifications 1. PS3 3.5" SATA HDD Mod 2. Adding IR Remote Control to the Sony PS3 3. PS3 HDD Replacement Mini-Guide 4. USB Flash Memory, USB Hard Drive (External Use) Controller Modifications 1. PS3 Controller Light Mod 2. PS360: Microsoft Controller, Meet Sony Controller 3. PS3 Controller Light Mod 2 4. PS3 Controller Button Contacts, Add extra buttons to the PS3controller Other Modifications 1. Charging Station Headset Mod Blu-Ray 1. Decrypt Blu-Ray Movies with a PS3 WITHOUT keys 2. Blu-Ray Unique Volume Keys 3. Blu-Ray Media Links 4. Play BluRay movies without disk 5. Convert HD-DVD To Blu-ray (works On PS3), No Loss Of Quality Other Media/Video 1. Set up media servers for your PS3 2. Transfer files from PC to PS3 via WmP11/Nero (viaDLNA/MediaServers) 3. How to stream AVI files on PS3 via Tversity 4. Copy music/videos from your iPod to PS3 5. Getting your PS3 to recognize your External Hard Drive 6. How to create a PS3 HD-MPG from HD-TS (Best Result For Below 1.6FW) 7. How to install your game saves 8. Downloading PS3 Game Saves Audio 1. How to connect PS3 to PC speakers Networking 1. How to change from 'NAT type 3' to 'NAT type 2' 2. Make a Lag Switch 3. Who Needs SIMPLE DNS 4. Remote Play On-The-Go Playstation Network 1. PSN Game Sharing Instructions 2. How to download Japanese Demos/Create *** PSN account 3. Create Different Region PSN Accounts 4. View PS3 Store, Download Demos on your PC and install Demos To PS3 5. Play Online And Access Sony Store No Updating 6. View Playstation store on PC Firmware Modifications 1. PS3 Firmware Version Check Bypassed (Linux) 2. PS3 Firmware Version Check Bypassed (Windows) 3. Ettercap Windows 4. PS3 Demonstration Mode "Unlock" Code 5. Use SIMPLEDNS To Bypass The Firmware Check (Windows) 6. How to UPDATE your PS3 Linux 1. How to install Fedora Core 6 Linux for PS3 2. PS3 Linux - The void has been filled...Full install instructionsfor Fedora Core 5 3. PS3 Linux FAQ 4. GUI Kboot 5. Yellow Dog Linux Free Version 6. Yellow Dog Linux 5.0 Installation 7. Partitioning and readying your PS3 for Linux 8. Gentoo 9. Uninstalling Linux 10. Installing YDL+VLC+Mplayer+Snes9x 11. Installing Mplayer on PS3 12. Installing VLC player on PS3 13. Installing "Other OS" on PS3 14. How to get Wi-Fi to work with YDL 15. Set up a Linux UPnP media server w/PS3 support 16. Run Ubuntu Linux 7.04 (Feisty Fawn) on PS3 17. Ubuntu, Kubuntu, Xubuntu, and Edubuntu onto a PlayStation 3 18. Emulate WinXP in PS3 under Linux Downloads 1. Homebrew Loaders 2. Linux 3. Utilities 4. Firmware Updates 5. "Other OS" Bootable Homebrew 6. Drivers 7. Proof-Of-Concept Exploits 8. Game Saves PS2/PS1 on PS3 1. Do your PS2 games look too jaggy on the PS3? Here's a semi-fix... 2. PS3 SWAP to play PS2 and PSX Games! 3. How to play/install to play PS2 backups on PS3 Miscellaneous 1. PS3 Features 2. Finding RAM locations on resistance 3. PS3 Parental Controls How-to 5. PS3 BiOS Flash Diagram Rev 1.0 So,if you have experienced some of the errors in your console, it is not the endof your gaming days, you can fix it. There are many solutions out there if youare willing to do a little research. This guide most possibly willcontain the solution to the problem you have encountered.
Ps3 repair guide Goodluck, and happy gaming.
Feb 08, 2011 | MSI 1990 - 1996 for PlayStation 3
I want games free
Feb 08, 2011 | EA - Electronic Arts Need For Speed:...
I lost my biohazard4 game CD key.... Can u Post key to my email ID: balumahesh8055@gmail.com
Feb 05, 2011 | Capcom Resident Evil 5 for PlayStation 3
FUJITSU SIEMENS ESPRIMO Mobile M9410 stalls on several windows platforms, but not on linux ubuntu. Whenever i watch a movie or listen to music its most noticeable, it just hacks the song/movie for a second...
It sounds like the memory is the issue. Windows handles the buffering in a different manner. You are noticing the "buffering"
On top of that Linux has a smaller memory footprint in most cases than windows so there is more real memory to go around. Swapping to the harddrive tends to cause stuttering. You might try killing some PID's in windows and seeing if the freed up memory helps.
Good luck
Joe
Jan 08, 2011 | Fujitsu Siemens ESPRIMO MOBILE M9410...
T30 working with 1/2 memory RAM
WoW!, Ubuntu Lover.
Thums up for you Man, Live Free, Linux for Human Beings.
Regards,
Waqar.
Aug 06, 2009 | IBM ThinkPad T30 2366 Notebook
Computer- reformat
In order for the computer to work, and for you to reformat the harddrive, you will need a bootable disk, either one which has a drive utility on it in order to reformat and partition the harddrive or an operating installation disk which includes a drive utility (any windows installation disk has it) - without one you will neither be able to properly reformat the harddrive nor install an operating system on it in order to use the computer.
As you have stated, this is obvious, and your problem is that you do not have an installation disk. A restore disk would not help if you reformatted the harddrive.
You can either purchase a Windows operating system disk, find one (no, not anything illegal - I have spare copies of windows and all of my geek friends have spare copies, because frankly of issues like this),
or download a copy of Linux and burn it to a cd - Ubuntu is a decent choice for a starting Linux user, and is very easy to use (works alot like windows, has tutorials, etc) and is completely free - you can do a search for Ubuntu Linux on google and you will be able to download a copy which can be burnt to disk or request a disk be sent to you, though I cannot remember if they still send free Ubuntu disks out.
Linux typically runs very well on limited resource computers such as the one you are in possession of. Did I mention it was free? If nothing else, you can use it to reformat the harddrive using their Live Boot disk - it allows you to use the Ubuntu operating system without installing it. You boot from the cd and can use their harddrive utility, or install Linux to the harddrive, or just check it out to see how it works.
Dec 14, 2008 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
How to install linux on compaq presario cq40-144tu
hrm... i'll just assume that this is the first time you've attempted anything with linux? There are vairous Linux distributions, with the Ubuntu flavour seeming to be the best one for the windows to linux switcher (IMO). I would try a live Ubuntu disc first to make sure it's what you're after, which can be downloaded here
http://releases.ubuntu.com/intrepid/ubuntu-8.10-desktop-i386.iso
or if you're ready to dive straight in, here is the full version that you burn to a cd and then install
http://www.ubuntu.com/getubuntu/download
Nov 29, 2008 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Ubuntu Linux Boot Problem
it'll be faster if you trash & re-intall
Aug 18, 2008 | Canonical Ltd. Ubuntu
Use with Ubuntu linux?
Unfortunately the Veo Advanced Connect ( model 642v ) ( ID 0x0545 : 0810 ) has some proprietary firmware inside on the chip , and so far there has been limited success in making a proper driver for it.
You could wait and see if some one does get a driver out for it but I have been looking for 2 years and not had much luck. I would recommend trying to get another web cam that is compatable with linux, or that already has drivers available.
Jun 18, 2008 | Veo Advanced Connect Webcam
Sony Playstation 3 (PS3) Console Logo
371 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
