Question about Nokia E71 Smartphone
New sim in phone but got unlocking code - Nokia E71 Smartphone
How can i unlock sim to use on diffrent carrier
SIM cannot be used on another carrier, but your phone can be unlocked to use another carrier's SIM. You can also transfer your existing number to the new SIM by contacting your existing carrier and requesting a PAC code. Then contact your new carrier and give them the PAC code to transfer the number.
Any contacts stored on your current SIM can be copied to the phone memory or exported as a file, then copied back to your new SIM if required.
May 05, 2016 | Cell Phones
When i have locked my phone they ask pin code incorrect enter pin code so what i do a
If your SIM card is PIN locked, the network unlock code is useless. The network unlock code allows a phone that is restricted to a single carrier to be unlocked for use in other carrier's networks.
The SIM PIN is a personal identification number that is used to unlock the SIM card in order to register it to the network. This means that the phone will not connect to the network before a SIM is unlocked. Usually (at least around here) a new SIM has a simple PIN, like 0000 or 1234, and the user can change this. However, the carrier doesn't know your PIN, so if you forget it it can't be reset from the carrier directly.
If you happen to forget your PIN, the only way to unlock the SIM is to enter a wrong PIN enough many times (3 or 5 usually), and after this the SIM asks for the PUK (Personal Unlock Key) code, which is sometimes referred to as PUK1.
The PUK code can be obtained from the carrier, after they verify you are the rightful owner of the SIM and contract. If the SIM is a prepaid, the PUK code is sometimes printed in the card holder. After you get the PUK, enter it into your phone and enter a new PIN. After this, you can unlock the SIM with the new PIN you specified.
Note: DO NOT try to guess the PUK code yourself, if you enter it wrong three times, the SIM will be permanently locked and you'll have to get a new SIM from your carrier.
Jun 27, 2015 | Nokia E5 Cell Phone
I forget my icloud password how do i reset my phone with new sim
The unlock code and the sim code are two different things. Unlock the phone with the normal unlock code, then it will say your sim is locked. Then use the new pin on your sim.
Mar 15, 2015 | Apple iPhone 4S
I dont know the phone lock code but if i put old 1 sim it works
The lock does not appear to be on the phone as the old SIM works. The lock is in the new SIM. You have to call the phone company or if you have the PUK code for the SIM you can go to the phone company's website and check how you can unlock the SIM card.
Sep 03, 2014 | Nokia Classic 2700 Cell Phone
New sim card and new phone. But nothing works. Is there anything regarding unlock
First ensure through your network provider that the new SIM card has been activated. If not wait for the activation to complete. Everything will be fine.
If the activation has been completed and still if it doesn't work, Insert your SIM card into any other active mobile phone and check whether it works with it. If it doesn't work there is some problem with your SIM card. Contact the seller where you bought your SIM card. If it works fine with the other phone, then there must be some problem with your new phone's SIM port.
Try inserting any other active SIM card to your phone and check whether the SIM port of your mobile phone is fine.
Also make sure that the new phone is free from network restriction or locked to same network of your new SIM card. If it has been locked to some other network, you need to unlock your device.
To unlock a mobile phone from network restriction, you need to enter it's unique unlock code. You can get an unlock code from the respective network provider or from any private service. For example, If you have a Blackberry phone, You can visit UnBBLock.Com to get the unlock code. If you have any other model phone, visit http://www.mobile-unlocker.com/ to get the unlock code at affordable cost with easy unlocking guide. Good luck.
Jun 03, 2014 | Cell Phones
Eu amm uitat codul de tel
Unlock Code
#*7337#
Entering Code instructions
1. Take out the SIM card from the phone and switch the phone on.
2. Enter the unlock code into your handset.
3. Now replace your SIM card and turn the phone on.
4. Your handset should now be unlocked.
Alternative Solution if the above fails
Unlock Codes
Code 1: *7465625*28782#
Code 2: *7465625*28638#
1. Remove SIM Card from handset
2. Enter Code 1 into the handset
(Your handset will display "auto subset lock activated")
3. Enter Code 2 into the handset
a) Enter an alternative network SIM card into your Samsung and reboot.
cool.gif The new network should be displayed in handset window.
c) If the process is repeated with yet another alternative network SIM card,
you may be requested to input a security or pin code to enable the use of
the new SIM card.
d) Enter 00000000 (8 zeros) which should enable the SIM to be accepted.
e) Finally once again enter 00000000 (8 zeros) and this should permanently
unlock the Samsung.
Final alternative Solution if the above fails
Unlock Code
#7465625*638*7337#
Jan 19, 2013 | Samsung SGH-i900 Omnia Unlocked Cellular...
Forgot phone lock code for GT-S5233S
Unlock Code
#*7337#
Unlock Codes
the new SIM card.
unlock the Samsung.
Unlock Code
#7465625*638*7337#
Jan 19, 2013 | Samsung Star GT-S5233 Cell Phone
My old sim card wont work in my new phone
If your new cell phone is with a different phone service provider than the the old cell phone then the SIM card won't work in the new phone.
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try this WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
The IMEI number is unique the each mobile phone.
The number is printed on the label under the battery.
You can also get the IMEI number by entering this on your phone
*#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
Jan 25, 2010 | LG Neon GT365 Cell Phone
IPhone SIM Failure
The phone is locked to Apple and needs a Security code to unlock it.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for “Security unlocking code”.
Nov 25, 2009 | Apple iPhone Smartphone
Can you please provide me with the PUK code for my phone please?
Try this:
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Dec 07, 2007 | Lands Phones
Nokia E71 Smartphone Logo
43 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
