DV328AEW will not start gives a Fault Code of FE which is abnormal power frequency I'm in the islands and cycles in the island are 50 cycles. Is there a 50 hz proccessor that I can replace or do you have a any suggestions
  • 1 more comment
  • lenny_4s Sep 20, 2009
    Thanks, the voltage at the outlet is 220V, 50hz. The electrical requirements on the dryer are
    120V/240V 3 wire 60hz 5400W.
    Thanks, this is the dryer with the problem, the washer works fine. It is not a combo washer dryer.
    any other ideas.
  • lenny_4s Sep 21, 2009
    Thanks will have to get an electrician to install a manual timer switch because shipping back to the US will cost more than dryer.
    President:
  • Washing Mach... Master
  • 1,723 Answers
Yes your machine is set up for 60 Hz. Which is what we run on through out the USA. Also the other consideration is the voltage. Normally, the 50 Hz machine is setup for 220 volts. Look at the name plate on the machine and see what the 'Electrical requirements' are that are listed. You may not be able to use that machine there. Is the voltage at the outlet 120 volts?
The 50 Hz will not necessarily hurt the machine. The main control unit may not allow 50 Hz to run the machine. It will run a bit 'slower' (the motor) due to 50 Hz power. That's all it would do though. The frequency change will change the speed of the motor running the drum.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 20, 2009
  • 2 more comments
  • Craig Butler
    Craig Butler Sep 20, 2009
    Is that a washer/dryer combo? 5400 watts is way more power than a washing machine uses.?? The machine will not function from that power source. I'm sorry to say, but you will have do something different.
  • Craig Butler
    Craig Butler Sep 21, 2009
    So sorry about that, the header says 'washing machines'. Anyway, the dryer is designed for 240 volts (for the heating element) with a neutral wire for 120 volt control, and 60 Hz. It will not run at your location.
  • Craig Butler
    Why go to any trouble...buy a cheap dryer, to get you by for now, there locally somewhere.
  • Craig Butler
    A local machine will be wired correctly, and rated for 220 volts, ready to plug in.
Hi I need code for my sony CD 307 - CDI - ISLAND - KW2000, serial number VO18714 thanks.
Hi i need help.. Ford CD307-CDI-ISLAND-KW2000
7M5T-18C939-EE
Sony CDX-FS307EE SERIAL : V031582
Feb 06, 2015 | 2009 Ford Focus
ZIP CODE OF FIJI ISLANDS
The Fiji Islands do not have a postal/zip code because the island is not big enough to require one.
May 06, 2011 | Video Cameras
I have an error code "FE" apperaing in my samsung washer dryer, it appears in the spin cycle and is not in the manual. waht causes this error
We did some extensive research and somehow found a service manual for our unit online. According to its section 4-1 "Error Items and Diagnostic Codes" the following is the problem:
(code) FE - (description) Power source frequency error - (Trigger) Invalid power source frequency - (Action taken) Check for: (a) Not using regular power source frequency (b) Invalid power frequency sense circuit.
In other words, either the thing you have plugged your machine into is faulty, the electricity itself is of poor quality where you live, or the sensor within the unit is faulty and giving an erroneous error code.
In our case, we had our machine hooked up to a cheap surge protector; which we thought might be the likely source of our problem in the light of the error code description above. So I tried connecting it to a commercial extension cord (I still got an FE code). So I tried moving the extension cord to another room's circuit, thinking maybe it was localized in the laundry room (I still got an FE code).
So, I am guessing we either have a bad "power frequency sensor" or the problem is due to the terrible electricity we have where we live (i.e. that the power frequency fluctuates too much due to our local power company's poor system).
Regardless, I hope this answer helps somebody with the "FE code" problem, now that you know what the code means.
Oct 05, 2009 | Samsung WF203ANW Front Load Washer
I can't find mirage island and jiraichi
Mirage Island, youprobably have heard of it. This Island, situated on Route 130 in Ruby& Sapphire contains one of the mysteries which has confused manyand still eludes thousands of trainers worldwide.
Now this island can onlybe seen one way, and it's complicated. Each day, Mirage Island getsassigned a random number. Now Mirage Island only appears when a Pokémonon your team has the same number as Mirage Island's number. Now thenumber changes every day and it must match the Island's. It also has tobe a Pokémon on your team. This makes your chances of seeing MirageIsland very rare.
mirage1.gifWhat you should do, instead of surfing there every single day is do the following;
  • Go to Pacifidlog Town
  • Go to the Bottom Right House
  • Talk to the Old Man thereIf he says he cannot see Mirage Island, then none of your party'sNumbers match that of Mirage Island's...so you'll have to keep trying.If he says he can see it, then leave and surf to it
    36.gifNowMirage Island in looks is rather basic. It has grass, and a specialBerry plot that gets you a new Berry...one found nowhere else, the Liechi Berry.
    mirage3.pngHowever that is not all it has, the grass contains one Pokémon, and one Pokémon only...Wynaut, The Pre-evolved form of Wobbuffet. It's levels range from Level 5 to Level 50 so be prepared for any kind of battle.
    However should you make your way to Mirage Island, be warned as it'llbe gone within a day. But don't be dismayed if you cannot get it, manyof the expert trainers go through the entire game without seeing it
  • Jun 25, 2009 | Nintendo Pokemon Box: Ruby and Sapphire...
    My problem is I can't get the cannon in zelda phantom's hourglass
    all you have to do is go to cannon island and go through the island to get to the back door of eddo's shop and speak to him then he will tell you that you have to tell him how much you want this so blow into the mic really softly and you can get it for as cheap as 50 rupees
    Mar 24, 2009 | Nintendo DS Console
    Cell phone area code for Big Corn Island, Nicaragua...???
    try to customer care and ask her fo code or contacs std operator or tellephone dierictory
    Mar 22, 2008 | Cell Phones
    Washing Machines Logo
    52 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
