Question about HP Scanjet 8250 Flatbed Scanner
HP c7280 scan 2 vertical lines
When I scan a document through the feeder in my HP c7280 I get 2 vertical lines, that look like smuge/clear about 1/2 inch in widhth, running down the entire page. The first line is about 19 inches from the left edge and the 2 line sra eabout 8 inches apart. It seems they would be caused from some rollers since the lines do not print if I scan directly from the glass. Pleade advise how to fix and specifically locate the source of the issue. Thanks so much
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899181&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3204785
this fixed it for me
Posted on Apr 04, 2010
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
Vertical lines when copying from feeder or glass - does not happen when printing from computer or scanning documents.
Inspect the glass below the feeder for ink or ink correction liquid remnants from previous scanned documents. Clean them out.
Oct 08, 2014 | HP OfficeJet Pro K8600 Printer
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Duplex copying on HP Photosmart C8280 All-in-One Can't see how to do two-sided copy apart from scanning both sides and printing two-sided! Old HP printer could do 1-1 1-2 2-1 2-2 etc.
Open HP Solution Center, click on Settings, click on Scan Preferences, select "Scan both sides of original when using duplex feeder."
or
Open Solution Center, click on Scan Document, and you should have a check box towards the bottom of the window which would say 'scan both sides of the original document'. check that box and start scanning.
Jul 22, 2009 | HP Photosmart C7280 Laser Printer
Black vertical line in scans and copies when fed through top document feeder.
clean your scan glass (thin strip of glass running from front to back, underneath document feeder) with a soft cloth and alcohol.
Jul 16, 2009 | HP Officejet 5780 Printer
Vertical lines when using document feeder to scan
you may have dirty glass on scanner or the feeder rollers are dirty or need replacement.
Jun 02, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Sep 29, 2006 | Canon DR-1210C Scanner
HP Scanjet 8250 Flatbed Scanner Logo
1,048 people viewed this question
Ben Johnson
