Question about Car Audio & Video
Speaker hook up
How do u know how many oams is a speaker its a d 3
All car speakers are 4 ohms these days and house speakers are generally 8 ohms
Posted on Dec 14, 2007
Can you have just 2 channel by hooking up to right & left front speaker posts on 5.1 surround
short answer.....no. If you hook more than one speaker up to a single channel, it will lower the impedence and will damage the amp. You can hook up multiple speakers by using a speaker switch box between the speakers and the amp. This will match the impedence and should keep the amp from blowing.
Dec 21, 2014 | Panasonic Technics SA-G76 AV Control...
My rear passenger speaker wires don't work, I have connected 3 different speakers to them none of them work but those 3 speakers work when they are hooked up to different connections.
have you tried connecting directly to the radio? I would suspect a broken wire or a bad fader control or switch depending on the model.
Jan 31, 2012 | 1998 Ford Expedition
I have a mazda 3 2005 the trunk relese will not work the key will open the trunk
need to check the trunk switch to make sure it working and is getting fire through it, i would use oam meter or test light, if it is not check fuses if it is check for fire at trunk release if it has fire change electric lock.. (dealer item)
Mar 21, 2011 | Mazda MAZDA3 Cars & Trucks
Hi. Today I bought a 3 foot audio y-cable and an RCA (Phono) Female to RCA (Phoneo) Female cable so that I could hook up these two speakers that I have that belong to a predisian sound system (boom box)...
All you need to do is get a USB based sound adapter 16/32BIT MINIMUM to plug your speakers straight into your laptop with better sound. Many laptops will have limited sound OUTPUT which places large limitations on pushing sound through your nice speakers. You already know the problem is not the speakers or new cables, therefore you know that problem has been isolated to your laptop. You may also check the volume settings in the laptop to ensure your running the highest possible BIT or volume enhacement software. Let me know if this does the trick for you.
Jan 09, 2011 | HP Audio Players & Recorders
Don't know how to put it back on wash,as it stuck on dry.
TRY TO TURN OFF POWER 4 1MIN IF THIS DONT WOK CHEAK OAMS ON HEATER COIL AND THERMOSTST
Jan 31, 2010 | Dishwashers
I need to know how to hokk up speakers with it
Hooking up a speakers to the monitor depends on the connections that you have.
1. What type of speakers do you have? Is it a regular computer speakers (2-channeled or multimedia)?
2. Does it have a 3.5mm jack or an RCA jack?
3. Does the monitor has a speaker ports?
If the monitor doesn't have a speaker ports were you can connect you speakers, then it's not possible. Meaning that you could only connect the speakers to the computer.
Aug 04, 2009 | NEC Computers & Internet
I have problem with my Internet connection
yeah i had that problem 2 days ago go to 192.168.254.254 and type in your user name and password click save settings and if you see the connect button press connect and if that doesn't work try getting a ball point pen and press down on the reset button for 5 seconds and it will have a flashing light on the last thing and that means it's powering up try it again until 3 solid lights come on and the last thing is flashing
May 22, 2009 | Siemens SpeedStream 4200 (13A4200001)...
I dont know how to get my speakers working
The audio cable on the speakers should go into the green audio port on the back or your PC. Once that is plugged in, if you still don't have sound go into your sounds and audio devices in the control panel and make sure the volume is not off or muted.
Mar 25, 2009 | Ozaki DT-500 3-Piece Speaker System...
BT ADSL prob: ATM OAM F5 segment ping - OAM F4 FAIL
are you using the router through a BT line? if you are BT will be able to sort this problem for you by sending the router an update that it sounds like it needs
hope this helps
Nov 20, 2008 | Computers & Internet
Car Audio & Video Logo
110 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
