Question about Frigidaire PLD2855RFC Dishwasher
What does Frigidaire dishwasher timer code "Hd"stand for? It's not listed in the manual and I couldn't find it listed online. If it's just a "Hold" code (which is what I suspect) for extra washing time, what would be causing that? I'd like the shortest wash time possible to save $$$ and resources. Model number is BGBD2432KFO. Thank you.
“HO” or “Hd” means the dishwasher’s cycle time is being extended while it is heating water. At certain points in the wash cycle, the dishwasher uses hotter water to ensure a clean load of dishes. If it detects that the water is not hot enough, it will heat it.
If you’re seeing “HO” or “Hd” frequently, check the temperature of the water available to your dishwasher. It’s best to do this at the sink closest to it, allowing the hot water to run until it reaches its maximum temperature before you test it with a thermometer. For best results, water should be not less than 120°F.
Posted on Jun 13, 2010
Hold to lock button how to unlock manual no good
Thank you for your post, friend!
I see that you are having trouble with the control lock feature on your Frigidaire dishwasher. I would be happy to assist you with unlocking the dishwasher. In order to provide you accurate assistance I would need your model number. You can locate the serial tag (which lists your model number) on the inside left hand wall of your dishwasher. I look forward to helping you out. -Matt
Feb 16, 2015 | Frigidaire Dishwashers
How do I find out the error codes?
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Nov 05, 2014 | Frigidaire Dishwashers
Wash cycle knob
It's a quirk of the cycle timer. You can replace the timer ($) or live with it. Besides, a replacement might have the same quirk
Jul 15, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire model number gld 2250, gld 2240
read your owner manual section troubleshooting and see the
problem for e.codes.
if you do not have it download from www.retrevo.com
or get support from frigidaire via online, chat or phone
God bless you
Sep 24, 2012 | Frigidaire Professional Series 24 in....
Frigidaire Signature Series Stainless Steel Dishwasher # PLD8998AA1 door springs don't hold up any more
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Feb 23, 2011 | Frigidaire 24 in. PLD2850 Built-in...
My 24 in dishwasher the timer is not working correctly and is not cleaning the dishes, also water is standing in the bottom of washer at the end of the cycle.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Nov 16, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Need 2 casters
Is the model number FMP330RGB as listed at the very top? That number does not cross.
There are the parts listed as wheels / caster for Frigidaire:
http://www.repairclinic.com/Frigidaire-Dishwasher-Parts?s=b2a9c252
If you need more assistance just respond here with the complete make and model number and we will help you.
Thanks for using FixYa.
Kelly
May 12, 2010 | Frigidaire FMP330RGB Free-Standing...
Calcium build up
Here is the manual in PDF
http://www.retrevo.com/support/Frigidaire-FDB510LC-Dishwashers-manual/id/1060bh934/t/2/
For the calcium,you can try TANG drink mix.
There also is a product called Restore 4, but it has a lot of fumes. It removes deposits. Get this at a home store, or online.
Sep 16, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Jan 03, 2009 | Dishwashers
Frigidaire PLD2855RFC Dishwasher Logo
10,351 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
