Question about Maytag MGR5750 Gas Kitchen Range
We got another range to replace old one,the old one has converter kit for propane,can we use the old one and what do we do next
  • 744 Answers
Make sure the range you want to use propane with is rated for the use - contact the store or consult the manual. The gas jets are different for propane and natural gas. Please be careful.
Posted on Sep 20, 2009
Wanting to change propane stove to natural gas,need parts to do that
Most ranges can be converted with the orfices being changed.Newer ranges have the orfices under the top.Older ranges can be convetrted by drilling the orfices larger.(propane orfices are smaller than natural gas.Sears can sell you a conversion kit if you know the model and serial #.Most Gas companies will convert it for a fee.
Mar 05, 2014 | Kitchen Ranges
Ge j2s968 convert to propane
On the back of the range there should be a conversion kit with intructions on how to convert from natural gas to l.p. good luck..
Nov 05, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
How to convert Maytag Model MGR5870 from natural gas to propane
you would have to find out from the manufacturers if there is a burner kit to convert from natural to propane... it usually involves replacing the gas jets...
Dec 22, 2009 | Stoves Kitchen Ranges
Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
Aug 31, 2009 | Thermador PGR366 Gas Kitchen Range
I want to convert to propane. Rinnai dont carry kkts for these anymore . . . . are there any way to convert these?
i want to convert one to natural gas from LPG would u like to swap the pilot assy and jets i cant find a conversian kit anywhere...
Apr 23, 2009 | Kitchen Ranges
Converting to propane
Call Dynasty / Jade ph # 800-884-5233 order convert kit from Nat to LP. Flip the cap on the gas regulator from Nat to LP, talk with Brad @ Dynasty if you needed help. Have fun.
Mar 22, 2009 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
Oven currently runs on propane
Yes. It may be necessary to purchase a conversion kit if the original kit was not retained.
Still cheaper thean a new range.
Mar 12, 2009 | Whirlpool GS460 Gas Kitchen Range
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Maytag MGR5750 Gas Kitchen Range Logo
107 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
