Question about Toshiba Satellite A100-S8111TD Notebook
My fan does not seem to be working on my toshiba equium a100
  • 3,153 Answers
Fans do not STOP !
They may switch speed in relation to the temperature but don't STOP !
It may be that your fan is clogged up as happens a lot with newer laptops.
There are a couple of approaches
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here
Do this outside with glasses on.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
It is preferable to have the battery and ROM drive removed but many get away without doing that.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
Additionally it is preferable to use a newer laptop with a cooling pad (3 fan preferred and with its own power supply when possible)
Don't sit laptops on cushions carpets or other soft items. they **** up minute fibres and particles which clog up the cooling.
If you continue to use it you may find it gets slower toactually use or worse it could cause motherboard and CPU damage.
If you are unsure a good laptop repair shop will do this at a reasonable price.
Posted on Sep 20, 2009
  • 60 Answers
Laptops are equipped with automatic fans switched on/off by a heat sensor, which turn on due to increase in temperature of processor. If u r working in a cold environment like in an airconditioned room, it might never turn on. Its ok if u r not facing any problem. If so, then tell me again. Hope this will be helpful
3 Suggested Answers
abhi_patil
  • 569 Answers
SOURCE: toshiba a100 freezes
check the power adaptor
give a check to your battery also
instead of doing it urself i suggest to show it to a service person
Posted on Nov 23, 2008
  • 7 Answers
SOURCE: Replacing screen on my toshiba equium a100 306
this is not the same model but i think you will get the idea.
http://www.fonerbooks.com/laptop_5.htm
Posted on Jun 17, 2009
I have toshiba equium a100-338 and the power button will not work
The cable (Wire) stays attached to the Power Button Board,
http://www.ebay.co.uk/itm/2270-POWER-SWITCH-BUTTON-TOSHIBA-EQUIUM-A100-/221111621689?pt=UK_Computing_Other_Computing_Networking&hash=item337b479839
No, I'm wrong? The Flat Flex Cable (FFC) does come out of a ZIF connector on the Power Button Board?
You may wind up buying the Power Button Board, and Flat Flex Cable, then.
Or you may find a 'Mom and Pop' computer store, that can repair the cable.
Regards,
joecoolvette
Aug 21, 2012 | Toshiba Equium Computers & Internet
Toshiba equium a100-147 service manual
This is the path:
http://eu.computers.toshiba-europe.com -> Support & Download -> Toshiba User Manual
Feb 07, 2011 | Computers & Internet
I have a toshiba laptop equium a100 laptop want to restore back to factory settings how do i do this
The best option is get a restore disc from Toshiba, I've done this a few times and it is a very easy process. Once you have the disc just boot the laptop with disc inserted and away you go!!.
Look here :-
https://backupmedia.toshiba.eu/
Jun 27, 2010 | Toshiba Satellite A100-S8111TD Notebook
My Equium A200-1V0 fan stopped working
The User's Guide is available on this page on the Toshiba website, under the User's Manual tab.
I have also compiled a tip for dealing with overheating issues on Laptops as that is a common issue.
You may please refer to this link for reviewing the same.
May 10, 2010 | Toshiba Satellite A100-S8111TD Notebook
Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
hold ctrl+alt and press the up or down key to change the screen to its original position
May 05, 2010 | Toshiba Equium 100 PC Desktop
Hi, just thought I'd let you know that when I got my Toshiba Equium 200-1V0 it was supplied with the User's Manual A210 Series. The manual is just basic and does not go into full depth of how to clean out heat sink etc. The problem you described regarding the shutting down is most probably that the heat sink is clogged up with dust and needs to be cleaned. Toshiba has a lot of laptops (different models) with this problem. I had the same problem with Toshiba A200-1V0 and have now got the same problem with the Toshiba A300D-20R which is only 6 months old! On the A200-1V0 I managed to hoover the bottom of the laptop where the fan is and it worked fine, but with the A300D-20R it has not worked, but fortunately it's still under guarantee so I will be sending it back to Toshiba to do it. Here is a link to download the Manuals. You will find the Manual for A200-1V0. Hope this helps. http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK
Mar 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
DVD ROM won't read disks . Toshiba Equium
YOU SHOULD GO THO TOSHIBA SERVICE CENTER AND YOU CAN REPAIR IT ON ANY COMPUTER SHOP
Oct 20, 2009 | Toshiba Equium 100 PC Desktop
Toshiba a100 freezes
Nov 23, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba equium A100-306
try function key for lcd it may be in presetaiton mode by mistake
or is lcd on / come on bright then go dim / dark just very dim if so your backlight is out replace lcd
Oct 24, 2008 | Toshiba Equium 7100S PC Desktop
Toshiba Satellite A100-S8111TD Notebook Logo
227 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
